C_Heath Samba Member
Posted: Mon Jul 20, 2009 1:46 pm Post subject: POR -15 alternative? |
Is there something that a person can use on good pans that are solid. No snow or salt here but Id like to get something on them before I coat them with sound proofer.
Thanks for the replys in advance. |
sharkinfested Samba Member
Posted: Mon Jul 20, 2009 2:13 pm Post subject: |
I've never used POR -15 but a good enamel tractor paint should give you some great rust protection. Heck, even good old Rustoleum would do a fine job too. I grew up on a farm. We bought a used tractor when I was 8 or so and painted it with regular Rustoleum – 25 years later it looked as good as the day we painted it and not a spec of rust. |
DonnieDarko Samba Member
Joined: September 06, 2008 Posts: 884 Location: Monroe, NC
Posted: Mon Jul 20, 2009 2:16 pm Post subject: |
Rustoleum oil-based primer or Rust Bullet. _________________ 1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
1972 Volkswagen Bus - Project
1970 Volkswagen Standard Beetle - Baja Project
I pick cheap and reliable. |
Posted: Mon Jul 20, 2009 2:36 pm Post subject: |
Oh, and I mean the Rustoleum you paint on with a brush or roller – not that aerosol rattle can stuff. And yes to the primer. |
cabrera Samba Member
Posted: Mon Jul 20, 2009 2:44 pm Post subject: |
RUST BULLET!
Absolutly the BEST stuff!
_________________ Andy |
BGEE68 Samba Member
Posted: Mon Jul 20, 2009 3:12 pm Post subject: |
Does Rust Bullet have any of the UV problems like POR15?
I went to the company site, but didn't find any mention of UV reactions. |
Posted: Mon Jul 20, 2009 3:26 pm Post subject: |
Rust Bullet is UV resistant. _________________ 1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Jul 20, 2009 3:30 pm Post subject: |
Rustoleum Rusty Metal Primer. Not to be confused with the rustoleum red primer!
The Rusty Metal Primer works GREAT! I have a car that has been sitting outside for over 30 years and where it was painted with this stuff, it is just as solid as the day it was put on. _________________ Mother Nature is a Mean Evil Bitch! |
BGEE68 Samba Member
Posted: Wed Jul 22, 2009 3:53 pm Post subject: |
DonnieDarko wrote: |
Rust Bullet is UV resistant. |
Thank you!!! |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
vpogv Samba Member
Posted: Thu Jul 23, 2009 5:55 am Post subject: |
I would recommend masterseries. Very simple to work with and tough as nails. |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Fri Sep 30, 2011 8:33 pm Post subject: |
I know this is a old thread ,but I'm going to paint the inside floors on my 74sb they are pretty solid accept the drivers side where water got in its got a lil rust but no holes ,,so I'm going to use rustoleum rusty metal primer top coated with rustoleum satin black 2cheap brushes qt rustymetal,satin black pint all for less than twenty bucks will see how it goes...any input is apreciated. |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Sat Oct 01, 2011 5:57 am Post subject: |
vpogv wrote: |
I used 2 coats of their silver primer & one chassis black topcoat on my pans... great stuff & it's cheaper than POR15 as well. Supposedly they use this stuff on bridges.... _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
ddeemiller Samba Member
Joined: September 02, 2011 Posts: 19 Location: Henderson NV
Posted: Sat Oct 01, 2011 7:11 am Post subject: |
I'm pretty new to all this stuff myself. I bought the masterseries for my inside pans. I painted it on. I was well pleased. I built a hoop house to cover my bug and I think I needed a little more air flow. That stuff was very strong. Only problem I had was that I had to wait for it to be shipped to me. About a week.
I went around town looking for similar products. I found this product called Trailercoat. I'm not sure but it seems to be the same or very similar to Masterseries. After I ran out of the Masterseries, I sprayed the whole car with trailercoat. I haven't seen any threads on this stuff so I'm just going to have to wait and see. I bought it at the marine store but at the marine store it's a bit pricey. You can buy it online for a little less than masterseries. _________________ My mechanic told me they were money pits. He wasn't wrong. Still love them. What did I get myself into? |
Posted: Sat Oct 01, 2011 7:20 am Post subject: |
Masterseries ,well my curiosity has been peeked ,I will have to give it a try! |
jlex Samba Member
Posted: Sat Oct 01, 2011 7:53 am Post subject: |
Actually, what I did before applying the Masterseries was to eliminate as much rust as possible with a wire wheel on a drill. Next I sprayed it with Phosphoric Acid to eat off the remaining rust, then when dry wiped it down w/ denatured alcohol.
You can get a gallon of phosphoric acid at Home Depot pretty inexpensively. Going into the third PA winter w/ no signs of rust! _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
Posted: Sat Oct 01, 2011 8:19 am Post subject: |
68IHscout wrote: |
Don't get it on your skin--it stays there for about 2 weeks!
Forget about cleaning & re-using brushes too--get a bunch of cheapos (even those foam-type ones work, or even cheap rollers if you're doing a big flat area--like I did the roof of my trailer with a few years ago), and then just throw them out when you're done.
And also someone else commented about using it in a well-ventilated area--definitely agree with that suggestion also... _________________ Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans |
cferry7 Samba Member
Joined: February 17, 2011 Posts: 400 Location: S.E. U.S.A
Posted: Mon Oct 03, 2011 4:30 pm Post subject: Rustoleum |
Rustoleum Oil-Based Primer - has survived !
Painted 10 % of 1 Rear Floor Pan Exterior using Rustoleum Oil - Based
Primer / Paint. 9 years later the Rustoleum still looks good !
Has seen 1 North East Winter, remaining South East Winter's.
Pleased with Rustoleum's performance / price !
Not being judgmental on Rust Bullet nor Masterseries; only commenting on Rustoleum performance / price.
_________________ 1st : ' 71 Super , 1641 cc , ~ Stock - a keeper !
2nd: ' 70 Standard , Totaled 7-14-01 , R.I.P. |
