dopedemon69 Samba Member
Joined: September 12, 2010 Posts: 11 Location: tehachapi california
Posted: Wed Sep 09, 2015 8:20 pm Post subject: |
Haha I love that movie. I'm going to go to harbor freight I know they have hellacoils. It's always I new lesson with this car most of them pricey thank you for your help Tim |
motoguzzi13 Samba Member
Posted: Sat May 07, 2016 12:29 pm Post subject: Re: The dreaded bolt |
stevearnold wrote: |
I have a 67 bus and the drivers side upper bolt was always giving me reason to shout profanities...as my bolt was loose and had nuts on each side...the transmission side was easy to reach but the engine side was behind the air shroud with little room to maneuver...if I could just weld that engine side bolt into place I would solve my problems...but I had a brainstorm and sliced an access panel between the support beams above and had easy access..found the three nuts I had dropped and now am grateful that my engine is properly mounted with all four bolts. |
thanks! I had just built a 1600 that had only 3 bolts and half the tin missing and the thermostat system. I found all the tin and thermostat put the engine in and could not reach that bolt. I cut a access panel took maybe 10 minutes and had clear access to put on the nut and tighten, i made a cover plate screwed it on with silcone and its all good, I am all about putting the car together the way it was designed. its kinda of arrogant some of these guys think they know more than the man who designed the car |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun May 08, 2016 6:28 am Post subject: Re: Driver side upper engine mounting bolt |
way to go 'Michigander'
stock Nazi's are gonna frown
Welkome and check out www.thegoodvolks.com _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Zundfolge1432 Samba Member
Posted: Sun May 08, 2016 8:13 am Post subject: Re: Driver side upper engine mounting bolt |
Entered in error
Last edited by Zundfolge1432 on Sat Feb 17, 2018 9:58 am; edited 1 time in total |
Posted: Sun May 08, 2016 8:14 am Post subject: Re: Driver side upper engine mounting bolt |
enteredin error
Last edited by Zundfolge1432 on Sat Feb 17, 2018 9:59 am; edited 1 time in total |
Posted: Sun May 08, 2016 8:16 am Post subject: Re: Driver side upper engine mounting bolt |
entered In error
Last edited by Zundfolge1432 on Sat Feb 17, 2018 10:00 am; edited 1 time in total |
Posted: Sun May 08, 2016 8:18 am Post subject: Re: Driver side upper engine mounting bolt |
enetered in error
Posted: Sun May 08, 2016 8:20 am Post subject: Re: Driver side upper engine mounting bolt |
eneteredin error
Last edited by Zundfolge1432 on Sat Feb 17, 2018 10:01 am; edited 1 time in total |
Posted: Sun May 08, 2016 8:25 am Post subject: Re: Driver side upper engine mounting bolt |
Entered in error
Last edited by Zundfolge1432 on Sat Feb 17, 2018 10:02 am; edited 2 times in total |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sun May 08, 2016 8:28 am Post subject: Re: Driver side upper engine mounting bolt |
Exactly as above.
Actually, I've R&R'd an engine that had a nut at that location with a doghouse cooler/shroud, and was pretty straightforward. And when that press-insert is there, a 17mm socket and some long extensions from underneath made this simple too.
No, I would NOT run with just 3 connected, just like I would not run with just 3 lug bolts ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun May 08, 2016 11:23 am Post subject: Re: Driver side upper engine mounting bolt |
cleaned up to avoid confusion and not germain to original question.
Last edited by Zundfolge1432 on Sat Feb 17, 2018 10:03 am; edited 1 time in total |
Raymond73 Samba Member
Posted: Fri Feb 16, 2018 6:40 pm Post subject: Re: Driver side upper engine mounting bolt |
Okay, just toying with an idea here.
I'm upgrading to a dog house fan shroud and the upper left engine bolt is on my list of things to tackle. I haven't ruled out the press-in nut as that seems the most secure method, but I'm worried about messing that up if not aligned correctly with my hand drill.
I am not entertaining the option of running only three bolts, as many have pointed out, it was designed for four.
This made me think that most of the forces being applied are torsional along the middle of the transmission and engine. If this is true, a stud from either the bell housing or the engine would limit any travel in either a clock-wise or counter clock-wise direction. I'm thinking that possibly using three bolts and one stud would be sufficient.
Since I don't think I can weld onto either material, would something like a quick release pin of sufficient length, diameter, and shear strength be a suitable replacement?
I found what I think is something that might be up to the task. I would appreciate your feedback and thoughts.
https://www.fastenal.com/products/details/0958165
_________________ '70 Auto Stick Beetle
113 905 205AD
30 PICT-3 |
Cusser Samba Member
Posted: Fri Feb 16, 2018 8:48 pm Post subject: Re: Driver side upper engine mounting bolt |
I say: get the correct captive nut insert, just install it, should be straightforward.
Or just use pre-1971 bolt and nut, and install the two little doghouse tins after the engine has been installed. I've done that, and it WAS straightforward. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sat Feb 17, 2018 2:38 am Post subject: Re: Driver side upper engine mounting bolt |
Raymond73 wrote: |
I'm thinking that possibly using three bolts and one stud would be sufficient. |
Two of the original engine fasteners are already studs. But they're threaded studs.
Wait, are we even considering having this discussion right now??
www.airschooled.com |
Posted: Sat Feb 17, 2018 5:40 am Post subject: Re: Driver side upper engine mounting bolt |
Cusser wrote: |
Or just use pre-1971 bolt and nut, and install the two little doghouse tins after the engine has been installed. I've done that, and it WAS straightforward. |
I agree the captive nut is the most ideal. Cracking the flange or drilling the hole incorrectly were negative results that I was weighing against. You know, the point of no return.
I honestly didn't consider the option of installing the tins after the engine was put back in. I was thinking that I would need to seal those tins with aluminum tape and that there wasn't enough space to access everything after the engine was in.
Thanks for additional info, Cusser. _________________ '70 Auto Stick Beetle
113 905 205AD
30 PICT-3
Posted: Sat Feb 17, 2018 5:58 am Post subject: Re: Driver side upper engine mounting bolt |
asiab3 wrote: |
Raymond73 wrote: |
Robbie |
Yes, we are having a discussion. This is what a forum is supposed to be: Individuals discussing the merits (or lack thereof) of an idea. To this point no actions have been taken. Surely you would agree that it is better to think through something first and then act.
Unfortunately the quote you extracted doesn't examine how I came to that possibility and paints my whole thought experiment (at least to the casual observer) with a bias that I am honestly championing this as a superior alternative to the captive nut. I'm not, by the way. I think I prefaced my post in such a way to outline this.
Maybe you are an expert in the mechanical properties and forces involved. Maybe you have already discussed this topic to death, ad nauseam. That's cool. I don't claim to know everything. I am comfortable admitting my ignorance in something. If it's a terrible idea please tell me why. _________________ '70 Auto Stick Beetle
113 905 205AD
30 PICT-3 |
Cusser Samba Member
Posted: Sat Feb 17, 2018 8:47 am Post subject: Re: Driver side upper engine mounting bolt |
Raymond73 wrote: |
Thanks for additional info, Cusser. |
I believe that one of those hidden tins has a 6mm hex head screw holding it (10mm wrench), the other has a 6mm nut (10mm wrench). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Feb 17, 2018 9:44 am Post subject: Re: Driver side upper engine mounting bolt |
Cusser wrote: |
I believe that one of those hidden tins has a 6mm hex head screw holding it (10mm wrench), the other has a 6mm nut (10mm wrench). |
Ahh, yes. I took a look at the EMPI tins, There are matching studs on the shroud. Hmm, it might be possible. I'm still not sure about accessing them with my vacuum control valve in the way. It's hard to visualize how much space will be in front of the new shroud and offset cooler with the engine still sitting on the floor.
However, this definitely opens up the possibilities of leaving the four standard bolts without going the press-in nut route or the quick release pin. I just might have to enlist my daughter's help (small arms!)
Thanks again, Cusser. _________________ '70 Auto Stick Beetle
113 905 205AD
30 PICT-3 |
Posted: Fri Jun 22, 2018 3:01 pm Post subject: Re: Driver side upper engine mounting bolt |
An update to my thought experiment.
One thing I didn't consider in the press-in insert/pin is how soft the case material actually is. I'm in the process of installing the doghouse oil cooler after much delay (translation:laziness). Since the studs for my offset cooler are slightly larger than the non-offset type, drilling was required. Completely do-able, which gives me more to ponder.
Sure what follows is not the scientific method, but I'm cool with that considering my limited resources. The pin, even with a close fit, is still much harder than the surrounding material. Without sufficient clamping force it's free to move and there's a definite possibility of enlarging the hole /cracking the flange after enough time. How much time it would take, I'm not sure. It might take days to decades depending on factors such as engine tune, driving style, etc.
Thinking back to my original..., well, thought, is a quick release pin and three bolts likely to cause more damage than just running with three bolts or are they equally bad, but just in different ways? Even with the softness of the material I still end up trying to think in percentages of effectiveness. If each of the four bolts provide equal clamping force and torsional resistance each bolt position is required to contribute a minimum of 25% of the load to max out at shared 100%. Dividing that requirement for 25% in half for each bolt hole position (12.5% each for clamping and torsional) that would mean that 3 bolts is 75% effective compared to 4 unmolested bolts (100%), and 3 bolts+example quick-release pin is 87.5% (i.e quick release pin lacks the clamping %).
Another thought is how much drilling and pressing damage the surrounding flange? Probably very little if done correctly. Still, to be fair, maybe half a percentage can be deducted compared to the original 100%. So, as a guesstimate for 4 bolts w/one press-in insert might be 99.5%.
To summarize assuming proper torque, no bolt/nut metal fatigue, crossed threads, etc:
75% for three bolts
87.5% for three bolts and example quick-release pin
99.5% for four bolts using press-in nut
100% for the original four bolts
If my crude thought experiment can be taken with a grain of salt, there are two distinct winners of the four options. Additionally, factoring in the theoretical damage the quick-release pin might cause, I'm comfortable in thinking that it would degrade in effectiveness over time. Eventually it would reduce from 87.5% down to 75% to equal only having three bolts.
One clear unknown to me is at what percentage (under 100%) does it fail to provide sufficient clamping force /torsional resistance to keep the engine and transmission happy? If it's 90% then it's clearly a bad idea to choose the first two options. If it's 80% then the third option is adequate, but probably not sustainable over time. If it's 70% then all options are viable.
However, considering that equal distribution is better than not, maybe the first option really isn't 75% effective after all. It's possibly less so I'm surmising that 75-80% is the minimum adequate clamping/torsional effectiveness required to stay operating. My rudimentary thinking is that the engineers chose 4 bolt equal distribution rather than 3, 5, or 6 for a reason. Losing a single bolt in the 3-configuration would result in 66% effectiveness, in the current 4-configuration 75%, in the 5-configuration it's 80%, and in the 6 configuration it's 83%. Overcompensating as the numbers increase. My 75-80% is based purely on economy as the 3-bolt option would likely be woefully inadequate during a failure. the 5 and more bolt options provide way more security, (most likely unnecessary considering the humble nature of the Beetle) but requiring more engineering and parts.
All that aside I realize that, yes there are four bolts and they are clearly better. If there were three bolts and a stud/hole then maybe the quick release pin given as an example would have more merit. For a theoretical example, drilling a broken stud and inserting a pin in its place.
Disclaimer: If you read this far, but missed my initial post in this thread, I'm neither championing the idea of running three bolts alone or relying on the pin. However, I still think that if the need arose, the quick release pin still seems to be adequate as a temporary measure to get you home.
If I missed something in my reasoning please don't hesitate to contribute. _________________ '70 Auto Stick Beetle
113 905 205AD
30 PICT-3 |
Cusser Samba Member
Posted: Fri Jun 22, 2018 3:56 pm Post subject: Re: Driver side upper engine mounting bolt |
If I understand your post, you're reluctant to use a long bolt and the press-in threaded insert for the left upper mount.
Guess what?? You can use a regular bolt and nut there, and then just install the two small doghouse tins after that. I've done that on someone else's engine, not tough. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
