Timing Marks
vanagon_fan_again
vanagon_fan_again is offline
PostPosted: Tue Oct 27, 2009 10:26 am    Post subject: Timing Marks Reply with quote
Im trying to get my vanagon on tdc, and i cannot figure out which timing mark it needs to be on and where the rotor should be. I see four holes on the crankshaft pully, would it be the very left hole, lined up to what?
And at what position should the rotor be? In-sync with the mark on it, or the 5/11 oclock positions?
Also, when cranking the engine over by hand, should i be turning clockwise or counter clockwise?
Ive read around alot and have heard both but from different years of motors.
-JENYVAN-
1989 Vanagon GL 2.1 Automatic. Metallic Blueeee.
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
vanagon_fan_again
PostPosted: Tue Oct 27, 2009 11:52 am    Post subject: Reply with quote
anyone?
sorry ive asked like the same question three times now, im just having a hard time understanding it. and im nervous about messing it up and causing more of a headache than i can handle.
-JENYVAN-
erdonline
erdonline is offline
PostPosted: Tue Oct 27, 2009 12:04 pm    Post subject: timing engine Reply with quote
Well, since no one has chimed in, I'll say what little I know about timing the 2.1 engine- I've never done it, and have been told pretty much not to worry about timing a 2.1 engine, because the Digifant system pretty much takes care of the timing, making quite a few adjustments in other areas to compensate for the timing being off. It seems that a lot of owners don't worry about timing their 2.1 very much, unless something has been done to throw it way off.
Ed in CT
'85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle
Zero419
Zero419 is offline
PostPosted: Tue Oct 27, 2009 12:21 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
1987 Westy Auto Bostig 2.0 Ztec
kshbaja
kshbaja is offline
PostPosted: Tue Oct 27, 2009 12:30 pm    Post subject: Reply with quote
Pull the valve cover and watch the rocker arms for #1 as you rotate the main pulley CW. I don't remember exactly, but I think when both valves are closed, if the intake valve opens with further rotation you just passed #1 TDC. When this happens back up to #1 TDC. There might be an easier way like watching the piston rise through the spark plug hole, but that is prone to being 180 degrees off.
In any event, when the engine is at #1 TDC, the rotor in the distributor should be pointing to about 4 oclock.
Take this with a grain of salt, its been months since I did this.
1986 Westfalia
vanagon_fan_again
PostPosted: Tue Oct 27, 2009 12:37 pm    Post subject: Reply with quote
thank you all- I'm about to go out and try again.
Just to clarify- Piston order standing behind the van, facing the front windshield would be- 3 top left, 1 top right, 4 bottom left, 2 bottom right.
Right? or...
-JENYVAN-
vanagon_fan_again
PostPosted: Tue Oct 27, 2009 12:48 pm    Post subject: Reply with quote
also- to my biggest questioning, What am i supposed to line up the marks on the crankshaft pully to? are these even used or relevant, or what? thanks agian-
-JENYVAN-
kshbaja
kshbaja is offline
PostPosted: Tue Oct 27, 2009 12:54 pm    Post subject: Reply with quote
First you get the distributor so it is close to TDC. Then, when you time it, the marks on the pulley will be lined up against the case seam. Don't recall the details of which mark is TDC and which mark is some number of degrees BTDC.
1986 Westfalia
vanagon_fan_again
PostPosted: Tue Oct 27, 2009 3:21 pm    Post subject: Reply with quote
I finally just decided to go do it. Im pretty sure #1 was on tdc, but didnt check specifically, just know that i put an extension in the cyl hole and it came out right at about 5o'clock on the rotor.
But im still not getting spark? i hope i didnt mess up and buy a distributor when i didnt actually need it.
I found two wires that were not connected at all. One goes down to right behind the crank pully, then goes up and meets with another that goes down between the driverside pushrod covers to some sensor.
Any ideas what these are and if they would keep it from running>?
-JENYVAN-
kshbaja
kshbaja is offline
PostPosted: Tue Oct 27, 2009 3:34 pm    Post subject: Reply with quote
Those are oil pressure sensor wires. They will not prevent it from starting. Look for the ProTraining Guide for the Digifant. It provides a step by step process to debug the ignition. I think DogPilot has it on a public server somewhere.
1986 Westfalia
vwmaniaman
vwmaniaman is offline
PostPosted: Tue Oct 27, 2009 5:41 pm    Post subject: Reply with quote
On my 86 the rounded notch it the tdc and the cut line is the timing mark for 5 atdc. That is set at the timing mark with a light when idling at the correct 850-900rpm. PorTraining manual will help explain all the things that can cause no spark. could be trigger coil or computer if it is an 86 and up. Ignition is in the computer for the fuel injection from 86 on.
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
vanagon_fan_again
PostPosted: Tue Oct 27, 2009 7:02 pm    Post subject: vanagon running-again Reply with quote
Got it running, im not really sure how as i didnt mess with timing it.
I put in the distributor with out any problems, was wayyy way easier than i had blown it up to be in my mind. Then i repaired and replugged the oil pressure sensors missing above, and took off and reconnected the diz cap from the coil, had my brother come out with me to help me test spark and it tried to run.. Put the two plugs in I had out in and it ran fine. Turned the idle up a bit(needed it before, just found out how while working on it) and took it for a test drive. Didnt seem to miss or give any problems. I do believe i need an altanator though, doesnt hold batt charge too well. Im going to have it tested tomorrow and see.
Thanks alot to everyone who replied in this, and my other thread, Really really appreciate the info. Next will be a Bentley and some fuel lines I think.
-JENYVAN-
