SambaUser1M Samba Member
Joined: October 27, 2012 Posts: 135 Location: Irvine, CA
Posted: Sun Jul 20, 2014 9:23 pm Post subject: |
kermatt wrote: |
Pretty cool. Why has this thread died? I'll post pix here soon. I need wiring, fuel lines, doors, and a line for my hydraulic clutch...that's about what in down to |
Hydraulic clutch line is surprisingly easy to make and the tools are usually available for rental from parts stores like Autozone. You might even be able to pick up some premade lines at NAPA and join them together.
It sounds like we're at similar stages. Post pics of your clutch master mount and any details you can. |
kermatt Samba Member
Joined: February 11, 2012 Posts: 105 Location: Lakewood, Co
Posted: Mon Jul 21, 2014 6:02 pm Post subject: |
If you flip back thru this thread, you'll see pix of my clutch master and how i mounted it.
I think i decided to go with a badass aluminium shortened oil sump from Martin at www.bugat5speed.de They arent cheap, but it seems like a good investment. Its gonna cost around 450 and I'll have to make the shortened pick up tube, but it was that or one for a steel one around 300 from Outfront. _________________ 1970 GTV volksrod
Subaru EJ18 swap
Super beetle Z box trans
2.5" Drop
Ghia Rear torsions, short caps, adj spring plates
Front Disc brakes
E brake/turning brake mod
Custom apron w reverse opening hood
Custom Instrument cluster "Box"
Clear coat on bare metal! |
Posted: Tue Aug 26, 2014 2:02 am Post subject: |
My shortened, ALUMINUM oil pan is on the way from Germany, 475 bux with shipping, but really a nice unit. Bugat 5speed, Martin is the owner _________________ 1970 GTV volksrod
Subaru EJ18 swap
2.5" Drop
Front Disc brakes
thinksand Samba Member
Joined: February 01, 2010 Posts: 2 Location: gresham, or
Posted: Wed Oct 08, 2014 10:21 am Post subject: More pictures |
I am interested to see where your project is so far. Have you done anymore to it? |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Thu Oct 09, 2014 12:48 am Post subject: |
this is my swap. except for the ripped motor mounts and blown clutch it runs great!!! rear radiators and all.running megasquirt 3 subagears 5 speed.
_________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
Posted: Thu Oct 09, 2014 12:52 am Post subject: |
mini cooper radiators peeking out from the bottom. _________________ Never look down at anybody unless you are helping them up..
kooldub Samba Member
Posted: Wed Nov 12, 2014 4:42 pm Post subject: |
My project took a back seat to paintball seasin this summer, but i just recieved my fuse block and am starting the wiring process with my Haltech e6k ecu.
Oil pan is here-its awesome. does anyone have advice for adjusting the length on the oil pick up? I think I'll build a sleeve, cut a section from the tube, put a 5mm shim on the bottom of the pan, then mount the pan so it lifts the oil screen the 5mm. The sleeve should hold the tube in place once i remove the pan and check the tube.
Am i right? _________________ 1970 GTV volksrod
Subaru EJ18 swap
2.5" Drop
Front Disc brakes
ErikTande Samba Member
Joined: February 09, 2015 Posts: 156 Location: Denver, CO
Posted: Tue Feb 10, 2015 9:51 am Post subject: Re: Subaru-powered VWs wiki |
SambaUser1M wrote: |
Guys,
Just throwing this out there. You're welcome to flesh out this wiki I started building this afternoon. http://subies4dubs.wikidot.com/
I'm collecting everything I need for my build and waiting for parts at the moment. So while I'm researching the other items I need to buy, or things I need to do next, I'm collecting all the links and resources I've used over the last year and placing them in a wiki. I'm finding it a lot easier than trying to sort through my browser bookmarks. |
Wow thanks! This should be helpful when I'm ready to swap my engine out. _________________ http://www.youtube.com/velocitylabs |
Zvonimir1985 Samba Member
Joined: August 19, 2015 Posts: 135 Location: Zagreb, Croatia
Posted: Wed Mar 09, 2016 12:57 am Post subject: Re: Subaru Swap |
Hey guys!
Does anyone has exact measurements for engine mount holder to late bay? I would like to make my own but with theirs proportions.
Thank you!
P.S. Any advice for getting ej20 into bay is welcome! Especially with some good schemes. From what car did you take radiator and fan? _________________ Proud to be Croat! |
otakuphill Samba Member
Joined: June 24, 2015 Posts: 71 Location: Harbor City
Posted: Thu Nov 24, 2016 8:59 pm Post subject: Re: Subaru Swap |
I cant get the damn air out of the coolant system and running hot. any solutions?
Posted: Thu Nov 24, 2016 9:45 pm Post subject: Re: Subaru Swap |
Jack it up wherever your radiator cap is located and than run it for a bit while topping it off.make sure you have the bypass hooked up that normally goes to heater core also check your thermostat. May the force be with you! _________________ Never look down at anybody unless you are helping them up..
Posted: Sat Nov 26, 2016 6:12 pm Post subject: Re: Subaru Swap |
gprudenciop wrote: |
Jack it up wherever your radiator cap is located and than run it for a bit while topping it off.make sure you have the bypass hooked up that normally goes to heater core also check your thermostat. May the force be with you! |
Was able to get it working right by taking a expansion bottle from a Nissan at pick your part and connecting it to my heater lines above the engine. took just 20 min or so and a few on and offs to get all the air out. So glad no more overheating.
Finished product.
Posted: Sat Nov 26, 2016 6:14 pm Post subject: Re: Subaru Swap |
After driving for a for a few miles and coming to a stop it feels like one of the cylinders stops firing and it runs ruff when i hit the gas. Once i turn it off and back on it runs normally till i stop 3 or 4 times and then it does it again. Doesn't do it every time bbut every now and then. Any ideas? |
danielzink Samba Member
Joined: August 03, 2004 Posts: 282 Location: Lansing Michigan
Posted: Mon Nov 28, 2016 4:49 am Post subject: Re: Subaru Swap |
otakuphill wrote: |
Do you have a VSS installed ?
Have you pulled codes yet ? _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
www.danielzink.com |
Posted: Mon Nov 28, 2016 8:08 pm Post subject: Re: Subaru Swap |
danielzink wrote: |
otakuphill wrote: |
Have you pulled codes yet ? |
Turns out it was a cable. replaced and now it runs right. |
Posted: Mon Nov 28, 2016 8:13 pm Post subject: Re: Subaru Swap |
what radiator is everyone using? i have a civic 1.6l radiator and it runs a little warm. around 210-220ish. I think i should get a better one but not sure where i should get it from.
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Nov 29, 2016 2:09 am Post subject: Re: Subaru Swap |
Those radiators work well, you just need to enclose it properly so air goes through it not around and get more air flow to it, you havent opened up the apron so you are reliant on your fan which can only handle so much heat load. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Tue Nov 29, 2016 6:13 pm Post subject: Re: Subaru Swap |
now i have a issue that is causing the car to only rev as high as 4k rpm. i was having a idle issue and found one of my ignition cables was loose. after reconnecting it it idles and runs fine but it wont go past 4k rpm. I reset the ecu to no avail. Any ideas? |
Posted: Wed Nov 30, 2016 6:03 am Post subject: Re: Subaru Swap |
Subaru Powered Rail
1915 Rail
