Typical oil pressure?
DonnieDarko
DonnieDarko is offline
PostPosted: Tue Sep 29, 2009 7:10 pm    Post subject: Typical oil pressure? Reply with quote
I hooked up a mechanical oil gauge I got, and it's reading ~43psi idle and 45psi or so when given gas (though, in neutral).
Sound about right?
1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
1972 Volkswagen Bus - Project
1970 Volkswagen Standard Beetle - Baja Project
I pick cheap and reliable.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Sep 29, 2009 7:11 pm    Post subject: Reply with quote
43 idle... how thick and how cold is the oil?
What's it at operating temp?
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
DonnieDarko
PostPosted: Tue Sep 29, 2009 7:19 pm    Post subject: Reply with quote
43psi is 10w-30 and an ice cold motor in about 60F weather.
I drove about 50 miles and checked it (the gauge is temporarily mounted in the rear until I get long enough hose) and now it's at 20psi and when given juice it climbs to 40psi or so (before I backed off the gas, the neighbors are sleeping) Wink
Mr. 010
Glenn is offline
PostPosted: Tue Sep 29, 2009 7:21 pm    Post subject: Reply with quote
That sounds better.
Glenn
DonnieDarko
PostPosted: Tue Sep 29, 2009 7:26 pm    Post subject: Reply with quote
Glenn wrote:
That sounds better.
Is it within specs? What's yours at?
Mr. 010
Glenn is offline
PostPosted: Tue Sep 29, 2009 7:27 pm    Post subject: Reply with quote
Hot... my oil pressure is like 10psi at idle.
Glenn
DonnieDarko
PostPosted: Tue Sep 29, 2009 7:31 pm    Post subject: Reply with quote
I wish I would have checked it without shutting it off. I drove 50 miles, went to take a leak, posted my thread, and then started my car back up and got the 20psi reading.
As long as it's not too bad, I'm happy. Laughing
Thanks again Glen Very Happy
10 A C N
10 A C N is offline
PostPosted: Tue Sep 29, 2009 7:53 pm    Post subject: Reply with quote
Oil temp 158 F. Oil SAE 30 at 2500 RPM (42 PSI new installation)
(28 PSI wear limit)
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Tue Sep 29, 2009 8:25 pm    Post subject: Reply with quote
20 at idle is OK
Experience always triumphs over hearsay and You get to select which theory to believe
SkrapMetal
Samba Hornblaster
SkrapMetal is offline
PostPosted: Tue Sep 29, 2009 8:50 pm    Post subject: Reply with quote
But you have a 26mm pump Glenn... don't you?
oo9less since 2007
-72 Ghia-
fastinradford
fastinradford is offline
PostPosted: Wed Sep 30, 2009 5:11 am    Post subject: Reply with quote
regardless, 5-6 psi is fine at idle, you do not need more than 2-3psi without a load on the motor.
Smithy
Samba Smithy
Smithy is offline
PostPosted: Wed Sep 30, 2009 6:48 am    Post subject: Reply with quote
A general rule of thumb is 10psi per 1000 rpm. With that in mind, with the engine warm and at 850 rpm (idle speed), the oil pressure should be about 8.5 psi. These are general guidelines.
The stock oil pressure sender goes off at 6/7psi. Therefore, depending on conditions, the oil light may flicker at idle. This is normal. There is no cause for worry if the oil pressure is 10psi per 1000 rpm at speed and under load.
Less oil pressure than 10psi/1000rpm may indicate internal bearing or case wear and should be addressed before your engine suddenly goes "boom".
Don't take life too seriously- you'll never live thru it....
Dyslexic rebel, I beats to the drum of a different march.
Cusser
Cusser is offline
PostPosted: Wed Sep 30, 2009 7:01 am    Post subject: Reply with quote
My idle oil pressure is also 10 psi or lower when hot, even Arizona hot (20-year-old 1835cc).
DonnieDarko wrote:
I drove 50 miles, went to take a leak...
Thanks for sharing.....
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
