wythac Samba Member
Posted: Tue Sep 01, 2009 7:38 am Post subject: Shortest Long Build Thread Ever-Sears Rascal |
February 2004
August 2009
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Tue Sep 01, 2009 7:50 am Post subject: |
Great job! You are making a bunch of guys jealous doing things that quick! I think I like the Rascal style the best. _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her
Last edited by sturgeongeneral on Tue Sep 01, 2009 8:11 am; edited 1 time in total |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Tue Sep 01, 2009 7:53 am Post subject: |
5 years, quick?
Very nice buggy.
The more I see them the more I like them. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
azspeedbuggy Samba Member
Joined: June 20, 2006 Posts: 226 Location: Tucson Arizona
Posted: Tue Sep 01, 2009 8:14 am Post subject: |
very nice!
like the wheels and caps! |
wythac Samba Member
Posted: Tue Sep 01, 2009 8:25 am Post subject: |
Seemed like an eternity...I never drove this car before this weekend...I towbar'd it home. It sat for a year before I started in on it, so actual build time is more like 3.5-4 years, but still...a lot longer than I thought I would be at it, and of course, I aint dun yet... |
Dinubadave Samba Member
Joined: February 18, 2009 Posts: 490 Location: Dinuba, CA
Posted: Tue Sep 01, 2009 11:16 am Post subject: |
Wythac,
Nice job, it looks great. Did you make the side bars or did you purchase them? If you purchased them, do you mind telling me where you got them?
Thanks,
Dave |
wythac Samba Member
Posted: Tue Sep 01, 2009 12:41 pm Post subject: |
Made 'em. Used some extra 1.5" .120 wall DOM and some 1/8" thick x 3"steel plate.
This photo was taken before I added another lateral support. You can see how it ties in with a crossmember inside the pan. I need them as a step to get into the buggy...with the 3" lift and the tall tires, there is no "swingin' your leg" over the door sill. They are strong enough to stand on.
Posted: Tue Sep 01, 2009 12:43 pm Post subject: |
So, how big was the smile on your face last weekend after the first drive?
Pretty big I bet! _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
wythac Samba Member
Posted: Tue Sep 01, 2009 12:57 pm Post subject: |
Mr. Wizard,
I'm a cautious sort. No smiles until drive #2, where after checking all the suspension hardware for tightness, I launched it thru a corner under acceleration that made me glad I had a 5 point harness. Lots of smiles from passers-by...it seems to be a real crowd pleaser. |
House Minutia Militia
Posted: Tue Sep 01, 2009 2:48 pm Post subject: |
Nice looking tub! |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Sep 01, 2009 7:31 pm Post subject: |
So digging the stock wheels!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Tue Sep 01, 2009 7:44 pm Post subject: |
Thanks Wythac, nice job....what happened to your emergency brake? |
wythac Samba Member
Posted: Tue Sep 01, 2009 9:23 pm Post subject: |
Dave,
I of course have no idea what you are talking about.....
Murzi,
Thanks. Obviously, I like the wheels too. Fronts are stock 15" smoothies from the late 50's. Backs are the same, modified by Stockton Wheel for width, offset, and backspacing. They reamed the center out of the stock rim and welded it to a 15x8 rim, with 3.5" backspace and a 1" positive offset. The stock hubcaps were what that effort was all about....adds a real vintage feel to the car, and retains some VW identity in the bargain. |
wythac Samba Member
Posted: Thu Mar 25, 2010 8:35 pm Post subject: |
First day this year in the PNW that was nearly 70 was this week...so now that it is spring I am getting started on my "winter" updates. I had the car running and the weather held long enough in the late summer and early fall of last year for me to take the car on enough sea trials to create a punch list of stuff to work on over the winter.
Project burnout set in, however, and I took to cleaning up the mess I created with four years of fiberglass and metal fab in my shop before I would allow myself to turn a wrench on the car. Just moved it "in to position" for work last weekend.
Much needs to be done under the cowl, and in the cabin with the cowl off, so I got the car disassembled for that last weekend. It is getting a different master cylinder and some residual pressure valves on the brakes. I had some repainting on the pan to do after some brake fluid leakage up front. I have some repaint work on the fuel tank, and a better ground wire for the tank sender, along with some horn wires that need to be run. I am replacing the crappy neo steering coupler, rerouting the speedo cable so the speedo will not "hop". I am also improving the cowl and windshield mounts, welding a stop on the front beam to keep the steering box from turning on the beam.
Wiring gets cleaned up too.
Yes, I am getting rid of the red coupler. Had to repaint the pan under the master cylinder.
ccbuggy Samba Member
Joined: August 28, 2009 Posts: 153 Location: Cape Cod, MA
wythac Samba Member
Posted: Fri Mar 26, 2010 7:14 am Post subject: Sears Rascal build thread |
cc,
You must have been so dazzled by the purple of the buggy that you didn't see the line of copy that says I am getting rid of the red coupler as part of this project.
Yes, they certainly are a lot of work. Fun, though. |
wythac Samba Member
Posted: Fri Feb 11, 2011 9:49 am Post subject: |
Yesterday was the first time I saw a new Dodge Challenger with the new "plum crazy" color that I was trying to get when I worked with my paint guy on the custom color on my car....the color on my car is a little lighter shade. Either one is good if you like purple. I can pull it off on the buggy, but I think most feel as I would when they are standing in an auto showroom, wondering: "If I order purple, will I ever be able to sell this thing later?" |
Posted: Fri Feb 11, 2011 10:21 am Post subject: |
I like the purple Wythac and your car can easily pull it off; that's coming from a guy who paints everything green. I've admired your car for a long time, great stance, great color, great build! |
wythac Samba Member
Posted: Sat Apr 23, 2011 5:22 am Post subject: |
Here are some close up photos of the identifying features of a Sears Rascal/Terra Buggy Body. Mine is of the "Late(large) Tailbox" variety, probably 70-71.
Dashboard with distinctive "leg" on the passenger's side
Late tailbox
Ridge line runs down the middle of the hood. Hard to see underneath the bumper but there is a big divot for a front license plate.
Package tray area is flat
LouisB Samba Member
Joined: August 16, 2004 Posts: 1027 Location: Tallahassee, FL
Posted: Sat Apr 23, 2011 6:18 am Post subject: |
Nice looking luggage rack, that new?
--louis _________________ Louis Brooks
'67 Manx II
Old people at weddings always poke me and say "Your next." So, I started doing the same to them at funerals. |
