type 4
moss
moss is offline
PostPosted: Tue Nov 17, 2009 1:53 am    Post subject: type 4 Reply with quote
Thinking of putting a type 4 engine in a rail question which cooling system to go for Porsche or a type 1
danfromsyr
danfromsyr is offline
PostPosted: Tue Nov 17, 2009 12:56 pm    Post subject: Reply with quote
I do't see why you couldn't use the T-IV system. it's quite sufficient and if the Alt belt breaks it'll still cool the engine.
Dna in NY.
T-IV stock config in a baja.
Abscate wrote:
baja72
baja72 is offline
PostPosted: Tue Nov 17, 2009 1:11 pm    Post subject: Reply with quote
If space is an issue, you could extend the rear section of your rail. That would be alot cheaper than converting to upright.
DWP
DWP is offline
PostPosted: Tue Nov 17, 2009 1:36 pm    Post subject: Reply with quote
I'm in the process of putting a porsche 1.7 into a sandrail.
Several things to consider.
The cooling will make the engine longer than the upright style. I.m not sure but 6" I think. Because of this I have to fab the rear cage for the extra length.
Word of advise, do not weld the rear of the cage until you have the engine and exhaust in place.
The exhaust is another problem. I took an exhaust from a 411 and removed the outer casing.
Dave
fusername
fusername is offline
PostPosted: Tue Nov 17, 2009 4:29 pm    Post subject: Reply with quote
http://www.europeanmotorworks.com/mm5/merchant.mvc...-4-exhaust
works w/ stock cooling, doesn't work with single carb
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
mtnroads
mtnroads is offline
PostPosted: Tue Nov 17, 2009 6:49 pm    Post subject: Reply with quote
I've had good luck with the stock type 4 cooling. But it is longer and lower and will decrease your exit angle.
love the power though...
if there was no cost involved I would convert to T-1 cooling.
pax
No Good Deed Goes Unpunished....
moss
moss is offline
PostPosted: Tue Nov 17, 2009 11:17 pm    Post subject: Reply with quote
I have reasons for not liking the T4 fan it’s long and heavy, its low down sucking in dirt and just a bit ugly.
The Porsche fan looks nice but again with the fan at the back will suck in mud and dirt. TheT1 type fan I thought is a bit more out of the way. So I think I’ve answered my own question
