how to suicide doors ?
olson1955
olson1955 is offline
PostPosted: Wed Nov 11, 2009 6:59 pm    Post subject: how to suicide doors ? Reply with quote
iam wanting to suicide my doors on my 66 bug
is there a dvd, vhs, magazin, thread, or something that does step by step?
any info will be appreciated! Thansk!
when i say suicide doors i mean like this
www.myspace.com/vwcody to see pics of my 66 Bug Project
anemol
anemol is offline
PostPosted: Sun Nov 15, 2009 6:03 pm    Post subject: suicide doors Reply with quote
I know this isnt exactly what you want but at least its a start and may contain some information you may want or need.
http://www.thesamba.com/vw/forum/viewtopic.php?t=210613
I did a search and came up with this.
Burl
joeysbuggy
joeysbuggy is offline
PostPosted: Sun Nov 15, 2009 6:47 pm    Post subject: Reply with quote
theres some good info on volksrod website about it
olson1955
PostPosted: Sat Nov 21, 2009 5:45 pm    Post subject: Reply with quote
i've tried volksrod and tried the search functions on this and didnt come up with what i wanted.. lmao
is there a dvd or magazine a can buy that shows steps?
i wanna use the stock hinges but probably use a bear claw latch!
let me know.. Thanks!!
Foxx
Uncle Meat
Foxx is offline
PostPosted: Sat Nov 21, 2009 7:09 pm    Post subject: Reply with quote
take this as i meen it,
but most that do that kind of mod have the ability to fab or modify the mounts themselves.
your just gonna have to get a lot of ideas and pick something
that you can handle.
if you need your hand held, then this sort of mod may not be for you, most are hand built and home made designed.
Frank
OG JHC
65 T34 Ghia
59 panel
Sarcasm is the body's natural defense against stupidity.
5 years later,.. my Red door panels look great!
hazetguy
hazetguy is offline
PostPosted: Sat Nov 21, 2009 7:23 pm    Post subject: Reply with quote
you could do this:
Parts and mechanical restoration services available. Check my ads or send a PM.
" just because YOUR hobby is another's profession, it doesn't mean that a shop works for free. " -Don
02fly
02fly is offline
PostPosted: Thu Dec 03, 2009 6:18 pm    Post subject: Reply with quote
Go to your local hot rod shop they have really easy kits that are used to shave hinges on the old cars. you would be amazed with all the stuff that cross over from early hot rods to custom VW stuff drop me a line if you need help.
Don
rgambord
rgambord is offline
PostPosted: Thu Dec 03, 2009 10:51 pm    Post subject: Reply with quote
hazetguy wrote:
you could do this:
I'd have to kill you. Twisted Evil Just going to throw out a suggestion: Why don't you try going to a junkyard, and see if you can find a door: with a lock, and the hinge. That way you can try playing around a bit, and not worry about damaging your car. Just 2 cents.
stevenpetry
stevenpetry is offline
PostPosted: Tue Dec 29, 2009 12:24 pm    Post subject: Reply with quote
http://www.thehoffmangroup.com/autoloc/suicideconfigure.lasso?step=hinges
The kit i used is the "better" kit.
A few leasons learned:
If you ride already has a good paint job, get ready to repaint.
Found tacking the doors to the body after making a few cuts helps to get everything in the right place.
Mount the hinges as far forward and out as possible. This will reduce any metal in the door wheather strip channel from being removed.
Get good latches. Bear claw minis are worth every penny. And get the mounting kit.
Mount the latch up near the where the top factory hinge was. Got to move mine up cuz the top of the door wants open up at high speeds.
Measure twice, cut once. No, wait, make that three...no four times.
You can try using the factory exterior handles, but have fun with that. Save yourself some time and go keyless. I don't have door handle inside or out. Funny as hell watching people try to figure out how to get out.
And locktite the hell out of the screws in the plates once you get everything nailed down.
Other than that, take your time, and have a beer. The finished result is nice and getting in and out is way easier now.
