Retrovan Samba Member
Joined: July 15, 2011 Posts: 524 Location: Port Elisabeth - RSA
Posted: Thu Oct 06, 2011 5:12 am Post subject: Need new Weber carbs, any contacts please.. |
Hi All,
Have me a 2000cc type 4 bus motor that I want to fit a Weber kit too.
But all the guys on Google, seem to have closed down.....
Carbs direct, Carbs.net, no reply...
what I need is a quote for a Weber Carb Kit K1412 (dual 34ict) with out filters, as well as a full set of all correction jets to enable the carb to be set for a VW type 4 2000cc motor
Shipping by lowcost surface mail.
Can you help Please.....
Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76910 Location: Sneaking up behind you
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Oct 06, 2011 5:56 am Post subject: |
www.aircooled.net
John says he'll give you free advice and/or setup the new carburetors for your engine. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Thu Oct 06, 2011 7:29 am Post subject: |
I got all my jets, gaskets, and such from Pierce Manifolds in Gilroy, CA. They've always had everything I needed. _________________ 69 Fastback Build
Berg5 Build |
Posted: Thu Oct 06, 2011 10:15 am Post subject: |
Thanks guys,
Finally got hold of Aircooled.net
Maybe someone gave them a heads up ?/
Had a problem communicating that I needed a extra set of jets, to fine tune the carbs once I got them.
Problem was , as I did not know what jets come with the carb, how do I order the set up and down.
They finally came back and told me to order two sets of jets, but to mention in the special order conditions, that I wanted up and down jets, they will work out which jets to include.
SO WE have it worked out.
Now I can order my carb set WITH jets....
Thanks again for your help.
Posted: Thu Oct 06, 2011 10:20 am Post subject: |
we are in the US, we were sleeping while you were sending your e-mails. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3564 Location: viroqua wi.
Posted: Thu Oct 06, 2011 11:00 am Post subject: |
Who recommended dual 34's for a 2000 cc engine? 2 liters should be able to run at least dual 40's |
Posted: Sat Oct 08, 2011 8:46 am Post subject: |
bsairhead wrote: |
Car running at Sea level, not a racer, but only a cruiser......
With the right jets, and venturi s (throttle body's), it will be fine.....
I am sure John will set up my new carbs just fine,
If [email protected] is happy with the duel 34 ict's then that's fine by me.....
Posted: Sat Oct 08, 2011 9:17 am Post subject: |
IDFs are far better (dual 40s). The extra $ spent is wise here, IDFs are superior in so many areas over any dual 1bbls, including ICTs. _________________ It's just advice, do whatever you want with it!
