Counterweighted cranks |
NO stock is fine for 5000 rpm |
21% |
[ 7 ] |
YES Always go counterweighted |
78% |
[ 25 ] |
Total Votes : 32 |
77charger Samba Member
Posted: Thu Oct 01, 2009 7:34 pm Post subject: |
go counterweighted.If you do decide you need more power later on the crank is a good start.
If for off road your rpms will be up.Say you are climbing a soft dirt/sand hill you will spin the motor up and likely about 5k rpm. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu Oct 01, 2009 7:41 pm Post subject: |
168,000+ members on The Samba and only 30 people have voted?
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Thu Oct 01, 2009 7:45 pm Post subject: |
I vote for Wasserboxer Crankshaft & flywheel.
Quit screwing around with junk. _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
SGKent Samba Member
Posted: Thu Oct 01, 2009 8:08 pm Post subject: |
wow - you can't get 5500 out of a stock crank engine sustained for 3 hours? must be some terrible engine builders these days. I thought y'all were pretty good but this makes me doubt your abilities. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Hotrodvw Samba Member
Posted: Thu Oct 01, 2009 8:15 pm Post subject: |
SGKent wrote: |
wow - you can't get 5500 out of a stock crank engine sustained for 3 hours? must be some terrible engine builders these days. I thought y'all were pretty good but this makes me doubt your abilities. |
Quite a bold statement. I'm curious as to what your head temps look like. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Thu Oct 01, 2009 8:38 pm Post subject: |
maybe, but you obviously forgot to shift into 4th gear.....
SGKent wrote: |
_________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Oct 01, 2009 8:40 pm Post subject: |
[email protected] wrote: |
SGKent wrote: |
Maybe he sucks at building trannys? _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Thu Oct 01, 2009 8:41 pm Post subject: |
Doesn't matter how high over 4500 you rev it, how many miles or hours you drove it like that, it's still a ticking time bomb. Always will be unless 'properly' modified. |
SGKent Samba Member
Posted: Thu Oct 01, 2009 9:58 pm Post subject: |
there was also a question as to head temps.
The answer to the time bomb - any engine at that rpm can scatter. But ticking no. Not if you balance it. However the engine life is about 15,000 miles to 20,000 miles between rebuilds assuming you make 5 to 6 trips a year that way. Keep it to 60 - 65 and they last a lot longer. My last engine was dead stock because I got tired of cracked cases, pulled studs etc. Ask Jake on a T4 what he gets on the FP 914. He is probably turning up to 9,500+ rpm for 20 - 30 minutes at a time. He has to be because he is winning. We had to turn 8K - 9K in FP 25 years ago to bring home trophies so he has to be doing better today.
re head temps - stock dog house shroud, fan (balanced) and cooler but you are asking me to remember what the cyl head gauge was reading 30 years ago. My recollection was that it used to run about 350 - 375 on those runs. An extended oil sump was mandatory as oil temps would be unsustainable otherwise and I believe that I was using 50 wt oil.
I don't recommend driving a bus at that speed but I was 30ish and we would go river running on the weekends. Travel out Fri nite in the cool and back Sun nite in the cool. The original question was did he need a counter weighted crank to turn an occasional 5,000 rpm. My humble opinion stands as no. If he plans to turn 6,000+ on a T1 yes. Incidently - I set the redline on the new T4 1977 bus at 4500 rpm. Parts aren't available as easily or as cheaply as they were in the 70's and 80's. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Oct 01, 2009 10:15 pm Post subject: |
I havent been in the vw scene for a very long time but after doing research, i understood that a c/w balanced crank is the basis for all motors. Unless you are staying w/ a basically stock 1600, intend to use the parts you already have,watching a budget, and dont plan on getting into too much of a performance motor; than by all means use what you have. I personally only like to do things once. -Jon |
SGKent Samba Member
Posted: Thu Oct 01, 2009 10:34 pm Post subject: |
go get some old editions of hot VW or sandrail from the 1970's and 1980's. There were thousands of sand rails using stock cranks to play. Re-read his original post as to what he intends to do with it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Oct 02, 2009 7:33 am Post subject: |
To sum it up: yes you can use a stock crank, but if you'll be building an engine there's no good reason not to use a c/w crank. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
