Rear Wheel Bearing Replacement - 74 Super Beetle
Page: Previous  1, 2
juki48
juki48 is offline
PostPosted: Wed Oct 02, 2013 9:49 am    Post subject: Reply with quote
what is the best way to get the outer bearing out?
Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx style buggy 1600 stock
beetlenut
beetlenut is offline
PostPosted: Wed Oct 02, 2013 10:17 am    Post subject: Reply with quote
Take a long punch or rod and insert it into the bearing area from the transmission side. Place the rod or punch against the outer circumference of the bearing housing and tap it out from the inside, moving the rod or punch to oppsite sides of the bearing housing on every other wack.
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
Tim Donahoe
Tim Donahoe is offline
PostPosted: Wed Oct 02, 2013 1:00 pm    Post subject: Reply with quote
dr geo, thanks for putting in new pics that work.
Tim
Blue69Baja
Blue69Baja is offline
PostPosted: Wed Oct 02, 2013 4:50 pm    Post subject: Reply with quote
Great pix's Drgeo!
In this pix you posted I notice no grease inside of the axle hub.
There needs to be grease in there! Couple of heaping tablespoons! did you put some grease in there?
Check your Bently for the exact spec..
If no grease in there the bearings can run dry when heated up. All vehicles need grease in this chamber, unless the bearings are sealed type.
Jim
69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original..
juki48
juki48 is offline
PostPosted: Wed Oct 02, 2013 4:52 pm    Post subject: Reply with quote
thanks, got them out. had to work around the bearing spacer in there but a few taps and they fell out. the inner bearings took quite a few more taps but came out fine.
Riley
Tim Donahoe
PostPosted: Thu Oct 03, 2013 5:07 pm    Post subject: Reply with quote
I did this job about thirty years ago and I remember having the hardest time pounding in the axel shaft after I changed the bearings. It took forever and made me never again want to change them out again. But I have a little play, and have to do it sooner or later.
Any tips on how to do this part of the job?
Tim
1970VWGUY
1970VWGUY is offline
PostPosted: Fri Oct 04, 2013 10:07 pm    Post subject: Reply with quote
http://www.vw-resource.com/rear_wheel_bearings.html
juki48
juki48 is offline
PostPosted: Sat Oct 05, 2013 10:45 am    Post subject: Reply with quote
Tim
I had this problem last night while doing my bearings. I used the old bearings as spacers and used the axle nut to pull the axle into the new bearings (brake drums off). I started with no spacers and as the axle pulled through the bearings I would take off the nut and add another old bearing or bearing race to the stack. to get started I had to remove the outer bearing cap/seal to get the nut on the threads. this worked great and did not require any hammering against the new bearings.
Riley
Tim Donahoe
PostPosted: Sat Oct 05, 2013 8:07 pm    Post subject: Reply with quote
Juki, sounds like a great idea.
Thanks!
Tim
Page: Previous  1, 2
Page 2 of 2
