rebuilt engine, turns over very slowly
VWinTHEblood
VWinTHEblood is offline
PostPosted: Sun Sep 20, 2009 5:16 pm    Post subject: rebuilt engine, turns over very slowly Reply with quote
I recently finished my engine rebuild on my 1970 deluxe, 1600 single port. When I try to fire it up it turns over really slowly. I have a new battery and starter and I cleaned all the corrosion off the connections to the starter and battery. I can't seem to get the engine to turn over fast enough even when it's connected to a running vehicle for a jump start. I noticed that the main transmission ground strap is broken in half, could this be causing the problem? The only other thing I think could be the problem is with the wiring from the ignition switch to the starter solenoid. I can't inspect much of the wiring because it runs under the belly pan of the bus. Any thoughts appreciated. Thanks.
Daverham
Daverham is offline
PostPosted: Sun Sep 20, 2009 5:20 pm    Post subject: Reply with quote
How does it feel when you turn it over by hand? Are we talking about awesome compression, misaligned bearings or an electrical/starter problem?
78 Kombi, 65 Bug, 69 Baja Bug, 63 Camper Van, 66 Bug, 72 Bug, 60 Ghia
busdaddy
busdaddy is offline
PostPosted: Sun Sep 20, 2009 5:24 pm    Post subject: Reply with quote
Fix that ground strap, the clutch cable is not meant to be a ground path.
As stated, how does it feel?
Desertbusman
Desertbusman is offline
PostPosted: Sun Sep 20, 2009 5:32 pm    Post subject: Re: rebuilt engine, turns over very slowly Reply with quote
VWinTHEblood wrote:
I noticed that the main transmission ground strap is broken in half, could this be causing the problem? .
Think about it. The starter requires a lot of juice. So there is the big positive cable from the battery straight to the starter. Where is the big qround cable from the starter back to the battery? It has to be able to complete the circuit. That ground strap that is broken plus all the bolted connectiions between the starter and trans, trans to frame via the ground strap, and then the frame to the battery with the battery ground cable.
If the starter is turning at all now without the trans ground cable the power is going thru all the lessor metal to metal contacts such as clutch and throttle cables, maybe the axle shafts, and wherever else.
Get a new ground strap on the trans.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
VWinTHEblood
PostPosted: Mon Sep 21, 2009 4:21 pm    Post subject: Reply with quote
The engine turns over perfectly, all the main bearings are seated correctly. Someone told me that a worn starter bushing may be causing the problem?
Sawsalesman
Sawsalesman is offline
PostPosted: Mon Sep 21, 2009 4:30 pm    Post subject: Reply with quote
Try fixing the strap first.
TomWesty
TomWesty is offline
PostPosted: Mon Sep 21, 2009 4:44 pm    Post subject: Reply with quote
All that stuff probably worked okay when you had an engine with weak compression and loose bearings. Now it needs more current to the starter to turn it over because you have a much tighter engine. The strap completes the path for that current. Replace the strap first.
VWinTHEblood
PostPosted: Mon Sep 21, 2009 8:52 pm    Post subject: Reply with quote
Okay thanks everyone, I ordered a new ground strap today. Ill post when I get it installed and see if it was the problem.
iratehippie
iratehippie is offline
PostPosted: Tue Sep 22, 2009 9:12 am    Post subject: Reply with quote
If you have some good jumper cables you could try and use them as grounding wire, trans. to frame, see if that makes a difference.
a-marshal
a-marshal is offline
PostPosted: Tue Sep 22, 2009 11:09 am    Post subject: Reply with quote
or use the jumper cable from the negative pole of the battery direct to the tranny case..
VWinTHEblood
PostPosted: Tue Sep 29, 2009 1:57 pm    Post subject: Reply with quote
I fixed the ground strap which corrected the slow starter motor so I was then able to start the rebuilt engine for the first time. I am now trying to work out some kinks in the fuel system to get the engine to run properly at idle. Thanks for everyone's help.
aeromech
aeromech is offline
PostPosted: Tue Sep 29, 2009 2:23 pm    Post subject: Reply with quote
another samba success story
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
