1621 Samba Member
Posted: Fri Oct 09, 2009 11:28 pm Post subject: UHMW Tape: Slider Door Sound Mod + others |
Introduction
I inadvertantly stumbled upon a great product that has a lot of practical application both around the house and in our vans. Ultra High Molecular Weight PolyEthylene (UHMWPE) is a plastic with high abrasion resistance, low coefficient of friction, and is used in many commercial applications like conveyor belts, chute liners, chain guides, and basically anywhere a durable - wear reducing surface is needed. You can read more about it here:
http://www.crownplastics.com/
I decided to pick some of the adhesive backed tape from a local plastics shop and test out a few things. The following is what I found.
Slider Door
I bought a roll of UHMW tape (1.5" wide x 0.010" thick). I decided to try it along the glides on the slider door wherever there was metal to metal contact. I was successful in applying it along three different locations. First, and most obvious, was along the bottom of the slider where the roller runs in the channel just below the floor level. I simply used a simple spray-bottle degreaser to clean the area out well and applied the tape where the roller passes. Very easy to see where it travels as there is a distinct worn section of metal visible.
The next section was on the inside of the van above the door. Here I placed it along one side of the recessed channel, outboard side. The inboard side is not necessary as the roller guide generally does not make contact since the door's weight tends to keep it to the outside. Besides, I'm not certain both sides could be lined due to tight tolerances - more on that in a moment.
The third and final location I used this material was on the outside of the van under the panel that hides the exterior roller track. There is one primary roller that runs vertically along a narrow lip of steel. For this I merely trimmed a piece of UHMW tape lengthwise and then creased it along the middle. I then placed this folded piece over the narrow lip. I also tried fitting a piece in the channel just above this for the two smaller rollers, though I found this to be too tight for the material thickness I had, and thus scrapped that location as it impeded movement.
Once complete, I regreased all the rollers (not the surface of the tape) and tested everything out. I was very pleased with the new sound! It no longer has that "jet engine at takeoff" sound as a majority of the metal to metal contact has been eliminated. It rolls very smoothly as well. Overall the sound difference is significantly quieter and less "abrasive".
*As a side note, I do keep these areas well cleaned and greased at least twice a year, so it's not as if my baseline was a neglected nor abused track.
Upper Bunk
I decided I liked this material so much I would try it elsewhere. I wanted to eliminate the screech that comes from folding out the upper bunk and the resulting metal to metal contact at the hinges. I quickly unscrewed the hinges, laid down a couple pieces, trimmed with an Exacto knife, and screwed the hinges back down. Now the hinges operate totally noise free!
Drawer
The last location I tried this stuff was on the drawer glides. My drawer occasionally sticks, so I cut two pieces to adhere to the wooden drawer guides inside the cabinet. To make it even slicker I ran a very thin coat of petroleum jelly atop the UHMW tape. Now the drawer slides open almost too effortlessly. It's a good thing those catches are in place or I would have dropped the drawer a couple times while playing with it.
Seat tracks
I considered doing the seat tracks but decided against it. It looked to be too tight for the addition of the tape, and thus I abandoned the idea. Not certain if it would hinder track movement, I simply regreased the tracks and left them alone.
Overall impressions with the UHMW tape
Thus far I'm ecstatic over this stuff. I'll need to assess its performance over time, though I'm confident that if it's used extensively in the commercial environment, it will hold up well on my van. One thing to note is not all UHMW is UV stable. I believe only the black material is UV stable (not the stuff I have) though I'm not worried about my application as it's not in direct sunlight for any great lengths of time.
Also, if anyone comes up with other locations where this might be of benefit, please let me know and I'll test it out. I still have yards of the stuff left on the roll. BTW - the roll cost a whopping $14 at Power Plastics in NW Portland. _________________ '85 Westy |
TroySmith80 Samba Member
Joined: October 09, 2008 Posts: 272 Location: Bend, OR
Posted: Sat Oct 10, 2009 6:58 am Post subject: |
Good idea, i should do the same. Not too long ago I was at this pretty cool desert bonfire party / bluegrass jam thing, and everyone camped out. We had to leave early in the morning and i felt like a jerk every time i opened and closed the slider while everyone else was still asleep! Quiet is nice! _________________ 1984 Westfalia Wolfsburg - 2.5L Subaru - Sold - Preparing to move to the dark side (4x4 Ford van) |
motelvw Samba Member
Posted: Sat Oct 10, 2009 7:54 am Post subject: |
| Bus camp outs just wouldn't be the same without all those noisy sliders. I'll do mine anyway. It'll make the midnight pee run much quieter for my wife. |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Sat Oct 10, 2009 8:00 am Post subject: |
how did you buy it?
their site shows links to distributors,
but the distrubutors site doesn't list it. (the tape) _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
1621 Samba Member
Posted: Sat Oct 10, 2009 9:51 am Post subject: |
| 240Gordy wrote: |
how did you buy it?
but the distrubutors site doesn't list it. (the tape) |
I just called up one of the shops local to me and asked if they had any in stock. The first two didn't but said they could order it, the third had some on the shelf.
I'd call around to any of your local plastics shops. This isn't something unique to crown plastics, I just included the link for reference. Hell, I even found some on eBay. _________________ '85 Westy |
Vanagonner Samba Member
Joined: September 15, 2009 Posts: 506 Location: Broomfield Colorado
Posted: Sat Oct 10, 2009 10:26 am Post subject: |
In the U.S. the type of plastic is known under the brand name of "Spectra". It is used extensively in anti-ballistic armor, tow ropes, climbing ropes and a bunch of other apps. Thanks for the thread, I didn't know I could get it in tape. _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 786 Location: Langley, BC, Canada
Posted: Sat Oct 10, 2009 12:09 pm Post subject: |
| 240Gordy wrote: |
how did you buy it?
PlasticWorks in Surrey is probably the best bet around here. I don't know if they stock it, but they can get pretty much anything.
http://www.plasticworks.ca/catalog/index.php
If you call them post back here with the cost
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Sat Oct 10, 2009 1:21 pm Post subject: |
| 240Gordy wrote: |
how did you buy it?
Here is a supplier in Canada, but they ship to the US as well. (a very dangerous site for wood workers)
http://www.leevalley.com/wood/page.aspx?c=&p=32182&cat=1,110,43466 _________________ -- 1987 Westfalia automatic (Captain Vino) |
sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
buildyourown Samba Member
Posted: Sat Oct 10, 2009 6:05 pm Post subject: |
FYI,
McMaster-carr is a great place to get stuff like this. They will ship to anybody with a CC. |
BSS Samba Member
Joined: April 22, 2008 Posts: 4 Location: Gardnerville, NV
Posted: Sat Oct 10, 2009 6:40 pm Post subject: |
| UMHW (aka PTEX) is used for ski bases. |
Posted: Sun Oct 11, 2009 8:49 am Post subject: |
| sc-surfer wrote: |
D#*M you Perales.... Now I have to order a bunch of really cool carpentry stuff...
They have some things I have never seen before! |
Do yourself a favor and get them to send you their catalog, or view it online http://www.leevalley.com/Home/OnlineCatalogs.aspx?c=1 _________________ -- 1987 Westfalia automatic (Captain Vino) |
BCWesty Samba Member
Joined: September 06, 2008 Posts: 165 Location: victoria
Posted: Mon Oct 19, 2009 12:14 pm Post subject: |
| I picked up some of the UHMW tape at my local Lee Valley store and put it on the slider's for my side door. Still need to do the top track, but I'm very happy with the noise reduction. I plan on doing the drawer as well. thanks for the idea 1621 |
dumpling Samba Member
Posted: Sun Apr 04, 2010 12:33 am Post subject: |
Slider door was operable only going into the opening motions from a full linebacker crouch. Rotary tool wire brush, paint and UHMW tape on the rails and she's easy like Sunday morning.
1621, thanks! |
Posted: Sun May 16, 2010 10:37 am Post subject: |
Here is another great fix for the UHMW tape.
I have always had trouble getting the instrument cluster cover to come off. It has always been a bugger and I feel like it is going to break every time I remove it. I put some UHMW tape on the surface of the metal clips that hold the cover in place. It is now very easy to remove when I need to, but totally secure in place. _________________ -- 1987 Westfalia automatic (Captain Vino) |
vweggie Samba Member
Joined: May 01, 2007 Posts: 219 Location: End of the road, Vancouver Island
Posted: Sun May 16, 2010 11:13 am Post subject: |
UHMW! That brings back memories. I worked for a snowboard manufacturer in Vancouver from '93-'99. We used to buy miles of that stuff from Crown Plastics for our bases and topsheets. Extremely durable stuff.
If memory serves me right it's important to sand and flame treat the plastic (an ordinary propane torch will work) if you want to bond it to anything. Don't over do it on the flame treating, just enough to give it a haze but not melt it. _________________ 1990 Multivan 2.1 AT |
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Mon May 17, 2010 8:48 am Post subject: |
Has anyone tried using this on the sliding (read: screaming) window tracks? Or are they too tight, small and narrow for application? _________________ 1984 Westy with tencentlife power! |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Mon May 17, 2010 8:55 am Post subject: |
Try HDSD (HIgh Density Structural Vacuum) - handles loads and weighs nothing! (just joking)
I recently cleaned my slider door tracks and the bearing assemblies and was amazed at the difference. I'll have to look into the product - with age the lube grease does pick up dust and dirt! |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Thu May 20, 2010 11:02 pm Post subject: |
How about putting squares of this tape on the rear brake backing plates where the brake shoes ride on it, instead of grease.
Has anyone seen this stuff at a Home Depot or Lowes? _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
