turboedbug Samba Member
Joined: April 14, 2006 Posts: 235 Location: washington
Posted: Sat Nov 07, 2009 3:37 pm Post subject: |
Hey those cars look familiar, wheres the vid? _________________ 1969 type 1 rolling subie power
ej20k w/vf-22 roller bearing turbo
ems stinger 4424 engine management
wide 5 discs
soon to be subaru 5 speed! Got the reversed gears just need to find time to install |
Joel Samba Member
Joined: September 04, 2006 Posts: 8102 Location: NSW Australia
Posted: Wed Nov 11, 2009 3:07 am Post subject: |
| icecold wrote: |
WOW! thanks guys.
I decided im gonna go ahead and get the EJ20 DOHC Subaru Impreza Twin Turbo engine.
| turboedbug wrote: |
| I currently am doing a ej20t, got the adapter plate from outfront motorsports. when I bought my engine it was right around 850$ shipped to me from cali I am in washington. |
I dont see the adapter plate on there website. did u have to just call them for it? Maybe i will just swing by since its by my moms house lol. |
most of the people here doing the conversion convert the twin turbo engines to single turbo
singles are a better setup anyway and the RHS turbo on TT interferes with the startermotor |
jboxjohnny Samba Member
Joined: February 01, 2009 Posts: 38 Location: Cape Cod
Posted: Sat Nov 21, 2009 2:50 pm Post subject: |
Well, I've been playing around with my ECM and changed the turn on temps on one of my fans and it cools just fine with just one...
I am going to try turning up the temp on primary fan and see if I can get it to shut off while moving....
Then I can see if the natural moving air will do the work of the fan while on the move....
Such a difference with 1 fan off, much better.
I think I am going to have summer temp settings and winter temp settings, I like these ECMs..... |
essjayarr Samba Member
Posted: Wed Dec 02, 2009 4:31 pm Post subject: Stock vs non stock ECMs? |
Why aren't the factory ECMs not used with alot of the Subaru swaps I see here?
I've done a couple Vanagon/Subaru swaps and a couple Ford 5.0s into Volvos and have always used the factory ECMs, harness with all the factory sensors, etc.. Troubleshooting later on has always been so straight forward and no difference than the factory car it was born in.
What am I missing here? |
Posted: Wed Dec 02, 2009 4:52 pm Post subject: |
This was my first subaru swap, I thought about using the factory ecm but I wanted some versatility and some added HP....
I can tune the engine any way I want, something you cannot do I don't think with the factory ECM?
Also the stinger can be used in many applications useing the right program...
My 2001 sohc ej25 gets 165hp with the factory ECM.
With the Stinger ECM it gets 200hp...
Pretty much plug and play?
Posted: Wed Dec 02, 2009 8:14 pm Post subject: |
| I guess if "driveability" is as good as factory in all driving conditions, then for me, it would get some consideration. |
Posted: Thu Dec 03, 2009 3:16 pm Post subject: |
yeah I've had no problem with driveability so far, its been pretty cold here...
I had a few rough starts but called outfront and was told my idle was to low so made an adjustment and we will see as the winter goes on.... |
Joel Samba Member
Posted: Fri Dec 04, 2009 3:57 pm Post subject: |
the stock ECU works extremely well and has full self diagnostics
most people do use them
the down sides are yes u can extract alot more power with a aftermarket, the ECU, main loom and engine loom all need to match as they changed almost on a yearly basis and the wiring is unecessarily over complicated
i know mine has a good 70 or so wires running between the ECU and the engine
but running on a stock ECU means the engine will live alot longer and gives excellent economy
typically EJ22 like mine get the same city milage as a 1600 vw and way better highway mileage but do it with nearly triple the power of a stock 1600
i know from experience that a 150hp VW engine is not economical in the slighest especially in city traffic |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 748 Location: Midlife Crisis, Midwest
Posted: Sat Dec 05, 2009 4:25 am Post subject: |
I'm enjoying this thread and getting more interested in a swap. $850 for a delivered low milage Subaru engine is very appealing. Assuming a reasonable set of fabrication and mechanical skills, on average, how much will a guy get wrapped up in all the other items needed for a quality swap? At what points if any will there be the need for professional services? I'm not sure what all is involved in the tuning folks are refering to. Cold starts are a way of life here inthe midwest.... Thanks _________________ Gary
Being a cheap old fart is just a front for my actual lack of money.  |
Joel Samba Member
Posted: Sat Dec 05, 2009 2:25 pm Post subject: |
| gr8cobbler wrote: |
I'm enjoying this thread and getting more interested in a swap. $850 for a delivered low milage Subaru engine is very appealing. Assuming a reasonable set of fabrication and mechanical skills, on average, how much will a guy get wrapped up in all the other items needed for a quality swap? At what points if any will there be the need for professional services? I'm not sure what all is involved in the tuning folks are refering to. Cold starts are a way of life here inthe midwest.... Thanks |
the best advise i can give you or anyone considering the conversion is by a donor car
so many people have been done over by buying an engine by itself then having to source all the other parts after
the electrics and computer are different on almost every year
some later ones are map based while earlier are maf based
later engines have immobilors systems which wont run without the relevant hardware from the car etc etc
it works out better in so many ways
more often that not you can pick up a damaged or just run down but running subaru cheaper than an actual engine.
or by the time u paid for a cheap engine then source all the electrical etc parts its more than most donor cars
you also have everything there to make it run and you can actually see it run
you could be buying anything with an engine by itself that you cant see running |
Posted: Sun Dec 06, 2009 8:29 am Post subject: |
I found a complete 2001 2.5 rs for $1000 with 50k and ended up parting the rest of the car out and pretty much breaking even on the engine.
So I had some money in the buget and it went with the ecm.
I went back a forth on using the factory harness ect.
I ended up using the stinger $1500 with the harness.
I just plugged it in and away I went, literally.
From what i've seen you can go either way depending on your budget,skill,time ect.
Do the research it is out here.
I know I new nothing of this setup this time last year....
surfbeetle Samba Member
zeeuwvw Samba Member
Joined: October 06, 2008 Posts: 53 Location: Grand Rapids, MI
LUNATIK Samba Member
Joined: July 02, 2005 Posts: 308 Location: Lockeford, CA
Posted: Sun Jan 24, 2010 2:07 am Post subject: |
I hope this helps in making your mind about going Suby.
Here is my Bugaru... I am not an expert or a experienced builder but I liked the way this engine fitted in the car. I used a 2.5 SOCH, all that I had to do is drilling out the side covers and the front balance covers and the engine fit perfectly.
I'm using SDS system for fuel injection ECU . Fitting a T3/T4, the turbo still in mock up stage as you can see I haven't decided where to place the intercooler. Need to run the fuel lines and change the fuel lines at the intake... it is dangerous leaving those lines so close to the turbo...
This car is not going to be modified to fit the radiators.
Regards,
 _________________ You cannot fight with STUPID people; becasue you have to get down to their level and they will beat you up with experience.
| vwracerdave wrote: |
| Be careful what you brag about because it may bite your ass in the end. |
Posted: Sun Jan 24, 2010 10:59 am Post subject: Heater Core |
The heater core I used was from a friend, he had a Jeep project and was going to use it in that?
It was for a CJ5 not sure on the brand, I'll try to look for an Id on it...
later |
Posted: Sun Jan 24, 2010 10:59 am Post subject: |
| Nice radiators man where are they going? |
Posted: Sun Jan 24, 2010 11:17 am Post subject: |
| jboxjohnny wrote: |
I'm placing the radiators under the car, under the transmission on each side, there is a 3rd radiator that fit in the beam no fan I havent received it yet. I saw a picture once of a fellow that installed his Setrab oilcoler under the tranny... I liked the idea. The radiators are going to be jointed by a bridge higher than the radiators (above the tranny) to evacuate any air bubble into a catch can in the engine bay... I hope that it works.
Regards, _________________ You cannot fight with STUPID people; becasue you have to get down to their level and they will beat you up with experience.
Posted: Mon Jan 25, 2010 12:07 am Post subject: |
Lunatik, when you get the beam mounted rad, please put up some pixs. I'm very interested to see that. I too am doing the suby into a blue 67. Thanks _________________ 67 Bug
Build Thread: http://www.shoptalkforums.com/viewtopic.php?f=19&t=134735 |
Posted: Wed Feb 17, 2010 12:10 am Post subject: |
A small update... just got the EFI system finish, not running yet because I still bulding the exhaust... it will be easier not installing the turbo now but for sure that something that I have to decide very soon.
Installed 16x7 fuchs w/ 225's on the back with spacers just to see the look... now trying to fit those tires inside the fender I hope this car is sleeper enough...
Regards,
