Bart Dunn Samba Consiglieri
Joined: May 09, 2004 Posts: 2457 Location: Sea level (Mid Pacific)
Posted: Wed Oct 21, 2009 3:50 pm Post subject: 36hp Piston and Cylinder Sets -- country of origin/quality |
Any feedback on what's a good quality set? I've learned that CIP1 sells ones made in China, Wolfsburg West's kit has German cylinders and Chinese pistons, and Vintage Parts has a set made in China but "finished" here in the USA where they do the fine machining.
What other options are there?
Naturally, there are the German sets for more $$, which I assume are good quality, but I'm curious to know what others' experiences have been with those originating in whole or in part in the Far East, or elsewhere (Brazil? Denmark?).
I'm reluctant to put a Chinese heart in my German car, you know? _________________ Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan |
Eric Outland Samba Member
Posted: Wed Oct 21, 2009 6:18 pm Post subject: Eric (VMR) |
Cofaps=brazilian 36er's are decent! as You mentioned Kolben's are great, and worth the extra$$$ if you can afford them.
Then you can alway's purchase oversize Original German 36hp pistons and ring sets that are floating around and take original cylinder's and machine them out to size. Then there is also the re-ring O.G Pistons and hown out O.G cylinder's. still many option's to choose from. depending on your $$$situation! Cheer's  |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1119 Location: San Carlos, CA
Posted: Wed Oct 21, 2009 8:05 pm Post subject: |
Hello-
If you can afford to wait, I would keep an eye out for a German set. I spent quite a bit of money on mine, but they come up for sale every once in a while for ~ $300.
Paul _________________ My dog's vet has all my car money (http://sagecenters.com/) |
john morris Samba Member
Posted: Mon May 24, 2010 7:09 am Post subject: 36 HP Piston and Cylinder Sets |
Bump!
There have been some really positive comments posted lately about the 36 HP engine but this topic got little response. Is everyone re-using honed cylinders and good used pistons? Or is eveyone stepping up to something more exotic? How many of you have purchased new pistons? Any feedback is appreciated! Thanks! |
Posted: Mon May 24, 2010 7:54 am Post subject: |
I ended up with the Wolfsburg West set, german jugs with the Chinese pistons, which I had balanced, so hopefully it'll run nice & smooth. We shall soon see--just about ready to start building. _________________ Not enough car seats fit into my:
'58 Beetle sedan |
sgmalt46 Samba Member
Posted: Mon May 24, 2010 4:28 pm Post subject: |
the jugs are the important part. you should be good.  |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25689 Location: Central Iowa
Posted: Mon May 24, 2010 5:50 pm Post subject: |
Mahle bought Cofap in 2001. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
StockNazi Samba Member
Posted: Thu Aug 19, 2010 9:04 am Post subject: |
| Bart Dunn wrote: |
| I ended up with the Wolfsburg West set, german jugs with the Chinese pistons, which I had balanced, so hopefully it'll run nice & smooth. We shall soon see--just about ready to start building. |
these jugs are not nos are they? i'm betting there not _________________ WANTED:
westfalia privy tent poles (any condition)
58 westy cabinet knobs and latch hardware
sloper westy rack
36hp and 40hp NOS parts
splitcase transmission NOS parts |
Posted: Thu Aug 19, 2010 9:41 am Post subject: |
| StockNazi wrote: |
| Bart Dunn wrote: |
these jugs are not nos are they? i'm betting there not |
No, I don't think so--like I said, it was the off-the-shelf set from Wolfsburg West. _________________ Not enough car seats fit into my:
'58 Beetle sedan |
earthquake Samba Member
Joined: January 10, 2008 Posts: 2037 Location: LAS VEGAS, NEVADA "SIN CITY"
Posted: Sun Aug 22, 2010 4:08 pm Post subject: |
How good of quality are NPR pistons and cylinders? I have a old set of NOS 83mm big bore P&C's I'm thinking about selling in the classifieds.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
65 pan [I haven't decided what to do with it]
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Some where in Kenya, A village is missing its Idiot!
"If you put the federal government in charge of the Sahara Desert, there would be a shortage of sand in 5 years" |
1990coupequattro Samba Member
Posted: Sun Aug 22, 2010 4:38 pm Post subject: |
| How far out can the original 36hp cylinders safely be bored to? |
Mr. Okrasa  Samba Member
Joined: May 20, 2000 Posts: 304 Location: Newport Heights, Califa.
Posted: Mon Aug 23, 2010 10:31 am Post subject: |
| 1990coupequattro wrote: |
78mm. Anything over that is asking for trouble. How do I know this? Even VW made oversize pistons in 77.50 & 78mm. You can go bigger but you have to use different cylinders that will MAINTAIN the same cylinderwall thickness or thicker to prevent warpage from excessive heat. I've even seen someone use an 80mm piston from some unknown application fitted in an overbored VW 36hp cylinder!! You can see oil literally "pouring" out from the underside of engine while on idle!?!?
This is my 83.50mm big bore "HURRICANE" 36hp piston/cylinder assembly that im experimenting with. Note that the cylinderwall thickness is greater than that of a stock 77mm liner.
 _________________ 1950 Split Window 356 Coupe / #5369 / Adria Blue Metallic
1951 Split Window 356 Coupe / #10572 / Radium Green Metallic
1952 Split Window 356 Cabriolet / #10188 / Azure Blue
1959 Enzmann Spyder 506 #28
VW www.Okrasa.com
356 www.PreA356.com |
Posted: Tue Aug 24, 2010 3:04 pm Post subject: |
Are these for a 36 horse or a 1200 40 horse motor? they have 20mm pins.
I thought they were for a 40 horse but now I'm not sure.
69 DUNE BUGGY
Posted: Tue Aug 24, 2010 4:04 pm Post subject: |
| earthquake wrote: |
Casey |
40hp _________________ 1950 Split Window 356 Coupe / #5369 / Adria Blue Metallic
VW www.Okrasa.com
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 539 Location: Practitioner of 36hp alchemy
Posted: Tue Aug 24, 2010 7:25 pm Post subject: |
| Mr. Okrasa wrote: |
| earthquake wrote: |
Casey |
40hp |
I just used a set like that on a 36hp build I did a few weeks back. Machineing the case and heads is the easy part.........making the barrels fit is very labor intensive. Ran it over the weekend, sounds very healthy. Installed it in a car, but I'm waiting on a starter so I can torture test it. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1424 Location: Winter Park
Posted: Thu Dec 01, 2011 9:46 am Post subject: |
Are there any new thoughts on this topic? _________________ Jason
1958 Kombi |
Posted: Thu Dec 01, 2011 2:38 pm Post subject: |
I have about 3500 miles on my engine now. No complaints, but I would suspect that unless there is some GEXesque problem with the build any minor quality problems with parts will take longer to reveal themselves... _________________ Not enough car seats fit into my:
'58 Beetle sedan |
