nize Samba Member
Joined: June 21, 2004 Posts: 531 Location: Sweden - Cheesy town
Posted: Fri Nov 01, 2013 9:24 am Post subject: |
Continued my struggle with the 54 last night. The adjustable springplates are now mounted.
Tested the Porsche brakes again. Dont worry... the red paint will be gone soon
The rear is now more or less ready except that I need some mount for the shock in the rear. Anyone know if there are shock mounts that can be bolted on?
_________________ ----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
felix ehrhardt Samba Member
Posted: Fri Nov 01, 2013 1:54 pm Post subject: |
Wow very nice progress. What a transformation to the before state!
Ken made a very neat bolt on solution for the shock mounts:
Have you shortened the front nose cone grommet? I have read that when you cut the front grommet a bit the setup with the nose cone adapter dosen`t move 1/4 backwards. |
nize Samba Member
Posted: Fri Nov 01, 2013 3:01 pm Post subject: |
Wow! That is a really nice solution. I am gonna copy that. Regarding the nose cone grommet... I havent done any cuts. I am not sure what you mean... Might be that I am not that fluent in english _________________ ----------(VW)----------
1954 Kombi
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Sat Nov 02, 2013 1:36 am Post subject: |
nize wrote: |
Wow! That is a really nice solution. I am gonna copy that. Regarding the nose cone grommet... I havent done any cuts. I am not sure what you mean... Might be that I am not that fluent in english |
Superb thread - I have really enjoyed catching up with this one. Regarding the nose cone front donut 'grommet' trimming, if you buy a concept 1 bus nose cone kit for fitting a later tunnel box in your early bus (or split bug) it pushes the trans back 1/4" - see the ad here:
http://store.concept1.ca/store/product/56970/Bus-Nose-Cone-50-59-COMP./
You have bought the adaptor which doesn't have the same warning so it may not be an issue for you: http://store.concept1.ca/store/product/52550/C-1-T2-Nose-Cone-Adapter/
A solution to the pushing back of the trans by 1/4" is suggested for trimming back the donut here: http://www.thesamba.com/vw/forum/viewtopic.php?t=508346
Trevor P wrote: |
Go with the Concept 1 mount.
It doesn't move anything back if the front rubber mount is prepped right. I cut 1/4" off the front rubber mount and everything fits in stock position just like it should. I'm running a 2180 and a later trans in my BD and it has held up just fine. We have run these mounts in buses driving from Canada to Cali 2 times (and many more kms since) with no issues. |
I have subsequently bought Concept 1's nosecone kit and plan to trim my donut mount - I just haven't got to it yet.
Keep up the superb work and great updates
Cheers,
Dave |
Posted: Sun Nov 03, 2013 3:22 am Post subject: |
Hi Dave,
thank`s for the top info abut the donut. That makes everything clear!
nize wrote: |
Hey don`t worry, me too Go on! |
Kasten68 Samba Member
Joined: March 26, 2005 Posts: 136 Location: Switzerland
Posted: Tue Nov 05, 2013 7:37 am Post subject: |
_________________ VW über alles ! |
nize Samba Member
Posted: Wed Nov 06, 2013 4:42 am Post subject: |
Thanks for the pics of the rear shock mount... Really neat!
Another thing... I will start working on the front beam tomorrow. I realize that I need to raise the shock mounts in the front. What do you think about swapping shock mounts from a beetle front beam and weld it to the barndoor front beam?
How much do you in general need to raise the shock mounts on a barndoor frontbeam if you wanna go low? _________________ ----------(VW)----------
1954 Kombi
1967250s Samba Member
Posted: Wed Nov 06, 2013 11:05 am Post subject: |
Bus shock mounts are a lot stronger! Get shorter shocks........ |
nize Samba Member
Posted: Wed Nov 06, 2013 11:44 am Post subject: |
1967250s wrote: |
I don´t agree...
That might be the case for a later split bus but a barndoor has another beam. It is much more similar to a beetle beam. I went out to the garage and managed to find a beetle beam in the storage area I got.
The left one is the beetle beam and the right one the barndoor beam.
And a picture from the front...
I think this is going to be good... It will even look stock _________________ ----------(VW)----------
1954 Kombi
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Thu Nov 07, 2013 6:13 am Post subject: |
That looks like it'll work really well. _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
biscotte Samba Member
Posted: Thu Nov 07, 2013 2:26 pm Post subject: |
Hello thé Brown barndoor si my bus. Look on this blog http://blackhands.skynetblogs.be
New front and rear beam.
Sorry for my english! |
nize Samba Member
Posted: Fri Nov 08, 2013 8:44 am Post subject: |
Did my planned operation yesterday. First I cut the barndoor shock mounts.
Then I did the same on a beetle beam... And here is the finished beam. There is more to do on it as you see
Tried it on and it seems to work...
1954 Kombi
nize Samba Member
Posted: Fri Nov 29, 2013 4:28 am Post subject: |
Some more progress over the passed weeks...
Front beam is now in and everything fits. It was a bit worrying to mount it back after the amount of welding that has been done to the body but it seems ok.
Yesterday I hooked the beam up with some beetle spindles just to see how things line up.
I just had to try the CSP brake disc on...
And of course then a mock up with the rim choice!
1954 Kombi
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Fri Nov 29, 2013 10:09 am Post subject: |
awesome! i like the way you think _________________ regards
Uli
Dean Bradley Samba Member
Joined: November 10, 2004 Posts: 438 Location: United Kingdom
Posted: Sat Nov 30, 2013 12:13 pm Post subject: |
What a fantastic thread , I'm looking forward to seeing it rolling out of your garage....... _________________ The Original German Folks UK
The path of the Righteous is Never Smooth ..... |
nize Samba Member
Posted: Thu Dec 19, 2013 12:35 am Post subject: |
I need new link pins for my barndoor. Do you know if the set for 55-63 will fit or is there a barndoor version for sale somewhere?
http://www.csp-shop.com/cgi-bin/cshop2/front/shop_...0&all= _________________ ----------(VW)----------
1954 Kombi
nize Samba Member
Posted: Sat Dec 21, 2013 12:09 pm Post subject: |
Ok so this week I focused on getting on with the rear brakes. I got hold of a local company capable of gluing new brake material on the old brake parts and some brand new rear brake cylinders from Sierra Madre.
Here they are mounted on one side:
And after that I could mount the E-brake cables.
I still got the right side left to do. I had to do some adjustments to the length of the e-brake cable tube in the rear so it took some time but this is left side... almost done:
1954 Kombi
bally Samba Member
Posted: Sat Dec 21, 2013 12:43 pm Post subject: |
Looking good. Did you get an answer to the link pin question? If there is a difference what is it? I have some 20mm link pins and bearings at home. I knew they were pre 63 but don't know if they'll be any good for your bus or not... Cheers. Dave |
bally Samba Member
Posted: Sat Dec 21, 2013 12:46 pm Post subject: |
Duplicate post. Moderator please delete |
nize Samba Member
Posted: Sat Dec 21, 2013 3:44 pm Post subject: |
bally wrote: |
I thnk they are all the same since they are 20 mm untill 1963. I think I have found a couple of NOS ones that I need to buy. _________________ ----------(VW)----------
1954 Kombi
