akokarski Samba Member
Posted: Wed Sep 09, 2009 11:56 am Post subject: Removing Speedo needle |
Hi,
There are about 40 posts of one page full search results on various speedo needle questions and how to get it removed, but nothing really conclusive for a sure safe way to remove these little buggers.
Here is why I want to get it off. Speedo is ticking and yes I can clean it up lube it and ticking and jumping needle symptoms should be cured. However, clear plastic part with numbers is cracked and I would like to replace it. I've got a few non cracked ones from early speedos which I scored at BOR from flowerbox (very nice panel btw). I think those should work, except for the ODO clear part, but I might be able to defrost the back of the dial wider to get all numbers showing.
I started tearing down one of the worse speedos for practice and little button that holds the needle is really on there. It feels like bastard is on there with a quite decent interference fit.
Now I am not afraid of braking the needle, as could probably take one make a mold and cast replacements. It's the button that I am having lots of trouble with. I was thinking of building a puller that would hook around the back and pull the button off, but this sounds like it's going to be come a 3 month machining project just to get a needle off the speedo. Is there a better way to get it off?
Thanks,
Anton |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Sep 09, 2009 3:08 pm Post subject: |
Hi Icy,
Yep. I've seen these threads and I've done speedo for my beetle. I think the difference between T1 and T3 speedo's is that the round part that needle is attached to made out of steel, not plastic over steel. And this is where I am having trouble of R&R.
Anton |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Sep 09, 2009 3:25 pm Post subject: |
PM Timgud. He used to do speedometer repairs. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Thu Sep 10, 2009 6:09 am Post subject: |
If/When you find out, would you post some pics? I have a myriad of gauges and will not be surprised if I find a Type 3 speedometer in the group. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
dnwar Samba Member
Joined: June 28, 2010 Posts: 2 Location: n w arkansas
Posted: Sat Jul 04, 2015 11:25 am Post subject: removing speedo needle |
I have tried to remove my type 3 1971 speedo needle but it wont budge. do I need to force it? I cant even remove the tripmeter reset knob, but I can get around that issue. Dan |
dnwar Samba Member
Posted: Mon Jul 06, 2015 7:35 am Post subject: t-3 speedo needle removal |
I did look at the threads you gave. I think the answer is that the needle mount may be made of metal and is just a tight fit. I am going to put a piece of paper or plastic under a prying point so as not to mark up the face of the speedo. then I can pry harder with a tool like a door panel remover tool. thanks |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Jul 06, 2015 8:00 am Post subject: |
A dinner fork _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
