name that tune!
dana
dana is offline
PostPosted: Fri Aug 08, 2003 4:18 pm    Post subject: name that tune! Reply with quote
alright, i discovered a new sound the other day near my left rear wheel. minor metal on metal rubbing on a certain spot on the wheel rotation. no problem i thought, i went and spent my 50 bucks on inner and outer wheel bearings, tore it all apart, put the new bearings in , bled the brakes and test drove. same damn noise. it will not do it if i turn left though. takes the pressure off it. i repacked the cv joints a couple of months ago and they seemed pretty good. anything i could be missing guys??? thanks for the advice.
nodtobob
nodtobob is offline
PostPosted: Fri Aug 08, 2003 5:51 pm    Post subject: Reply with quote
Did you adjust your brakes at all? That could be making a noise, if the brakes are loose in there. good luck anthony
slow down!
Cook911411
Cook911411 is offline
PostPosted: Fri Aug 08, 2003 6:00 pm    Post subject: Reply with quote
I currently have the same problem ....... hmmmm
Chris
74 Transporter
dana
dana is offline
PostPosted: Fri Aug 08, 2003 6:08 pm    Post subject: Reply with quote
i just got in the house. i think my brake drum may be scraping my backing plate in one spot. weird. anyway my brakes are making an awful grinding noise now after putting them back on and bleeding. sounds like when you dont drive for a while then you have that surface rust on the rotors and drums. could my shoes just be a little dirty?? and does anyone know an easy way or trick to removing those damn brake drums?
NuggJugg
NuggJugg is offline
PostPosted: Fri Aug 08, 2003 6:36 pm    Post subject: Reply with quote
I don't know what year you have, but my 71 has 2 bolts that you undo to take the drum off of the back wheels.
My Shows:
http://db.etree.org/nugg_jugg
1971 Westfalia
1975 Beetle
1990 Jetta GL 5 speed manual 190,000 miles and still smokes!
Bajatacoma
Bajatacoma is offline
PostPosted: Fri Aug 08, 2003 7:05 pm    Post subject: Reply with quote
If you damaged the backing plate, it can rub against the drum. My first guess would be to check the leading edge of the drum/backing plate. CVs usually make more of a chattering or popping noise when they are going bad.
'78 Westy
Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?
Hunter S Thompson
nodtobob
nodtobob is offline
PostPosted: Fri Aug 08, 2003 8:57 pm    Post subject: Reply with quote
If you adjust them out they will make a sound against the drums until you wear them even again. Make sure that the adjusters have the clip holding them in place or they will back themselves out or in, and make sure they move freely so you can adjust them. Something could be loose in there like the e-brake cable and it can rub if you were in there recently and didn't put things back in there proper place. good luck anthony
slow down!
jeremysmithatshawdotca
jeremysmithatshawdotca is offline
PostPosted: Sat Aug 09, 2003 2:05 pm    Post subject: Reply with quote
The drums usually come off fairly easily, once you take the two bolts off, then you can get a really good look at the inner workings and see what's up. Jeremy
