Subaru Swap
Goto page 1, 2, 3 ... 10, 11, 12  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
icecold
icecold is offline
PostPosted: Thu Oct 22, 2009 10:33 pm    Post subject: Subaru Swap Reply with quote
I had a question I was thinking about an engine swap with a EJ20 DOHC Subaru Impreza Twin Turbo Engine from http://www.tigerjapanese.com and I was wondering if it would be a good idea to get it or one without the turbos which shows is more expensive without them. and would i have to get a different transmission or would my stock one in my 71 Super Beetle suffice?
Thank You Guys
Isaac
Inane Cathode
Inane Cathode is offline
PostPosted: Thu Oct 22, 2009 10:58 pm    Post subject: Reply with quote
What's up with that website? Theres no way those engines complete with turbos could be that cheap...
fastinradford
fastinradford is offline
PostPosted: Thu Oct 22, 2009 11:04 pm    Post subject: Reply with quote
you could use the stock transmission as long as you don't give it more than 1/2 in throttle.
95 jetta 5spd, (first waterpumper vw)
the nice 74 Ghia, (of course the fiance drives that one).
My mk1 jetta 1.6d
"It'd still be like my grandads old broom though, original, only 3 new heads and two new handles" -Marv [UK]
icecold
icecold is offline
PostPosted: Thu Oct 22, 2009 11:13 pm    Post subject: Reply with quote
what about one without a turbo?
turboedbug
turboedbug is offline
PostPosted: Fri Oct 23, 2009 2:17 pm    Post subject: Reply with quote
I currently am doing a ej20t, got the adapter plate from outfront motorsports. when I bought my engine it was right around 850$ shipped to me from cali I am in washington. everything was complete minus the ecu and intercooler. I say go with the turboed engine if you go with the one without a turbo and want more power your probaly going to spend more $ in the long run. You are definently going to want to look into getting a built trans. but hey you could wait on that till you get it running.
1969 type 1 rolling subie power
ej20k w/vf-22 roller bearing turbo
ems stinger 4424 engine management
wide 5 discs
soon to be subaru 5 speed! Got the reversed gears just need to find time to install
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
lostinbaja
lostinbaja is offline
PostPosted: Fri Oct 23, 2009 3:42 pm    Post subject: Reply with quote
Be aware it is far from a plug and play engine swap. Lots of fabrication to make it look, fit and function properly. Lot's of tuning.
Jerry...
If it's being towed, it must be a trailer!
The Southside Buggistas - Volkswagen & Kit Car Club
www.southsidebuggistas.com
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
icecold
icecold is offline
PostPosted: Fri Oct 23, 2009 9:58 pm    Post subject: Reply with quote
is there someone i can talk to to get the tuning just right for the swap?
turboedbug
PostPosted: Thu Oct 29, 2009 12:23 pm    Post subject: Reply with quote
call outfront motors they can answer alot of questions you have 714-994-5222
wide 5 discs
jboxjohnny
jboxjohnny is offline
PostPosted: Thu Oct 29, 2009 7:55 pm    Post subject: My 69 with an sohc ej25 Reply with quote
[IMG]http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01379.jpg[/IMG
jboxjohnny
PostPosted: Thu Oct 29, 2009 8:04 pm    Post subject: She Moves pretty good Reply with quote
Factory scirocco radiator...
with the summitt dual fans...
stinger from outfront!
plent of ground clearance with the 30 degree tranny adapter?
even some good heat for those chilly days using the orgional heater channels...
some guages to let me know what is going on...
Very happy with this vehicle , plenty of power (200hp) and very driveable....
Only 1 thing is using up this factory 091 clutch and probably needing a satge 1 or 2?
jboxjohnny
PostPosted: Thu Oct 29, 2009 8:08 pm    Post subject: Reply with quote
I need a spell checker? Laughing
turboedbug
PostPosted: Thu Oct 29, 2009 8:26 pm    Post subject: Reply with quote
Nice! Whats it like with 200 HP
wide 5 discs
jboxjohnny
PostPosted: Fri Oct 30, 2009 8:20 am    Post subject: Reply with quote
Thanks!
Freakin Sweet man!!
Nice and smooth and plenty of power...
No smelly heat, starts in the cold with no icing up...
Good on gas (haven't figured out the mileage)...
The stinger ecm is great, totally adjustable...
The only con is the electric fans I need to get more air flow to the radiators...
There is no problem with over heating the fans keep it around 180 deg but I would like the fans to shut off when driving artound town...
I am going to try installing an oil cooler to try to reduce the engine temps before I think about adding vents to the front area under the hood...
I have a scoop under there but I might need more air....
Have any pics of your ride?
turboedbug
PostPosted: Fri Oct 30, 2009 8:49 am    Post subject: Reply with quote
yeah I posted a few on here "subaru turbo in a bug" Most of my pics is in shoptalkforums.com in the conversion section under "got my ej20T"
wide 5 discs
lostinbaja
PostPosted: Fri Oct 30, 2009 10:27 am    Post subject: Reply with quote
The one thing OutFront Motorsports can't do, is tune the motor to where it starts easy and dependably when the outside temps get below 50 deg. or so.
Jerry...
RIP Morgan
My photos
jboxjohnny
PostPosted: Sat Oct 31, 2009 4:16 pm    Post subject: Reply with quote
I've heard that from a guy with a manxter at show...
So what dose it do when it gets that cold?
It hasen't been quite 50 hear yet but I'll keep an eye on it?
I asked Jeremy at outfront about this issue he said I shouldn't have a problem!
This was the conversation....
Hey Jeremy,
I have a couple of questions?
I talked to a guy at a show the other day aith a Manxter with an ej25 dohc with the ecm you guys recommended for my car, he said there is no cold start with the ecm?
Is that right?
And another question when i reversed my intake manifold I am assuming that I need to reverse my coil back around for the proper cylinder?
Do I need to change around my fuel rails as well or just install the corresponding injector plugs to the correct cylinder?
thanks john
There is cold start and also it can be wired to have idle control solenoid. If you reversed your intake just let us know when you order the wire harness and we can wire it accordingly. The injectors won’t matter.
Jeremy
Outfront Motorsports Inc.
8071 Commonwealth Ave.
Buena Park, CA
90621
714-994-5222
jboxjohnny
PostPosted: Sat Oct 31, 2009 4:18 pm    Post subject: Reply with quote
nice turboed bug!
looks good!
71-BEETLE-SEDAN
71-BEETLE-SEDAN is offline
PostPosted: Sat Oct 31, 2009 5:39 pm    Post subject: Reply with quote
Your gearbox should be fine but youll need a stronger one soon cause most turbo engines chew up gearboxes. Its been done heaps here in aus at the moment, good luck with it, make sure yo get a hortened sump and youll have to do a fair amount of work if you wanna save some money.
stasher1
stasher1 is offline
PostPosted: Sat Oct 31, 2009 5:43 pm    Post subject: Re: My 69 with an sohc ej25 Reply with quote
jboxjohnny wrote:
http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01365.jpg
http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01357.jpg
http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01380.jpg
http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01381.jpg
http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01388.jpg
http://i3.photobucket.com/albums/y82/carcatz/bug/DSC01389.jpg
Nice clean install, but the welds on the exhaust are hideous. Shocked
71-BEETLE-SEDAN
PostPosted: Sat Oct 31, 2009 9:17 pm    Post subject: Reply with quote
Looks like trying to weld stainless or a different grade steel to mild steel, will make it hard to runa good weld.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 1 of 12
