Beetle to Thing part swappable brake system information
doublecanister
doublecanister is offline
PostPosted: Sat Sep 12, 2009 8:39 am    Post subject: Beetle to Thing part swappable brake system information Reply with quote
Beetle to Thing part swappable brake system information;
Courtsey of Eric/Uber Auto Werks
At least for us with orginal drum brakes systems.
[Doublecanister]
As I previously stated, makes it easier on obtaining local parts without
the " you drive a what? a Thing, what the heck is that?" questions.
Or my favorite so far: the local Napa jerk, you drive a Vw? you'll be one of my best customers soon..." remarks... TT.
Again I thank Eric for providing!
Courtsey of Eric/Uber Auto Werks ;
- I think I covered every stock brake part except the pedal and the blue hose. Let me know if I missed any.
- These number apply to ALL I.R.S. ('73 and later) Things, 181's, 182's, Treker's and Safari's. If you have a swing axle car ('72 and down) the front parts still apply but the rear gets goofy fast!
- "ALL" denotes Standard Beetle OR Super Beetle
Enjoy and don't overpay for "Thing only" parts that aren't!!
Eric
Uber Auto Werks
- Front backing plate is Thing only (181-609-139) Because of the lower ball joint difference, Bug can work but may rub.
- Front shoes - Std Bug '65-'77 (113-609-237C)
- Front drums - Bug '65-'67 (131-405-615A)
- Rear backing plate - ALL Bug '68-'79 (113-609-439E)
- Rear shoes - ALL Bug '68-'79 (113-609-537C)
- Rear drum - Thing only (181-501-615)
- Rear wheel cylinder - ALL Bug '68-'79 (113-611-053 B)
- Front wheel cylinder - Std Bug '65-'77 (131-611-057)
- Front wheel seal - ALL Bug late '68-'79 (111-405-641 C)
- Front inner wheel bearing - ALL Bug late '68-'79 (311-405-625 B)
- Thrust washer (@ front outer bearing) - ALL Bug '66-'79 (311-405-661)
- Axle nut left (left-hand threaded) - ALL Bug '66-'79 (131-405-669)
- Axle nut right - ALL Bug '66-'79 (131-405-670)
- Front outer bearing - ALL Bug '66-'79 (311-405-645)
- Rear wheel seal (inner AND outer) - ALL bug'69-'79 (113-501-315 H)
- Rear outer roller bearing - ALL Bug '69-'79 (113-501-277 A)
- Rear inner ball bearing - ALL Bug '69-'79 (113-501-283)
- Front brake hardware (Spring) kit - Std Bug '65-'77 (113-698-001 B)
- Rear brake hardware (Spring) kit - ALL Bug '65-'79 (113-698-003 B)
- Front brake hose (440mm) - Bug '65-'66 (211-611-701)
- Rear brake hose (235mm) - ALL Bug '69-'79 (113-611-775 E)
- Brake line kit (ALL metal lines) - STD Bug '68-'77 (113-698-700 B)
- Fluid reservoir - ALL Bug '68-'79 (113-611-301 L)
- Reservoir cap - ALL Bug '68-'79 (113-611-351)
- Master cylinder - Bug '67-'77 (113-611-015 BD)
- Brake light switches (three prong) - ALL Bug '67-'79 (113-945-515 G)
- Brake line T (At rear left) - ALL Bug '50-'79 (803-611-755)
- Clip, Brake Line to Bracket/Hose (4 per car) - ALL Bug '50-'79 (113-611-715 A)
- Grommet, Brake Line (4 Req, 2 at each bulkhead) - ALL bug '50-'79 (211-611-751)
- Star adjusting nut (2 per wheel) - ALL Bug '58-'79 (113-609-205 A)
- Adjustment screw (2 per wheel) - All Bug '68-'79 (131-609-209)
- Parking brake lever, Left - ALL Bug '58-'79 (113-609-613 A)
- Parking brake lever, right - ALL Bug '58-'79 (113-609-614 A)
- Parking brake lever pin, - ALL Bug '50-'79 (211-609-601 B)
- Clip @ parking lever pin, - ALL Bug '50-'79 (211-609-619)
- Parking brake cable bracket, left - ALL Bug '50-'79 (113-609-637)
- Parking brake cable bracket, right - ALL Bug '50-'79 (113-609-638)
- Backing plate plug (4 per wheel) - ALL Bug late '67-'79 (113-609-163)
- Lug bolt (12mm - 5 per wheel) - Bug '45-early '67 (111-601-139)
- Dust cap left (W hole) - ALL Bug '66-'79 (111-405-691 B)
- Dust cap right - ALL Bug '66-'79 (111-405-692 B)
- Parking brake cable (left OR right) - ALL Bug '73-'79 (133-609-721)
- Parking brake lever w ratchet - ALL Bug '68-'79 (111-711-305 A)
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White)
'70 Weekender (White too)
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
Chad1376
Chad1376 is offline
PostPosted: Fri Sep 25, 2009 4:42 pm    Post subject: Reply with quote
I've had ACVW's for like 25-years now. I've always told the parts guy something like:
"I need the thingamajig that hooks to the doo-hickey"
Today, I bought a brake parts, with VW part #'s in hand (thanks to this sticky). The shop owner was so happy, I thought he was going to crawl over the counter and give me a hug. He know the #'s from memory and got exactly what I needed in about 30-seconds.
Ya learn something every day. Cool
My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22
Rabid Irish
Rabid Irish is offline
PostPosted: Fri Nov 11, 2011 9:33 am    Post subject: Reply with quote
So 68-77 beetle rear 4 lug drums won't just bolt up? I need to find a rear drum that I can have drilled to I can bolt up my 15x7in Fuch's. the wide 5 adapters make the rims stick out past the fenders in the rear. Front is OK because I have a disc brake conversion and a narrowed beam. Anyone have some advise?
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Nov 20, 2011 11:04 pm    Post subject: Reply with quote
Rabid,
I don't see why you can't use the 4lug drums on your 181. I went the other way of installing the 181 rear drums on Bug rear supensions.
The type 181 add about 1/2in track width to each side. So going to the Bug drums you should have that much extra clearance in fender well.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Rabid Irish
PostPosted: Sat Nov 26, 2011 6:38 am    Post subject: Reply with quote
Well I got a set of late 4lug drums that were drilled and studded. Also got a set of spacers that allow the axel nut to be tightend down all the way. I am pretty sure it will work. I will let you all know Sunday when I try to bolt them up.
jeffff
jeffff is offline
PostPosted: Mon Sep 29, 2014 10:13 am    Post subject: Reply with quote
As per above:
I'm having trouble finding the front shoes listed. I'm trying to order from Cip1. I just got off the phone with them....they show and recommend the "537C" shoes for both the front and rear, Im assuming they will work?
vwwestyman
vwwestyman is offline
PostPosted: Wed Aug 05, 2015 8:41 pm    Post subject: Reply with quote
To respond to the above question about brake shoes (though I suspect that the poster has figured out an answer already so this is for others):
I ordered a full brake rebuild kit from The Thing Shop had two boxes of shoes in the shipment, and both boxes said "shoes for front or rear."
So I'm guessing CIP1 is also correct.
My post is on front wheel bearings.
I discovered tonight that the rear wheel bearings from any VW MK1, MK2 or MK3 (drum brake) so Rabbit, Golf, Jetta, Cabriolet 1975-1998
The part number for a kit is 191 598 625
Dave Cook
1973 Wild Westerner
My Thing
driftman11
driftman11 is offline
PostPosted: Tue Mar 01, 2016 11:52 am    Post subject: Re: Beetle to Thing part swappable brake system information Reply with quote
So, on this note. my thing has 4 lugs. They don't have the spacers I believed would have been there but everything works as it should. So are these drums off a late model beetle and just direct swap over? I was expecting to find something that screams conversion or something but I haven't found anything out of normal except my 4 lug drums. Someone please help me figure out what drums these are so I can buy shoes for it.
Rev. Scott
Rev. Scott is offline
PostPosted: Fri Mar 18, 2016 7:16 pm    Post subject: Re: Beetle to Thing part swappable brake system information Reply with quote
Part numbers?'
"I haven't seen one of those since I was shootin' at 'em!"
ecopine
ecopine is offline
PostPosted: Fri Aug 12, 2016 9:40 am    Post subject: Re: Beetle to Thing part swappable brake system information Reply with quote
Is there a list like this for other parts that are compatible or not?
Is there a rule for compatibility between Sedans and Safaris/Things? Obviously engine parts are the same, and body parts interchange is not, but what about the transaxle, Ball Joints, stabilizers, etc?
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Apr 29, 2020 10:17 am    Post subject: Re: Beetle to Thing part swappable brake system information Reply with quote
Trying my lousy luck here... Rolling Eyes
Is there a rear disc brake kit for a '73, WITH the porsche pattern 5x130? Confused
Have found front kits with the pattern that are "claimed" to fit but the only rears are wide-5. Sad
dan macmillan
dan macmillan is offline
PostPosted: Sat Sep 05, 2020 8:05 pm    Post subject: Re: Beetle to Thing part swappable brake system information Reply with quote
I just took this disk conversion off a 74 Beetle chassis and put it on my 74 Thing. Works perfectly.
Chevy/porsche pattern with ebrakes
There is no reason why it won't work on a 73.
https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D4126%2DKT
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
volkybus
volkybus is offline
PostPosted: Mon May 08, 2023 3:08 pm    Post subject: Re: Beetle to Thing part swappable brake system information Reply with quote
A reply to ecopine about transmission swaps The late bug tranny 71 up will fit but the cv joints are smaller. The thing has bus sized cv joints while bug tranny's are smaller I changed mine a few years ago after I got sick of the bungee cord usage in the mts of Conn.The bus and bug cv joints fit on the original axles. I got lucky as it's been at least 5 or 7 years ago.somaybe 20 k miles.I recommend changing transmission oil on a stick every 25 thousand miles or so.Also the wheel bearings are the same.I think. Also buy German ones unless you want to do the job twice ormore.. (the cheap way always comes out more expensive). Good luck Bill ..PR N Vt
