61 DD/WT build - Garry
Goto page Previous  1, 2, 3, 4  Next
zuggbug Premium Member
zuggbug is offline
PostPosted: Tue Jan 11, 2011 6:42 pm    Post subject: Reply with quote
Garry,
I did not know you had a DD - that bus is sick... I love it.
great story.
cant wait to take a ride - love the wheels....
paul
SOUTHERN INTEGRITY AIRCOOLERS
56 Kombi
72 Dormobile
58 15 window
Glenn A
Glenn A is offline
PostPosted: Tue Jun 28, 2011 9:18 am    Post subject: Reply with quote
Garry looks like you need to get back in the garage and get to work. Any updates.
mannys66 wrote:
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it.
65 walk through EzCamper
67single cab huge project
010 TDI sportwagen
And a stupid Baywindow.
GarryA
GarryA is offline
PostPosted: Tue Jun 28, 2011 9:50 am    Post subject: Reply with quote
I've been workin. Just keeping the progress to myself. Wink
Spending a lot of time with them "budder rolls" too.
Maybe I will post up some progress soon.
Good to hear from ya Glenn.
61DD W/T Turbo Build
Rats Nest 55 Oval
What to do while not working on a VW
Southern Integrity AirCoolers
Glenn A
Glenn A is offline
PostPosted: Tue Jun 28, 2011 10:09 am    Post subject: Reply with quote
That is a very nice bus you have there. I can wait to see at a show.
010 TDI sportwagen
zuggbug is offline
PostPosted: Tue Jun 28, 2011 2:27 pm    Post subject: Reply with quote
x2
56 Kombi
72 Dormobile
58 15 window
scvw
scvw is offline
PostPosted: Tue Jun 28, 2011 3:54 pm    Post subject: Reply with quote
zuggbug wrote:
x2
Drag Night?
53 Oval
57 PG/SG standard
WTB - (2) Lemmerz 15" beetle wheels date stamped 3/53
WTB - PG/SG OG paint rims, SG block off plate, AS-1 Sigla vent wing glass
VW tools
http://www.thesamba.com/vw/classifieds/detail.php?id=478847
http://www.thesamba.com/vw/classifieds/detail.php?id=522550
Glenn A
Glenn A is offline
PostPosted: Tue Jun 28, 2011 4:12 pm    Post subject: Reply with quote
scvw wrote:
zuggbug wrote:
x2
Drag Night?
Way to Throw down the gauntlet Joey!
010 TDI sportwagen
bill may
bill may is offline
PostPosted: Wed Jun 29, 2011 8:20 am    Post subject: Reply with quote
i hope you are talking about the drag strip, and not the full moon when the trans-sexuals come out. Shocked
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
tlambert
tlambert is offline
PostPosted: Wed Jun 29, 2011 8:28 pm    Post subject: Reply with quote
What??????
Glenn A
Glenn A is offline
PostPosted: Thu Jun 30, 2011 3:21 am    Post subject: Reply with quote
What??????
Hah. Long story Tim. You know fast talking New Yorkers are just to much for Garry. Laughing
010 TDI sportwagen
tlambert
tlambert is offline
PostPosted: Thu Jun 30, 2011 8:20 pm    Post subject: Reply with quote
Now I remember, just not sure what you said that made him think that.
GarryA
GarryA is offline
PostPosted: Tue Jul 26, 2011 5:35 pm    Post subject: Reply with quote
A few updates.
Rear bumper mounted with hidden trailer hitch.
Engine lid was borrowed from another project car.
Only exhaust visible is the small pea shooter to right of hitch. Patina-ed pea shooter is from a 74 SunBug.
It should not give away what is really under the lid.
Rusty swap meet rear apron trimmed and fitted. Fuel lines worked out.
Wires and vacuum lines will be routed on back side of motor next time the engine comes out.
Looks like a rats nest in this pic but it is actually coming together and everything is finding its place.
A view from under the bumper.
Left side with coil mount. Wires snaked up behind spare tire bucket.
Right side with fuel pressure regulator, additional fuse block, battery cut off switch.
Bracket made for the motor electronics to be mounted out of sight inside the spare tire.
Regretfully had to cut a hole in my uncut no-rust bus.
I cut the hole only on the flat area so that reversing the hack can be easily done.
Picked up some body side molding yesterday that will protect the wires from the edge of the cut metal.
View of behind the bumper. I have made a middle splash shield to cover the center section.
A couple of shots of the hitch/bumper mounts. Splash pans fit nicely too.
It is tacked together right now in case I find out I need to move something. The center receiver section is held in by magnet but it is marked for final welding. I had to have the motor back in to make sure the headers cleared the receiver.
Bumper/hitch/splash pans all come off together with four bolts. Well, four major bolts plus the ones that hold the splash to the body corners.
Back side of apron had to be clearenced for the turbo. This area will need insulation. Bottom lip was removed as well because it hit the headers.
Oil filer mounted with existing frame holes - factory bumper mount holes.
Oil filter mount. Upside down in pic.
Oil cooler mounted to bottom of frame in front of trans. No holes made in the bus to mount it there. I used only existing holes for the rear and in the front used a bar similar to a traction bar set up with two small bars over the top of the frame rails. Long bolts hold the to bars to the frame. The cooler bolts to tabs on the cross bars. This was the only place I could think of to mount the cooler on a bus with IRS conversion and belly pans. It really does not hang down that low. But I may put some kind of road kill cattle catcher on the front mount to divert any debris.
Waiting on some more parts to arrive to hook up the breather hoses and clamps to hold oil lines in place. UPS delivered one Summit order and another coming tomorrow. Motor has to come back out to fab up a bracket for the breather box, route breather hoses from back of valve covers through tin, hide all the wires on the bulkhead in front of the motor, and put in a second accelerator cable tube for the cruise control.
I have done more work in other areas of the bus as well.
Rats Nest 55 Oval
Andy P
Andy P is offline
PostPosted: Tue Jul 26, 2011 6:28 pm    Post subject: Reply with quote
Top work, mate.
Gotta love a sleeper. Smile
Cheers & God Bless
'62 Beetle
'62 Panel project
'67 Panel
'98 T4 EV Transporter LWB
Jägdwagen - Busse Vom Australis
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed Jul 27, 2011 5:31 am    Post subject: Reply with quote
Nice work!
Mike K
Bulli Klinik
Colorado Springs
http://www.bulliklinik.com/
zuggbug is offline
PostPosted: Wed Jul 27, 2011 5:36 am    Post subject: Reply with quote
Shocked man you are good...
56 Kombi
72 Dormobile
58 15 window
GarryA
GarryA is offline
PostPosted: Wed Jul 27, 2011 5:45 am    Post subject: Reply with quote
Check your email Paul.
Have you ever seen a DD W/T turbo Dormy?
Rats Nest 55 Oval
peecee69 Premium Member
peecee69 is offline
PostPosted: Wed Jul 27, 2011 9:02 am    Post subject: Reply with quote
That is sweet looking. I'd love to see more pictures of that hidden hitch setup!
View user's profile Send private message AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
GarryA
GarryA is offline
PostPosted: Wed Jul 27, 2011 9:24 am    Post subject: Reply with quote
The bumper needs to come back off for full welding. I think I have all that properly fitted and clearing. I can take more pics when I pull it back off.
Rats Nest 55 Oval
Major Woody
Samba Enigma
Major Woody is online now
PostPosted: Wed Jul 27, 2011 11:18 am    Post subject: Reply with quote
I really like the way you did that hitch!
GarryA
GarryA is offline
PostPosted: Wed Jul 27, 2011 6:00 pm    Post subject: Reply with quote
I thought some might like my hitch set up. I have to give credit to Jeremy. He has an ad here for split hitches. I talked to him and he agreed to sell me the bumper mount pieces. He sells the complete hitch but I was not sure it would clear the turbo and wanted to make a custom fit. His design works great. Splash pans and bumper bolt up. Makes it easy to pull hitch and bumper off as one unit.
Rats Nest 55 Oval
Page 3 of 4
