Variable intermittent windshield wipers?
Page: 1, 2, 3, 4, 5  Next
Rhinoculips
Rhinoculips is offline
PostPosted: Wed Oct 21, 2009 3:09 pm    Post subject: Variable intermittent windshield wipers? Reply with quote
Moderator pictures added Feb 20 2012
Can't seem to find any info on this. Is it possible to convert the intermittent wipers to variable intermittent?
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
Christopher Schimke
PostPosted: Wed Oct 21, 2009 3:23 pm    Post subject: Reply with quote
Yes!
http://s-cars.org/postnuke/downloads/pdf/Pro-Wiper_Relay.pdf
http://www.worldimpex.com/item_detail.html?sku=54591
syncrodoka
syncrodoka is offline
PostPosted: Wed Oct 21, 2009 4:24 pm    Post subject: Reply with quote
As loogy posted.
Passats have the relay with a .99 that replaces the .19 relay and it is programmable on the fly. Mine is VW part# 357 955 531. Good luck.
Rhinoculips
PostPosted: Wed Oct 21, 2009 5:59 pm    Post subject: Reply with quote
So its a simple plug and play relay? Then how do you control the timing of the wipers? Do you change out the stock with a Passat or install an aftermarket control dial on the dash?
Click to view image
syncrodoka
PostPosted: Wed Oct 21, 2009 6:05 pm    Post subject: Reply with quote
plug and play, nothing changed other than relay. Turn the stock wiper lever to intermittent(down) then off for time desired then back on and it sets itself. I use it all the time in light rain or heavy fog.
hiram6
hiram6 is offline
PostPosted: Wed Oct 21, 2009 6:07 pm    Post subject: Reply with quote
Pull the lever into the intermittent position, and, as the wiper does it's sweep, click back into the stop position, if you want a 3 second gap, then wait 3 seconds, and click back into the intermittent position. Bam, you just programmed a 3 second timing. There ya go.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
vanaguy
vanaguy is offline
PostPosted: Wed Oct 21, 2009 7:38 pm    Post subject: Reply with quote
syncrodoka wrote:
As loogy posted.
Lots of VWs have this relay, starting sometime in the early Golf era. If you've got a good boneyard nearby you might find a couple in a day of looking.
Rhinoculips
PostPosted: Wed Oct 21, 2009 7:44 pm    Post subject: Reply with quote
Many thanks for the replies! Sounds like it's one of the simplest "mods" one can do to a Vanagon. Can't wait.
Click to view image
syncrodoka
PostPosted: Wed Oct 21, 2009 8:07 pm    Post subject: Reply with quote
According to loogy's second link the Cabrio used it for 3 years, The Corrado 3 years, Golf and GTI for 4 years, and the passat for 8 years. If I find a passat I always look because they used it for so many years. It is also easier to get to the relays in a passat- just lazy I guess Smile. Good luck.
Rhinoculips
PostPosted: Wed Oct 21, 2009 8:17 pm    Post subject: Reply with quote
I just ordered it from Loogy's second link. A bit pricey, but the ability to set my wipers to my liking....priceless. Thanks again Sambanauts
Click to view image
syncrodoka
PostPosted: Wed Oct 21, 2009 8:22 pm    Post subject: Reply with quote
Not pricey really. The cheap online dealer that I like wants almost $50 for a OEM one. That should help you from any buyer's remorse. Very Happy
madspaniard
madspaniard is offline
PostPosted: Wed Oct 21, 2009 8:44 pm    Post subject: Reply with quote
very interesting, where is this relay located? fuse box?
syncrodoka
PostPosted: Wed Oct 21, 2009 8:48 pm    Post subject: Reply with quote
Yup.
vanaguy
vanaguy is offline
PostPosted: Wed Oct 21, 2009 9:58 pm    Post subject: Reply with quote
Keep in mind somebody may have upgraded this part in a VW that isn't on your list, and then junked the car. I've personally put the "99" relay into three Rabbits, two A1 Jettas, a Scirocco, and two Vanagons.
snowsyncro
snowsyncro is offline
PostPosted: Thu Oct 22, 2009 11:10 am    Post subject: Reply with quote
Eurovans have this too.
RonC
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Oct 22, 2009 11:18 am    Post subject: Reply with quote
Is this upgrade good for all model year Vanagons with intermittent wipers?
(bonus from my engine swap: 99 relay from donor Jetta!)
Neil.
1981 Westy, 15º ABA
1988 West, 50º ABA
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
syncrodoka
PostPosted: Thu Oct 22, 2009 2:41 pm    Post subject: Reply with quote
It worked fine in my '90, '91 and both of my '86 vanagons.
tclark
tclark is offline
PostPosted: Thu Oct 22, 2009 3:25 pm    Post subject: Reply with quote
Looks like someelse has done all this leg work
http://wiki.seloc.org/a/Wiper_Variable_intermittent
vw/audi old# 357 955 531A,
new vw 1HM 955 531B (yes the B is important) has 99 on top
vw (3B0955531 has 197 on top)
Kaehler(KAE) (3.200.110)
worldpac (W0133-1627097, really KAE part )
APS (25-955 531)
Bosch(0 986 335 058)
Beru(0 900 301 082),
Kostal (377 955 531) is Brazilian with a Motorola chip volvo#
Doduco
89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold)
syncrodoka
PostPosted: Thu Oct 22, 2009 5:44 pm    Post subject: Reply with quote
euro spec. cars are usually different- be careful.
Vanagon Nut
PostPosted: Thu Oct 22, 2009 6:50 pm    Post subject: Reply with quote
Thanks syncrodoka.
A quick look at Bentley shows '86 and '81 are similar. 53 *seems* different.
Off to the archives I go.
1981 Westy, 15º ABA
1988 West, 50º ABA
VE7TBN
Page 1 of 5
