johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Sat Sep 19, 2009 4:31 pm Post subject: Brake fluid reservoir, Steel vs. Aluminum |
When did they switch from steel to aluminum? Or was aluminum only a replacement part? I have some ideas, but they are only from hearsay conversations. Anyone have to documented story ??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Sunroof53 Samba Member
Posted: Sun Sep 20, 2009 3:16 pm Post subject: |
Funny you should post this as i was about to ask whether anyone has a drawing for an early resevoir so i can make one for my 53.I was going to machine one from Stainless steel.I have never seen one ,even at swap meets to copy.I do remember SCVW repaired one when he restored his Black 53 a while ago. http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=120 |
Posted: Sun Sep 20, 2009 6:19 pm Post subject: |
I have 2 of them, and considering selling one. Both are steel with steel caps. I also have an aluminum one in horrible shape, and have seen the aluminum ATE replacement caps around for years. Just trying to get a clear understanding of what the history is.
One of mine has been zinc plated, and the other is going to the plating this week. As you probably know, the tops get mangled as people tried to wrench them off.
I can post some pics of them here if folks think that would help... _________________ John Henry
'57 Deluxe
'56 Single Cab |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Sun Sep 20, 2009 8:07 pm Post subject: |
I think in '54 and up the Beetles had the res behind the spare already. In fact I know they did in '54, with the M6 nuts. Maybe people were using AL bus ones on split Beetles as replacements..... _________________ John Henry
'57 Deluxe
'56 Single Cab |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Sun Sep 20, 2009 8:09 pm Post subject: |
My 56 had a steel reservoir behind the spare with a rubber cap. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Mon Sep 21, 2009 8:36 am Post subject: |
Not sure about VW, but my early '53 356 had the aluminum can with the aluminum cap. Hard to find aluminum cans that are not rotted through at the bottom.
Alan Hall |
Posted: Mon Sep 21, 2009 9:16 am Post subject: |
alanhall wrote: |
Alan Hall |
I had some data that said the res moved to behind the spare tire in '53, but probably mid year. Don't have PR in front of me. _________________ John Henry
'57 Deluxe
'56 Single Cab |
ZwitterND Samba Member
Joined: September 08, 2005 Posts: 1451 Location: Fargo, ND
Posted: Mon Sep 21, 2009 12:48 pm Post subject: |
My 11/52 zwitter has steel can & top, but then again I just found out that the exterior door handles are from '51. They must of emptied the parts bins when they built this thing. _________________ Bill |
Posted: Mon Sep 21, 2009 12:57 pm Post subject: |
So no evidence of an aluminum res being used on a split/oval from the factory?? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Sep 21, 2009 10:00 pm Post subject: |
Looked in the '52/54 worklshop manual to see if it said or showed anything. The only pictures of the master cylinder and reservoir show what appear to be the steel can with the larger radius corners at the bottom. No mention of any setup except the master cylinder with the attached can.
Alan |
ProjectX Accessory Nut
Posted: Tue Sep 22, 2009 3:55 pm Post subject: |
My October '53 had an aluminum can originally, it was rotted through the bottom but I can attest to the fact that it was original And full of mystery sludge _________________ Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible |
Nessy Samba Member
Joined: September 28, 2004 Posts: 424 Location: Wales,UK
Posted: Wed Sep 23, 2009 9:21 am Post subject: |
My Sept '53 still has its aluminium reservoir perched on top of the master cylinder, but the lid has a plain, flat top......
Do I take it then from reading this thread that the lids for aluminium reservoirs that have an octagonal boss on the top marked 'ATE' are in fact service replacements?
So my lid could be original factory fitment?
_________________ 1972 1302LS Convertible RHD |
Posted: Wed Sep 23, 2009 12:46 pm Post subject: |
Nessy wrote: |
I think they are, only because you see them everywhere, and they look too new to be true "NOS" parts. I'm sure it was a common replaceble part and Ate just made a whole pile of them. Probably used on another marque's brake system as well.
I have never seen a plain flat top on any res though. Nessy, can you post a pic? I'll post a pic of the ones I have next evening or two... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Wed Sep 23, 2009 3:54 pm Post subject: |
Should there be markings on the cover if so what are they and from which side can they be read. Reason being I have purchased a couple of caps which were claimed to be NOS and a repro but each are different. Anyone got a picture of an original cover? My original cap was pretty much bonded to the resevoir and it appears someone used the jaws of life to remove it a couple of times. _________________ Bill |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Sep 23, 2009 6:25 pm Post subject: |
My 50 has an aluminum reservoir and I'm pretty sure thats the original one. My old man's 50 had an aluminum reservoir and my uncle's 50 has an aluminum reservoir.
I have few extras in my spares, but they are all eaten away. I've seen other bad aluminum ones at swap meets, but i don't think I ever saw a steel one. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Sep 23, 2009 8:21 pm Post subject: |
any og pics of a steel one? |
Posted: Wed Sep 23, 2009 11:00 pm Post subject: |
Steel one I picked up somwhere, not sure what vintage.
Posted: Thu Sep 24, 2009 12:08 am Post subject: |
Two aluminum caps, I was told the one on the right is OG and left is a repro. The knurling on right cap is larger. The repro cap is more rounded.
