Wolfsburg West Repro Abarth
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu May 05, 2011 6:34 pm    Post subject: Reply with quote
A member on here told me in person that the exhaust would not clear his 1955 Barndoor Bus rear apron.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
Thomas Pedigo
Thomas Pedigo is offline
PostPosted: Thu May 05, 2011 6:54 pm    Post subject: Reply with quote
EMPIFLAKE wrote:
derluftwagen wrote:
My guess would be the curved tips are for the 55 and earlier without cutouts on the apron, and the straight pipes are for 56 up.
The cut out for the stk pipes on a 56 and later wouldent help in any abarth aplication!
. Please expound on this statement...
Defying conventional wisdom since 1970
EMPIFLAKE
EMPIFLAKE is offline
PostPosted: Thu May 05, 2011 7:39 pm    Post subject: Reply with quote
Ok my point being that the only difference on a 55 is theres no cutouts in the apron where as on a 56 there is for dual pipes! But these opening are not suiteable one way or the other for any abarth weather or not the pipes are curved or not! What derluftwagen was stateing was he thought that was the reasoning for the downwerd bend in the tail pipes was to clear a solid 55 and earlier rear apron ! But weather or not the cutouts are there dosent make a difference their still in the wrong location and only for single pipes!
AlteWagen
Troll
AlteWagen is offline
PostPosted: Thu May 05, 2011 7:47 pm    Post subject: Reply with quote
what is the difference between the A100 and A200? Both engines are 36hp, the only other change is the apron between 55 and 56.
In Fig 3 I can see two flange locations on the BP. Does the 55 earlier apron have the reinforcement piece that 56 up aprons have? If not that looks to be the reason for the change.
Snort
Snort is offline
PostPosted: Thu May 05, 2011 8:18 pm    Post subject: Reply with quote
Figure 3 shows both the left and right flanges that attach to the heater pipes and heads, as they are different lengths.
Thomas Pedigo
PostPosted: Thu May 05, 2011 8:26 pm    Post subject: Reply with quote
Well, I guess I should have saved some money and just slapped a nice set of dual quiet-packs on my '56. I personally think,(and this might be a little anal retentive),the pipes look like total dog shit hang'n down there for absolutely no good reason. Evil or Very Mad
EMPIFLAKE
PostPosted: Thu May 05, 2011 8:40 pm    Post subject: Reply with quote
This is a pic of my buddies 56 vert! He's runnin Mr Wob's exhaust same a cip! This is the one I have also if you notice if it was any higher it would hit the cut out opening in the apron and blister the paint! Does the ww abarth hang lower than this in comparson to the apron!!
Thomas Pedigo
PostPosted: Thu May 05, 2011 8:49 pm    Post subject: Reply with quote
Compared to that pic,mine hang about another 1 1/2" lower. Ill upload some pics as soon as I can get to my computer.
Thomas Pedigo
PostPosted: Wed May 11, 2011 1:10 pm    Post subject: Reply with quote
well i have some good pics to add to this topic but i cant seem to upload them. you can refer to my personal gallery to view though.[/img]
AlteWagen
Troll
PostPosted: Wed May 11, 2011 1:25 pm    Post subject: Reply with quote
Yeah, WTF?
Thomas Pedigo
PostPosted: Wed May 11, 2011 1:55 pm    Post subject: Reply with quote
Thanks Derluftwagen for the upload. I would be remiss if I did not mention that the original "pee-shooters" were approx 1" below where they should have been before I swapped-out the muffler due to a worn-out front tranny mount. However,the majority of the lower hanging issue on the exhaust is a result of the design itself. I first contacted WW via email once I installed it, asking if it was designed to be a "one size fits all" type of application as far as type1 and split window busses go,but apparently after spending over $2,500.00 with them in the last 12 months,they didn't feel it was necessary to respond to my email.
AlteWagen
Troll
PostPosted: Wed May 11, 2011 2:01 pm    Post subject: Reply with quote
Yeah your stock looks low too. Maybe wasted rear trans mounts too? What kind of trans is in there? Ive seen some early pan with late trans that had some FUNKY home made conversion stuff in there that made the engine tilt one way or another. Hope under the back seat there is no strange hack.
Thomas Pedigo
PostPosted: Wed May 11, 2011 2:22 pm    Post subject: Reply with quote
It has a splitcase transaxle still intact and I did actually measure the original sag before the muffler swap. If you look at the side-view of the muffler,one can see the verticle distance in elevation between the inlet and outlet on the WW Abarth itself. That view looks NOTHING like the cut-sheet previously posted on this topic. I should also point-out,that the original muffler was an older aftermarket repop...not original equipment.
AlteWagen
Troll
PostPosted: Wed May 11, 2011 3:05 pm    Post subject: Reply with quote
Do you have the correct nose cone and mount on the trans? Possibly a one year only 60 split case trans and cone?
Thomas Pedigo
PostPosted: Wed May 11, 2011 3:25 pm    Post subject: Reply with quote
Ill have to check that out, but what I do know about the '60,(since I just sold one) is the droop was a result of the transaxle carrier and required a special "one year only" nose cone mount. As I have the original pan on my '56,I can only assume that everything is correct for that year at this point...ie; nosecone/front transaxle mount. If you look at the last images,you can tell the take-off for the downward sloping axhaust is at a higher centerline than the WW repop. We really need to see an actual side view of the original Abarth to see just how the exhaust tips are oriented on a verticle plane compared to the inlets from the #1 and #3 "J" tubes
AlteWagen
Troll
PostPosted: Wed May 11, 2011 3:40 pm    Post subject: Reply with quote
There are a several 60 only parts. Frame horns are at a different angle than pre and post 60, I thought the carrier was the same though. Front mount, nose cone, transmission, oil dip stick, and inner apron sheet metal are also one year only.
These patent blue prints tell the story. But even if you had an original muffler it looks like it would still hang lower than it should.
Does the Mr. Wob repro follow the original design more accurately?
Thomas Pedigo
PostPosted: Wed May 11, 2011 3:53 pm    Post subject: Reply with quote
"Frame horns" is what I should have said instead of "trans carrier". Why is it that I can see MAJOR differences in overall design, yet the obvious still escapes this thread? Patiently waiting for clarification... seriously,if you wanted to discuss all of the '60 one year only issues, we could discuss the overly engineered horn design as well. Thanks for your input.
AlteWagen
Troll
PostPosted: Wed May 11, 2011 4:29 pm    Post subject: Reply with quote
I can clearly see the differnences but am wondering why others do not have the same issue. I can see an inch difference but yours looks like its low enough to rake some hay!
Same wheel, column and horn assembly was used in 61 as well. Wink
Wondering if all the picks above are actually WW and not Mr. Wob which looks more accurate
Thomas Pedigo
PostPosted: Wed May 11, 2011 5:13 pm    Post subject: Reply with quote
I suspect that Mr WOB's is closer to original in design. Could you post side view pic?
58Dub
58Dub is offline
PostPosted: Wed May 11, 2011 5:46 pm    Post subject: Reply with quote
for what its worth....here is a pic of my dads '60 back in the day with an original Abarth
58 Beetle (now just a pile of parts in the corner)
60 Beetle 6 volt 36HP
Page 4 of 7
