fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Mon Sep 02, 2013 7:40 pm Post subject: |
Jake Raby wrote: |
People who favor conventional tuning and engine design simply cannot wrap their head around twin plug engines, their combinations and optimum tuning. When they try, they often fail. Instead of altering the combo they generally just say "it doesn't work" and then slam the technology.
It took us over a decade to come up with the optimum combinations. These are dramatically different than their single plug counterparts. I start at 11.25:1 CR with any twin plug engine.
In 2014 all of my engines will be twin plugged as standard offerings.
I
love my 993 twin plug, vario-ram, daily driver! |
I'm going to want a 2176 type 1 build with twin plugs from you by 2014. A true daily driver .....pushing at least 190 hp. Think you can deliver? Without absolutely killing my bank account? _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon Sep 02, 2013 7:47 pm Post subject: |
fivelugshortaxle wrote: |
Jake Raby wrote: |
I
I'm going to want a 2176 type 1 build with twin plugs from you by 2014. A true daily driver .....pushing at least 190 hp. Think you can deliver? Without absolutely killing my bank account? |
I haven't based my engines from the T1 foundation for several years now. All we build are Type 4 based engines.
I only have one Type 1 engine on my property. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Wed Sep 04, 2013 8:21 pm Post subject: |
gears wrote: |
No need to "clear out fins" .. just carefully machine through them.
Required tooling:
For those of us who aren't machinists could we buy these tools reasonably somewhere and try this at home, maybe doing a few test runs on some old heads? Or do you think a local machinist would be fine and willing to do it? Or is it so precise that only someone experienced in cutting dual ignition plugs should attempt it? _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Sep 05, 2013 8:40 am Post subject: |
All it takes is a Bridgeport & Balls .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Sep 05, 2013 9:47 am Post subject: |
gears wrote: |
All it takes is a Bridgeport & Balls .. |
Bridgeport as in a milling machine? So I guess this isn't the kind of job to try on my drill press. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Thu Sep 05, 2013 9:55 am Post subject: |
gears wrote: |
Takes more than that. You need a jig to hold it in place very ridgidly or the fins just snap off. |
Posted: Thu Sep 05, 2013 6:03 pm Post subject: |
Jimmy111 wrote: |
gears wrote: |
Would a homemade wood jig work along with a drill press? _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Posted: Thu Sep 05, 2013 6:54 pm Post subject: |
Approach angle is everything. You have to consider pushrod tube clearance, exhaust primary location (else you'll melt plug wires) and how strong the chamber is where you'll break through the casting. _________________ Jake Raby
Posted: Thu Sep 05, 2013 8:40 pm Post subject: |
Jake Raby wrote: |
Approach angle is everything. You have to consider pushrod tube clearance, exhaust primary location (else you'll melt plug wires) and how strong the chamber is where you'll break through the casting. |
Good points. It also seems to me that each combustion chamber would have a different aproach angle due to differnt positions of the push rod tubes. Right? _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
gears Samba Member
Posted: Fri Sep 06, 2013 6:51 am Post subject: |
Jig must be absolutely rigid. From a performance standpoint, you want both plugs pointed toward exhaust .. so angle selection on one of the plugs is critical. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
bj Samba Member
Posted: Sat Sep 07, 2013 7:59 pm Post subject: |
Gears,
Does the napz dist fire the plugs at the same time or is the a few degrees between them?
And yes, Bob from Pele Bug still has the original distributor ... Even though he has since closed shop.
BJ |
gears Samba Member
Posted: Sat Sep 07, 2013 8:59 pm Post subject: |
bj wrote: |
Gears,
Does the napz dist fire the plugs at the same time or is the a few degrees between them? |
Not sure what a "napz" distributor is, but after experimenting with advancing the bottom plug 2-4 degrees with my distributor, I settled on simultaneous spark. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
bj Samba Member
Posted: Sat Sep 07, 2013 9:47 pm Post subject: |
Gears,
The distributor is from the twin plugged Nissan motor (z24).
Thanks.
BJ |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Sep 07, 2013 9:50 pm Post subject: |
Doesn't that distributor spin the other way? What happens to the advance when it spins backwards? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
gears Samba Member
Posted: Sun Sep 08, 2013 5:44 am Post subject: |
Oh .. of course. The distributor we're borrowing the cap & rotor from. I remember there being two styles .. I just chose one style and stayed with it. We had to wait a couple years for Nissan to begin using Zytel plastic, so the rotor wouldn't disintegrate at 6,000 engine rpm.
I'm pretty sure the Nissan also used simultaneous spark .. (but I never worked on one) _________________ aka Pablo, Geary
'87 Syncro GL 2.5
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 419 Location: Nowhere, USA
Posted: Sun Sep 08, 2013 3:19 pm Post subject: |
Paul-
Is this work you are doing for other people, or just for your own cars? I'd be interested in seeing your distributor set-up, etc. I'm assuming you are adapting the Nissan cap/rotor to a better-known distributor, if you aren't using crank-fire.
Twin plugging just makes sense, especially as the bore increases. I think something >10:1 is completely possible with this setup (Jake said as much earlier in the thread. _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
gears Samba Member
Posted: Sun Sep 08, 2013 5:48 pm Post subject: |
I did a fair number of heads and distributors for mainland guys during the mid-90s when I had a Bridgeport & lathe on Maui. While I still have all my tooling, I haven't had a mill or lathe in over a decade.
Early distributors were merely an adapter plate shrunk fit onto any centrifugal advance distributor. I later had castings made, which after machining resembled "billet".
I seriously doubt that any of my customers went as far as Jake with his high compression combos, but I don't know .. they were all so far away. Gary Peloquin had pretty good results. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Sun Sep 08, 2013 6:08 pm Post subject: |
With that in mind, is anybody currently doing this correctly (with the bottom plugs aimed at the exhaust, and so everything clears the P/R tubes)?
... and probably equally important, is anybody building dual plug distributors or adapters? _________________ Stan Galat
gears Samba Member
Posted: Sun Sep 08, 2013 8:47 pm Post subject: |
I found the ideal placement possible only when using 10mm lower plugs. We usually changed the upper plugs to 12mm at the same time. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
