Heater Channel and Rear Cross Member fitting!!! HELP!
Page: Previous  1, 2, 3, 4, 5
thebugnut
thebugnut is offline
PostPosted: Sat Dec 11, 2010 6:51 am    Post subject: Reply with quote
Hi Nubby
If you are going to do any work on any car... learn to weld. I didn't know how to MIG weld before this project. Once I decided what I was going to do with this project I picked up a welder (Flux Core) and practiced on some scraps before working on the car.
BEST THING I EVER DID.
I should have learned years ago.... it really isn't that hard. You just need a little practice. Once you start to see what you can do with the welder the possibilities are endless with that you can do.
you can weld on panels, fix broken parts and even make your own tools and jigs.
Go buy a welder you can afford and start practicing.... worth every penny Smile
Old VW's Never Die, They Only Get Faster!
https://www.thebugnut.com
View user's profile Send private message Visit poster's website Facebook Twitter Gallery Classifieds Feedback
Danpa
Danpa is offline
PostPosted: Sat Dec 11, 2010 8:22 am    Post subject: Reply with quote
thebugnut wrote:
Hi Zach
I believe you can remove the luggage tray all at once from the window down. The trick to removing any of the panels is to remove all the original seam sealer and find the spot welds. Once you can see the spot welds it is easy to see how the car was put together. Get a spot weld cutter and some drill bits and cut the welds all out and you should be able to remove any panel on the car. Sometimes you will still need to get a flat pry bar or screw driver in-between the spot welds to pop them lose from each other.
It will look like this. I did change out the crossmembers, though.
Zach Thomas
Zach Thomas is offline
PostPosted: Sat Dec 11, 2010 8:56 am    Post subject: Reply with quote
Thanks for the replies! I've helped my dad replace some rear end sheet metal on two different Camaros now, so we've gotten pretty good at drilling out spot welds Laughing I just wanted to make sure it would all fit back into place without separating the pieces. Thanks again!
62 Rag - a little crusty
thebugnut
PostPosted: Sat Dec 11, 2010 2:25 pm    Post subject: Reply with quote
I love looking at everyones pictures of their projects and what that took apart. Nice work.
Zach Thomas
PostPosted: Sun Dec 12, 2010 6:48 pm    Post subject: Reply with quote
Well hopefully I can contribute some in the next couple weeks Wink
Seeing all the pictures makes it all seem possible Laughing
bjthedj410
bjthedj410 is offline
PostPosted: Wed Sep 10, 2014 6:16 pm    Post subject: Crossmember fitment Reply with quote
Hi guys what am I missing here. What folds into where to close channel end.
Page 5 of 5
