johnanddes Satellite Wrangler
Joined: October 17, 2004 Posts: 692 Location: Orcutt CA
Posted: Wed Oct 20, 2010 2:44 pm Post subject: |
Dont know if you have a NAPA, but I just bought on of these distributors also. Here are their part numbers if your looking just to get the thing running and dont care about "genuine". I understand NOS is the best, but on a budget, all the stuff costs 19.24 excluding tax:
ECH EP150 (rotor) $4.88
ECH EP125 (Condenser) $ 2.39
ECH EP 149 (Cap) $7.88
ECh CS336 (Points) $4.09 _________________ John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk |
billfred1 Samba Member
Joined: May 19, 2014 Posts: 287 Location: Bloomington, IN
Posted: Sun Oct 19, 2014 12:09 pm Post subject: |
Anyone know if you can order a replacement drive dog for these?
Sorry to rehash the oldie. _________________ Bill
1966 Beetle |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Oct 19, 2014 2:56 pm Post subject: |
Better to reuse an oldie than to start a new thread just for a drive dog. PM me and I can send you one.
Let me guess that the one you had now has a broken ear? They are softer than the Bosch drives and I have broken a couple and have learn to be careful with them. _________________ Roads Scholar &
Posted: Sun Oct 19, 2014 3:07 pm Post subject: |
btw, when shopping for points watch for sets that have the phenalic washer included. It fits between the two parts of the points and some NOS sets do not have this washer. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Oct 19, 2014 4:51 pm Post subject: |
tasb wrote: |
Let me guess that the one you had now has a broken ear? They are softer than the Bosch drives and I have broken a couple and have learn to be careful with them. |
I actually was trying to drive the pin out to turn it 180. It had been working fine. I had to pull the engine for a bad main bearing. Put the engine back in and no spark from the coil to dizzy. Coil is getting power, everything shows the coil is OK. Not sure why all the sudden no spark. Points were opening and closing as they should, gap was good, points and condenser only have a few hundred miles on them. Not sure what was going on. The only thing that was different was the dizzy was clocked 180 from where it was before. I know this shouldn't matter, but I was trying anything.
I'll probably take you up on the drive dog. However, I'm considering just getting a new(er) dizzy since I can't figure out why I'm getting no spark all the sudden.
1966 Beetle |
Posted: Mon Oct 20, 2014 5:19 pm Post subject: |
Sometimes its a grounding issue with the distributor. The Garbe Lahmeyer distributor is pretty much fool proof in this regard however since the points plate is literally screwed to the distributor housing. Bosch units sometimes rely upon a ground strap that gets feeble over time.
The older mechanical advance cast iron distributors also have the common issue of the through bolt for the condenser grounding on the distributor housing. If you were moving things around it may have been bumped and is now grounding out your points. _________________ Roads Scholar &
LivinInnaVWBus Samba Member
Posted: Mon Dec 29, 2014 4:51 pm Post subject: |
johnanddes wrote: |
ECh CS336 (Points) $4.09 |
How did you find these part numbers? Under what year and model? The points are NLA through NAPA |
Posted: Mon Dec 29, 2014 10:03 pm Post subject: |
Look at the pic above... there are scads of these available both here on the Samba classifieds and on Ebay. _________________ Roads Scholar &
Posted: Mon Dec 29, 2014 10:08 pm Post subject: |
Just did a search under "points" and the first three ads were for the points you are looking for and the then 4 out the first ten ads. This was on 12/29/14. _________________ Roads Scholar &
