dippedbus Samba Member
Posted: Fri Sep 18, 2009 8:55 am Post subject: bus underside factory colour |
Can anyone confirm weather a bus came sprayed in primer underneath from factory ?
Or was it lower body colour?
And if primer etc what year bus it was applicable to if not all . _________________ Table top restorer! |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Fri Sep 18, 2009 8:57 am Post subject: |
Bus was dipped in primer at the factory. Then the lower body color was oversprayed onto the underbody. They would get the wheelwells pretty good and what they could see from inside/under the engine compartment. The rest was left in the primer color. |
Posted: Fri Sep 18, 2009 9:01 am Post subject: |
awesome response time
Any one else confirm this have conflicting views on this _________________ Table top restorer! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Sep 18, 2009 11:32 am Post subject: |
I concur from having owned two og paint busses and paying attention to people like MW. Both mine had been dealer sprayed with undercoating to prevent salt rash over the factory finish: one in snotty mucus semi sticky semi clear, one in dry black powdery glittery tar-ey stuff. |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Fri Sep 18, 2009 11:43 am Post subject: |
dippedbus wrote: |
Any one else confirm this have conflicting views on this |
Wait, so "dippedbus" has conflicting views on whether his bus was dipped? Is it just me??
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
camerod Volksfab
Joined: October 01, 2002 Posts: 606 Location: washington state
Posted: Fri Sep 18, 2009 12:20 pm Post subject: |
my '58 15 has both chestnut and sealing wax painted on the bottom. the wheel wells are sealing wax but the center area between the outriggers is all chestnut and was painted BEFORE the sealing wax as it has some very light sealing wax over spray. this bus was fully undercoated I already removed it leaving very well preserved paint.
the only signs of exposed primer is in the wheel well area where the coverage of the sealing wax is a bit thin. _________________ DON'T SHIT WHERE YOU EAT! |
Posted: Sat Sep 19, 2009 12:57 am Post subject: |
excellent 2 pack zinc epoxy primer it is ,like the shiny look of body colour but it soon goes off in uk climate. _________________ Table top restorer! |
Posted: Sat Sep 19, 2009 9:11 pm Post subject: |
If you are going to use it as a daily driver in the UK, I suggest you consider painting the underside with Wurth SKS Stoneguard gray. It is a thin, undercoating-like coating that is smoother than asphalt undercoat, and it is bluish gray, like the factory primer was. It is a good compromise between rust protection and factory correctness. |
Posted: Sun Sep 20, 2009 12:48 am Post subject: |
Major Woody wrote: |
excellent will have a peek ,unsure about doing the whole underside though maybe arches only.
Bus is never gonna see rain and will be kept in a dehumidified carcoon aswell _________________ Table top restorer! |
Lohe Samba Member
Joined: June 26, 2007 Posts: 662 Location: Chandler, Az
Posted: Sun Sep 20, 2009 7:56 am Post subject: |
dippedbus wrote: |
Bus is never gonna see rain and will be kept in a dehumidified carcoon aswell |
You are joking, right? |
Gmiee5 Samba Member
Joined: December 06, 2008 Posts: 388 Location: Portland Oregon
Posted: Fri Jan 01, 2010 10:57 pm Post subject: |
It looks to me that you are correct with your description.
This is the bottom of my bus after the undercoating was removed
Note: the bus is a 1967 21 window
