FrankRam Samba Member
Posted: Thu Dec 17, 2009 5:10 pm Post subject: |
Just a couple of lights for Christmas |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 878 Location: Lanark County, Ontario, Canada
Posted: Fri Dec 18, 2009 10:54 am Post subject: |
Beautiful car! Reminds me of Fjiord Blue. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Fri Dec 18, 2009 11:17 am Post subject: |
Thanks, It's the color that was original from the factory, Horizon Blue.
Real similar. |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Fri Dec 02, 2016 8:13 am Post subject: Re: Back up speedometer switch help for reverse light |
Just installed one of those "ambulance" part number NOS back-up switches (between the speedo and cable end) on my freshly restored '59 Double-Cab, and yes, you have to have vehicle movement in reverse for several feet before the switch can illuminate the reverse light assembly.
The "hooded" Hella reverse light assembly can be seen on the left side of the rear bumper blade. Works as an accessory basically the same on a Type 1, 2 or 3.
Same thing to turn it off!!! You must move forward several feet for the light to turn off again. If you just back-up and stop and fail to move forward, the back-up light will remain on. Cool vintage accessory, but you need to be aware of it's quirks. I have another set of ambulance switch and hooded light to install on my upcoming '57 Kabriolett restoration
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Fri Dec 02, 2016 9:15 am Post subject: Re: Back up speedometer switch help for reverse light |
When I back up into the garage I enjoy getting out and seeing it still on. i believe it does go out with the key. Still works great. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
stale air Samba Member
Joined: August 23, 2007 Posts: 5151 Location: Senoia Ga, formally NorCal
Posted: Fri Dec 02, 2016 10:44 am Post subject: Re: Back up speedometer switch help for reverse light |
EverettB wrote: |
When I have had one on the past, I hook it up to keyed power to make sure it turns off when I remove the key. |
That's how mine is hooked up as well. _________________ WANTED: Henry Veale Santa Rosa plate frames
