69 Beetle On pan restoration project
ryohey
ryohey is offline
PostPosted: Tue May 24, 2011 5:45 pm    Post subject: Reply with quote
I started working on the rear end area of the bug. took the A-arms off to paint. Took the stub axle and bearings out going to give it all some new grease. here are some pics mostly before pics. will update when everything is put back together. Also just got my urethane bushing today for the A-arms
69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight=
ryohey
ryohey is offline
PostPosted: Sun Jun 05, 2011 12:26 pm    Post subject: Reply with quote
Some updated pic of the progress so far. Took the rear end apart to paint and grease everything. Had no problems. took the stub axle out and bearings cleaned up everything. New Polyurethane bushings in the pivot arms. I only got the passenger side pretty much buttoned up. Still need to hook up the brake cylinder and put the shoes back on. here are the pics
ryohey
ryohey is offline
PostPosted: Mon Jul 11, 2011 6:50 am    Post subject: Reply with quote
Well after countless months, days and hours of thinking about it, I am electing to take the body off the pan to take it to the painter. If I knew I was going to do this when I started the project, it would have made things easier on myself, none the less, it is what it is. Here are a few pics of the body dolly I made out of 2x4's got done with it yesterday.
Today took all the bolts out holding the body on.
I will take some pics when I get the body on it
ryohey
ryohey is offline
PostPosted: Sun Jul 24, 2011 7:17 pm    Post subject: Reply with quote
well got the body off and on the dolly. It sits a little high, I will have to take about 8 inches or so off so it sits a little lower. Today I used kbs rust stop on the bottom under the package tray turned out nice will post some pics of that tomorrow. here are the pic of the body on the dolly
ryohey
ryohey is offline
PostPosted: Fri Sep 02, 2011 8:12 pm    Post subject: Reply with quote
Waiting to take the body for paint. here are a few pics of the pan I laid down some Fat Mat turned out nice. Installed new clutch cable, refurbished the pedal assembly, used the new ultimate clutch pedal shaft featured here http://www.thesamba.com/vw/classifieds/detail.php?id=1087010 nice smooth feel. Hooked up the battery and got the engine started. Started right up and ran nice.
69vduber
69vduber is offline
PostPosted: Sat Oct 22, 2011 3:44 pm    Post subject: Reply with quote
When you took the A arms off did you need to do anything with the torsions? or just unblot the plates ?
ryohey
ryohey is offline
PostPosted: Sat Oct 22, 2011 4:29 pm    Post subject: Reply with quote
I removed the outer cv joint first then unbolted from the spring. If you are taking it completly out. You will have to unhook the ebrake cable at the ebrake handle and push down on the arm. Then take out the 17mm pivot bolt. You only need to remove the torsion spring if you decide to lower it,which I did. PM me if you need more info. Its not difficult.
69vduber
69vduber is offline
PostPosted: Sun Oct 23, 2011 7:41 am    Post subject: Reply with quote
Thanks , I'm at about the same point as you except your frame is done, but my body work has been done. Still need to get it to paint .. I just would like to take the A arms off and replace bushings etc. and paint , Was not sure of teh Torsion plates ... Frame looks great.
ryohey
ryohey is offline
PostPosted: Sun Oct 23, 2011 8:35 am    Post subject: Reply with quote
Thanks, the body will have to wait for next year.
millerje78
Samba Amishman
millerje78 is offline
PostPosted: Tue Nov 01, 2011 7:19 pm    Post subject: Reply with quote
great find! looks like the body is in very fine shape. Can't wait to see it finished!
always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry
19-VW-74
19-VW-74 is offline
PostPosted: Mon Jan 09, 2012 10:19 pm    Post subject: Reply with quote
He bro, got any updates for us?
This is lookin' good Cool
-Austin
My 1974 Standard Beetle Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=492617
ryohey
ryohey is offline
PostPosted: Mon Jan 09, 2012 10:38 pm    Post subject: Reply with quote
No real updates right now, still chiggin away. Just hot done stipping tims from engine for powder coating, so when thats done ill get a pic up
ryohey
ryohey is offline
PostPosted: Sat Feb 04, 2012 5:59 am    Post subject: Reply with quote
A little update. took the cooling tins off the engine for powder coating, getting done in satin black. Going to have to clean the engine up some, might have a push rod tube leaking we will see after it clean it up. took the fenders and some of the little parts to the painter, he doesnt want the the body yet, that will be next. here are some before pics of the engine tins and engine will post again when it is back together. Also will be installing rebuilt SVDA dizzy.
ryohey
ryohey is offline
PostPosted: Mon Feb 20, 2012 6:17 pm    Post subject: Reply with quote
Well got my tins back, I think they turned out real nice. here are the pics. Still have to get some things done that I forgot to take.
69 Jim
69 Jim is offline
PostPosted: Tue Feb 21, 2012 9:36 am    Post subject: Reply with quote
Excellent work. Cool
ryohey
ryohey is offline
PostPosted: Tue Feb 21, 2012 3:29 pm    Post subject: Reply with quote
Thanks Jim its a slow go, but I am getting there.
ryohey
ryohey is offline
PostPosted: Fri Mar 30, 2012 5:33 am    Post subject: Reply with quote
quick update: got the freshly powder coated cooling tins on along with the new distributor on. Im in the process of restoring the heat exchangers and muffler. I used a wire wheel on the 4.5 inch grinder. going to get some ospho and dupont new ford grey paint. Ill get a pic of them when that is done. Here are some pics of the engine with the cooling tins on. And I do plan on moving the fuel filter.
ryohey
ryohey is offline
PostPosted: Sat Mar 31, 2012 11:44 am    Post subject: Reply with quote
ok got one heat exchanger wire brushed, primed and painted here is what it looks like. dupont high heat w/ceramic
before
after
Rust2Rods
Rust2Rods is offline
PostPosted: Sun Apr 08, 2012 6:01 pm    Post subject: Reply with quote
Lookin' good! Keep up the great work!
Double69project
Double69project is offline
PostPosted: Sat Apr 21, 2012 7:26 am    Post subject: Reply with quote
nice build i will be watching this one
If you don't have time to do it right the first time, you must have time to do it over.
Page 2 of 5
