Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Tue Aug 18, 2009 11:09 pm Post subject: Factory cure for sucky early wipers? |
Soooo, The early-style pinch-bolt wiper shafts suck.
They strip.
The later splined style ones are way better.
My 67 has the early style ones, and they park on the left.
It seems that they kept parking on the left until 71,
When they started parking on the right.
Did the 68, 69, or 70 cars have the splined wiper shafts?
It would be sweet to get a wiper assembly, or arms and shafts,
And convert over.
Cause the early ones suck.
Or did i mention that already...? _________________ Bus Motor Build
What’s That Noise?!? |
Blitzkrieg_ Samba Member
Joined: July 12, 2007 Posts: 229 Location: South Africa
Posted: Wed Aug 19, 2009 12:32 am Post subject: |
I've used some loctite on mine and it holds just fine |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Wed Aug 19, 2009 6:10 am Post subject: |
The 68 and 69 used the same style of wiper shaft/arm attachment as the 67 and earlier did, but I think they got a larger diameter shaft also. The 70 was the first year for splined shafts, and the last year for parking on the left. They are all by their self. The 71 to 73 used splines as well, but they had shorter shafts (due to the fresh air box change, requiring a different wiper motor transmission), and parked on the right.
If you can find a 70 wiper motor assembly, get the 1 year only wiper arms to go with it. It's an almost direct swap (you have to open the holes up for the wiper shaft seals, as they are larger). I did thios to my 65 Notch, and I've been happy since. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Aug 19, 2009 6:43 am Post subject: |
The factory did have a cure for the early ones with the set screw, but you will never find the parts.
They re-designed the wiper arm, and instead of the set screw they had a pinch bolt.
One thing that was a killer on the set screw style, was people turning the wipers on, when the blades were frozen down, or the windshield was covered with snow in the winter.
Also, try and avoid using the high speed, unless you have to.
BTW, Bob, '69 is a 1 year only wiper arms and shafts. Prior to then, the shafts were 8mm diameter. '69, they changed them to 9mm. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Paul Wilson Samba Member
Posted: Wed Oct 23, 2013 6:07 pm Post subject: |
Bobnotch wrote: |
If you can find a 70 wiper motor assembly, get the 1 year only wiper arms to go with it. It's an almost direct swap (you have to open the holes up for the wiper shaft seals, as they are larger). I did thios to my 65 Notch, and I've been happy since. |
Ok, what I have here is 3 different versions of the 12 volt wiper assemblies. Please correct me if I don't get it right. The first 3 photos are the old style shaft, about .250" in diameter. PN 311 955 113 E. Parks on left. 67 - 69?? Second set of 3 photos have the splined shaft and parks on the left. PN 311 955-113K. 1970, I think. Third set of 3 photos have the splined shaft and parks on the right. PN 311 955 113M. The frame is also different.1972--? I will get the photos up loaded tonight. I think I have them in the right order now.
Wish me luck!
Paul
I will be installing the second type on my 66 Squareback.
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Wed Oct 23, 2013 7:09 pm Post subject: |
I recently upgraded my Square this way:
http://www.aircooledtech.com/early_wiper_upgrade/
Another upgrade I did was with the arms. I used a set of Bay bus arms and shortened them. This way I have a beefier arm with stronger springs to hold the wiper to the glass = better wipe.
Just another way to skin the ol' cat. . . _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
Posted: Wed Oct 23, 2013 7:12 pm Post subject: |
Paul Wilson wrote: |
Bobnotch wrote: |
Wish me luck!
Paul
Keep in mind that you're going to need a 2 speed wiper switch from a 68 and later VW. You'll have to open the hole up a little on your 66, but IF you trim a little off the early switch knob, around the end, you can use the early knob with the later switch. I found a 90* die grinder will work at removing the material quickly, and using the late escutchion (slotted aluminum nut) will help you determine how much to remove. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Oct 23, 2013 7:37 pm Post subject: |
I will be using the 2nd version with the splined shaft. Will I have to use the 70 wiper arms? I understand that they are hard to find?
Paul |
Posted: Wed Oct 23, 2013 7:56 pm Post subject: |
Paul |
Yes. They are 1 year only parts. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Oct 23, 2013 10:02 pm Post subject: |
Bobnotch wrote: |
Paul |
Yes. They are 1 year only parts. |
I think they are right and left also. I have heard that some like to use the shorter arm on both sides. If that is true---which is shorter?
Paul |
snj Samba Member
Joined: October 18, 2006 Posts: 489 Location: Seattle, WA
Posted: Fri Oct 25, 2013 6:04 am Post subject: |
Bobnotch wrote: |
Paul |
Paul |
I was going to measure them, but I think they're the same length. If 1 is shorter than the other, it's not by that much. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Oct 25, 2013 7:59 am Post subject: |
Bobnotch wrote: |
Bobnotch wrote: |
Paul |
Paul |
I was going to measure them, but I think they're the same length. If 1 is shorter than the other, it's not by that much. |
Thanks, Bob, your knowledge is always appreciated. |
vwed Samba Member
Joined: August 07, 2004 Posts: 127 Location: United Kingdom
Posted: Thu Jul 24, 2014 12:25 pm Post subject: |
The left arm is 331 mm long, the right 321.
Source of information: a period SWF catalogue I have. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Jul 24, 2014 8:06 pm Post subject: |
Or....you can do it like many later cars did including the 411 and 412....and use equal length arms with one short and one long wiper blade. Ray |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jul 24, 2014 8:41 pm Post subject: |
I have a fix for these I'll post soon if I remember. I'd sell it as a "kit" but anyone who ordered one would be pissed and give me bad feedback- it's that simple! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Jul 28, 2014 8:30 am Post subject: |
Tram wrote: |
I have a fix for these I'll post soon if I remember. I'd sell it as a "kit" but anyone who ordered one would be pissed and give me bad feedback- it's that simple! |
Well, come on, now, don't hold out...
You are planning a big marketing roll-out with a live band and all at the big convention center downtown? _________________ Bus Motor Build
Posted: Tue Jul 29, 2014 11:46 pm Post subject: |
Clatter wrote: |
Tram wrote: |
You are planning a big marketing roll-out with a live band and all at the big convention center downtown? |
No, I've just been slammed plus ADD, LOL. I have a whole pile of stuff to catch up on including seat release handles for somebody- being laid up from the latest surgery was MONTHS longer than they told me it would be... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jul 31, 2014 11:17 pm Post subject: |
Tram wrote: |
No, I've just been slammed plus ADD, LOL. I have a whole pile of stuff to catch up on including seat release handles for somebody- being laid up from the latest surgery was MONTHS longer than they told me it would be... |
OOooo!!
So, that means that you're hard at work on my seat release levers , then??
Stoked!
Can't wait! _________________ Bus Motor Build
