Brake fluid reservoir, Steel vs. Aluminum
Page: Previous  1, 2
splitjunkie
splitjunkie is offline
PostPosted: Thu Sep 24, 2009 3:13 am    Post subject: Reply with quote
ZwitterND wrote:
Steel one I picked up somwhere, not sure what vintage.
that's what my Oct 51 came with. It was parked in '62
Chris
johnshenry Premium Member
johnshenry is offline
PostPosted: Thu Sep 24, 2009 3:13 pm    Post subject: Reply with quote
Here's a few pics of the 2 steel ones I have. One has been zinc plated, the other recently media blasted.
John Henry
'57 Deluxe
'56 Single Cab
Nessy
Nessy is offline
PostPosted: Sat Sep 26, 2009 12:56 am    Post subject: Reply with quote
johnshenry wrote:
Nessy wrote:
My Sept '53 still has its aluminium reservoir perched on top of the master cylinder, but the lid has a plain, flat top......
Do I take it then from reading this thread that the lids for aluminium reservoirs that have an octagonal boss on the top marked 'ATE' are in fact service replacements?
So my lid could be original factory fitment?
Wink
I think they are, only because you see them everywhere, and they look too new to be true "NOS" parts. I'm sure it was a common replaceble part and Ate just made a whole pile of them. Probably used on another marque's brake system as well.
I have never seen a plain flat top on any res though. Nessy, can you post a pic? I'll post a pic of the ones I have next evening or two...
Don't have any pics sorry, in the light of the other responses on this thread, am beginning to think that the cap on my aluminium reservoir isn't original Sad .
Have to admit that at first glance the cap did remind me of the type of lid you used to find on aluminium pharmaceutical canisters in drug stores years ago............... Question
1972 1302LS Convertible RHD
splitpartsunlimited
splitpartsunlimited is offline
PostPosted: Fri Oct 09, 2009 7:48 am    Post subject: Reply with quote
IMO: i believe there are no "ate marked" repro caps , the repro i make has no markings , and it is a clon of the cap found in my own split , no markings either , just like some nos caps being sold at the samba right now .
by last , you can buy any reservoir and cap combo you want , but beware of threadless units Laughing Laughing Laughing Laughing ..... pics will follow later today ....
in my Garage:
1951 crotch cooler split
1971 1302 cabriolet
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring
hazetguy
hazetguy is offline
PostPosted: Sat Dec 05, 2009 4:06 pm    Post subject: Reply with quote
here are a bunch of pics of the reservoir assembly that came with my March 13, 1951 Beetle. also pictured is the NOS cap i scored in the classifieds for $10 shipped. Dancing
i doubt the screen is correct since it doesn't really fit anywhere.
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
PostPosted: Sat Dec 05, 2009 5:47 pm    Post subject: Reply with quote
Is the res steel? That cap looks like the aftermarket NOS aluminum ones that have been everywhere lately. Good looking usable cap, but you may have corrosion problems with dissimilar metals if you use it on a steel res. Could be OK, if you put a little anti-seize compound on the threads and take it off every now and then.....
John Henry
'57 Deluxe
'56 Single Cab
hazetguy
hazetguy is offline
PostPosted: Sat Dec 05, 2009 5:58 pm    Post subject: Reply with quote
yes, reservoir is steel. unfortunately i am not a miracle worker, and i feel the original steel cap, while it still screws on, is beyond being fixable to the point where it wouldn't leak.
here is a "before" pic of the aluminum res cap. i would speculate that it is an NOS one and not a repro. i've seen a few repro caps, and this one is nicer, the logos are nice and crisp, and it is more "squared". but hey, if it is repro, it was still way cheaper than i could have bought it anywhere else.
i've pondered the corrosion/dissimilar metal situation, and i was planning on using some kind of anti-sieze on the threads. i may also have the cap anodized for additional protection.
hazetguy: invested?
Cabriothusiast
Cabriothusiast is offline
PostPosted: Sat Dec 05, 2009 9:10 pm    Post subject: NOS Steel Brake Fluid Can and Top Reply with quote
splitpartsunlimited
PostPosted: Tue Dec 15, 2009 4:49 pm    Post subject: Reply with quote
reservoirs in aluminum are available right now , 100% compatible with original or aftermarket caps
in my Garage:
1971 1302 cabriolet
hazetguy
hazetguy is offline
PostPosted: Tue Dec 15, 2009 4:55 pm    Post subject: Re: NOS Steel Brake Fluid Can and Top Reply with quote
Cabriothusiast wrote:
what's up with that weird "bolt" and nut? looks like the torsion arm retaining bolt/nut for a front axle.
hazetguy: invested?
Cabriothusiast
PostPosted: Tue Dec 15, 2009 9:07 pm    Post subject: Steel Brake fluid resevoir Reply with quote
The screw is original but the nut is just on it to hold the screen filter screw in.
bwaz
bwaz is offline
PostPosted: Tue Nov 06, 2012 9:08 am    Post subject: Reply with quote
and would this be the correct way for the insert to sit in the cap? I've tried this but found the brake fluid is leaking out the top. The rubber ring has softened and not giving a great seal. What's the purpose of the insert anyway? I was going to try for another seal, or for now just make one out of a gasket material to seal it all up.
thanks
Brian Waz
bwaz
bwaz is offline
PostPosted: Sun Feb 24, 2013 7:27 pm    Post subject: Reply with quote
after finding it wasn't the cap, I needed a way to remove the brake fluid to replace the washer between the master clyinder and the reservoir. Didn't want to bleed the brakes, and the siphons were mostly for gas tanks... this was the solution, dollar store pump worked great!
PostPosted: Sun Feb 24, 2013 8:12 pm    Post subject: Reply with quote
Cool stuff. I use a turkey baster.
Don't tell the wife.
Or come over for Thanksgiving....
John Henry
'57 Deluxe
'56 Single Cab
ZwitterND
ZwitterND is offline
PostPosted: Sun Feb 24, 2013 8:50 pm    Post subject: Reply with quote
Note to self, don't eat turkey at John's place.
Bill
James Davies
James Davies is offline
PostPosted: Sat Jul 19, 2014 6:32 pm    Post subject: Reply with quote
Does anybody know on what cars or buses the aluminum ATE brake reservoir on the right was used? The one on the left was used in 1953 Porsches.
As you can see, the one on the left has a standard 22 mm diameter hole for the hollow fastening bolt. The one on the right has a smaller 14 mm hole.
Anyone know anything about the one on the right?
Page: Previous  1, 2
Page 2 of 2
