stock vs welded counterweighted crank
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
Counterweighted cranks
NO stock is fine for 5000 rpm
21%
 21%  [ 7 ]
YES Always go counterweighted
78%
 78%  [ 25 ]
Total Votes : 32
hendersoned
hendersoned is offline
PostPosted: Wed Sep 30, 2009 5:01 pm    Post subject: stock vs welded counterweighted crank Reply with quote
What is the safe rpm limit of a stock cam for OCCASIONAL higher rpm use IE in an off road play car, mild cam and 2 barrel single carb, 1835 cc or 1915 cc. Shooting for 90 hp or so, driven 3000 miles a year, NOT my dailey driver. Do I need a counterweighted crank for 5000 rpm. I'm not drag racing it and am looking to build a motor that makes power from 1500 to 5000 and don't want to waste the $$ if I don't need the counterweighted crank.
If I go longer stroke then fur sure it will be counterweighted...
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Wed Sep 30, 2009 6:27 pm    Post subject: Reply with quote
I've taken my totally stock 1600 to 5500 on many occasions, never did it any harm that could tell. Trouble is crank failure are almost always fatigue related failures, so you'll NEVER know something's wrong till it snaps...
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
SGKent Premium Member
SGKent is offline
PostPosted: Wed Sep 30, 2009 6:43 pm    Post subject: Reply with quote
stock balanced 1600 with dual carbs, 1980's. used to drive 5500 RPM three hours at a time back and forth to Lake Havasu from LA. Never had an oil or bearing issue.
IMHO just make sure you have a good align bore, case savers or better and the entire engine is balanced by a professional racing shop. If you don't plan to drag it then you won't see the kinds of forces that will snap it.
It is a 40 to 50 year old car that has been abused by at least one of the prior owners. Many parts are no longer available, and like BusDaddy says - rust never sleeps. Better get used to it. If you can't then be prepared to get out your wallet, and your tools.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Sep 30, 2009 6:45 pm    Post subject: Reply with quote
5500rpm for 3 hours????
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
Endicott jb
Bondo King
Endicott jb is offline
PostPosted: Wed Sep 30, 2009 6:56 pm    Post subject: Reply with quote
The major issue with turning a non counterweighted crank is it can warp the case around the case, leading to oil spewing from behind the pulley. I will almost never turn my engine past 4500. And that is with a counterweighted crank.
Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs.
SGKent is offline
PostPosted: Wed Sep 30, 2009 7:21 pm    Post subject: Reply with quote
yes - 80 - 90 mph 71 deluxe stock trans with duals a cam and a well built 1600 engine. Running between LA and Havasu. Boring long drive. I pulled studs, cracked rear of cases, wore shims through crank to dowells, cracked heads but never had a single issue with crank,rods, pistons or valves. I was building water cooled racing engines in those days that held together for 250 - 350 miles at close to 10,000 RPM. Some people we knew were getting 14,000 RPM out of motorcycle engines back then. Today I've read that a formula one cars go up to 20,000 rpm at times. My heads were ported by the same guy who built engines for Al Unser Jr. and some Cosworth engines for Indy. Also helps he was a Super Vee winner several years in a row. I worked in his shop boring blocks, resizing rods, align boring and rebuilding engines, decking, blue printing engines etc. All my machine work came free.
Glenn - you have to stop doubting me so much. It is downright annoying.
Type 5 Joe
Type 5 Joe is offline
PostPosted: Wed Sep 30, 2009 7:26 pm    Post subject: Reply with quote
So you are saying 5500 RPM for 3 hours?
With a stock crankshaft?
Built by YOU?
C'mon you must be kidding....
- Just messing with you. Cool
Mr. 010
Glenn is offline
Sorry, but when you say things that don't make sense, I just have to point it out.
5500rpm for 3 hours with a Type 1 engine ... has anyone else done that?
Anyone?
Glenn
Hotrodvw
Hotrodvw is offline
PostPosted: Wed Sep 30, 2009 7:50 pm    Post subject: Reply with quote
Wow... Might want to install a tach. I don't think that calculates out right. I'm barely at 4500 at 90.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
gt1953
gt1953 is offline
PostPosted: Wed Sep 30, 2009 7:58 pm    Post subject: Reply with quote
Go with the counter weight it will be so much smoother. Trust us who have them. Enuf said. Very Happy
hendersoned
PostPosted: Wed Sep 30, 2009 8:05 pm    Post subject: Reply with quote
if you have ever seen a class one-1600 go by a full chat they run 400 to 500 miles (up to 1000 in baja) at warp speed! but I'm not interested in a 1600 race motor (12:1 compression, 90 hp the hard way)
Jimmy111
Jimmy111 is offline
PostPosted: Wed Sep 30, 2009 9:17 pm    Post subject: Reply with quote
The drive from LA to vegas is all uphill. For a lot of it a stock bug needs 3rd gear at WOT. I used to drive it many times and the motor does scream. Couldnt tell you the RPM but it is up there.
Fot the typical VW owner these days I would say a CW crank is a good Idea. We all have lead feet... Very Happy
sturgeongeneral
sturgeongeneral is offline
PostPosted: Wed Sep 30, 2009 9:31 pm    Post subject: Reply with quote
For lonevity and piece of mind, counterwieghted AND BALANCED! For a little bit more money, just pay it. In the long run it is definetely worth it!
Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her
madmike
madmike is offline
PostPosted: Thu Oct 01, 2009 6:23 am    Post subject: Reply with quote
I vote for CW Cool I ran a 1/2 1600 Buggy in SCORE events my rear tires were off the ground alot Shocked =5k+rpms Laughing Shocked That was 30+ yrs ago and I still have the motor It's in my daily driver Cool
65 Baja
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag bug 1915 or 2276 'Turbo'
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's
veedubcrazy
veedubcrazy is offline
PostPosted: Thu Oct 01, 2009 7:30 am    Post subject: Reply with quote
C/W crank.
1967 Deluxe Sedan
www.bayareavwclub.com
The Noof
The Noof is offline
PostPosted: Thu Oct 01, 2009 7:49 am    Post subject: Reply with quote
I think this pole is retarded.IF you're building an air cooled VW engine of any sort, for any purpose, 1600cc or larger,why would you even consider a non-counterwieghted,balanced engine?
Mr. 010
Glenn is offline
PostPosted: Thu Oct 01, 2009 7:51 am    Post subject: Reply with quote
Can you balance a non-CW crank?
Glenn
Hotrodvw
Hotrodvw is offline
PostPosted: Thu Oct 01, 2009 8:06 am    Post subject: Reply with quote
It all depends on what your tolerances are..... How close is acceptable, etc.. You can balance anything, with lots of work.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
melville
melville is offline
PostPosted: Thu Oct 01, 2009 9:00 am    Post subject: Reply with quote
SGKent was talking about a Bus. I've got probably the same gearing in my Westy, and I get 5K at 80. I don't do 90 in a Bus.
On the subject:
Sounds like he had some case problems, which I understand is the main reason for a CW crank in a mag cased T1.
Any T1 I build that is not absolutely stock will have a CW crank. It's only a few bucks more.
2000 M Roadster
75 R75/6
65 Standard Micro
61 Sunroof
60 Sunroof
57 Sedan
The Noof
The Noof is offline
PostPosted: Thu Oct 01, 2009 9:11 am    Post subject: Reply with quote
Yes Glenn,you can:Piston/rods/pins/clips/ are wieghed and replicated by bob wieghts.Bob wieghts are attatched to the rod throws,than balanced.
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
