robin.richard Samba Member
Joined: February 17, 2012 Posts: 493 Location: V. Beach VA
Posted: Thu Apr 10, 2014 4:59 pm Post subject: |
OK,
Here are a few photos of where I'm at with this task. Needed to replace oil seal on passenger side.
Brake drum removed. Brake cylinder was blown out. I guess I was running on three brakes since I returned from deployment. Notice left side brake pad?!
Bake parts removed.
Bearing cover finally removed.
Stuck spacer, oil seal pulled off.
Now, how do I remove the spacer.? I tried a little heat but no luck. I have also tried PB Blaster, no luck. What tool can you use to get a good grip on this to remove it?
-Rich |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Thu Apr 10, 2014 5:09 pm Post subject: |
A small puller would do it, but I think you can unbolt the backing plate, pull the e-brake cable out, and it should ?? come off over the spacer, then you could tap the spacer from the backside out. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Thu Apr 10, 2014 5:21 pm Post subject: |
Do you have any recommendations to keep from marring the spacer? I' m sure that's important so the oil seal does it's job.
-Rich |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Thu Apr 10, 2014 7:20 pm Post subject: |
robin.richard wrote: |
-Rich |
The seal coming off the cover is common. Heat up the spacer all the way around with a propane torch even though it seems like it's not doing anything. What it does is makes the ring a smidgen larger. Pull off the backing plate. Now take a long drift from angled behind an the left and right and hit on the slinger part of the spacer. You can file any dings later. Turn the stub axle and drift-hit such that you go back and forth. |
Posted: Sat Apr 12, 2014 8:55 am Post subject: |
OK, I got it all apart and cleaned, reassembled but now I'm not sure of the torque for the four 14mm bolts on the carrier. In this thread it says 43 foot lbs. I thought I had read somewhere it was less.
Can someone confirm before I install the drum. Thanks.
-Rich |
EverettB Administrator
Joined: April 11, 2000 Posts: 69804 Location: Phoenix Metro
Posted: Sat Apr 12, 2014 9:16 am Post subject: |
Everett,
THANKS! I also believe I now know why that seal was leaking. A PO or shop installed the large O seal and the carrier does not have a channel for it. It is a large axle trans with oil slinger spacer combo.
-Rich |
BarryL Samba Member
Posted: Sat Apr 12, 2014 6:58 pm Post subject: |
Glad you got it but what ended up working for you?
In this picture your following brake shoe looks seriously thin. Is it or is it an optical illusion?
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2206 Location: UK (South)
Posted: Thu Oct 16, 2014 5:10 am Post subject: |
Hi
I'm about to order the parts to replace the seals on one of my hubs.
I've a couple of questions
Firstly, I can get kits with or without the spacer. The price differential is significant (kits with the spacer are four or five times the price of those without). Should I get the more expensive kit with the spacer, or is it uncommon for them to be the cause of the problem?
I've edited the rest of my post, because I've found a cutaway image of a brake drum that I think answers my question, but to double check...
Is there any need to torque the hub nut straight away after replacing the bearing seals? Does doing so compress the gaskets in any way? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Thu Oct 16, 2014 7:31 am Post subject: |
If your spacer is in bad shape it is a good idea to replace it. No way to tell its condition until disassembly.
Axle nut needs to be torqued down before filling with gear oil, or the seal will leak. If you aren't going to refill it right away, then you need not torque it right away. But don't forget to do it. _________________ nothing |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Fri Oct 17, 2014 4:23 am Post subject: |
Who.Me? wrote: |
Hi
You can get kits with the big nut rgb slinger spacer?
I thought those were not available new.
Details please! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Fri Oct 17, 2014 5:43 am Post subject: |
Interesting - the kit I was looking at (from VW Heritage here in the UK) is listed as 'out of stock', but I figured that just that they'd run out. The item also says 'not currently available', so I just rang them and they confirmed that they cannot get them anymore.
This was the kit with the spacer...
https://www.vwheritage.com/shop/311598051S/hub-seal-kit-with-outer-spacer-rear-axle/#esp_pg=2
So that makes the decision for me - I'll have to go for one of the kits without.
Thanks
Andy |
DencherD Samba Member
Joined: December 16, 2011 Posts: 43 Location: Sonora Ca.
Posted: Sun Feb 15, 2015 10:16 am Post subject: rear bearing cap or retainer |
Can anyone point me in the right direction to find some 64 -67 rear bearing caps,someone said they could help but that I need the factory part number.For a big nut transmission . Thanks DencherD |
BarryL Samba Member
Posted: Sun Feb 15, 2015 6:56 pm Post subject: Re: rear bearing cap or retainer |
DencherD wrote: |
I need the factory part number.For a big nut transmission . |
211 501 311 B
The cover usually only has a "11" stamped and a VW emblem with a "B" up by the spring holder. |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Mon Feb 16, 2015 5:16 pm Post subject: |
Here's how I did this recently on my '66 big nut:
Remove the wheel and drum and disconnect the parking brake cable. The Bentley says you have to unhook it up front to remove the backing plate but that's not true, it pops right off at the lever inside the drum.
Pull the cable and hide it out of the way, it's a slip fit in the backing plate.
Remove the clip from the brake hose and loosen it from it's mount:
Remove the one bolt from the RGB holding the brake line retainer:
Unbolt the 4 bolts from the seal retainer and remove it and the backing plate. Hook the backing plate on the torsion housing using a S hook from a bungee cord. It's not necessary to disconnect the brake hydraulic line. It's necessary to remove the backing plate because oil can/will seep between the BP and the RGB housing mimicking a seal leak.
I used WW seal kits but most of it I don't use, only the seal, small o-ring, and cotter pin. The rest of the stuff is for Type 1s.
Drive the old seal out using a punch.
Clean the housing thoroughly, I bead blast and then brake clean and air. It's sitting next to the old seal.
I put a thin coat of Toyota FIPG on the inner surface where the seal seats, this is a high quality RTV. You may want to use your preferred brand. Being that this is a rubber coated seal this might be overkill, if it's a metal ringed seal this is important.
Set the seal in place, "lip to the lube". That means don't put the bastard in backwards.
Either push it in with a vise, which is what I did, or
Knock it in with a hammer. Either way, use an appropriate driver. Yes, you can sometimes cheat and use a big socket if you have one, but a seal driver kit is cheap and everyone should have one. HF sells them.
Push it in until it seats on the bottom. There's a channel for leakage to run out if it seeps, note the hole is clean.
Clean all surfaces of old sealer, rust, gunk, and whatever. I use a gasket whizzer on the backing plate, but a wire wheel in a drill should work.
Don't use a gasket whizzer on the RGB flange because you'll get abrasive from the disc into the bearing, use only a razor blade or scraper there.
That means both sides of the backing plate, axle flange and seal housing.
Dry everything with brake clean and air.
Cleanliness is critical, no oil film or anything is allowed here because RTV won't stick to an oily surface. Use brake clean on a rag to remove oil film, lacquer thinner or ether will also work. My RGBs were empty and freshly rebuilt, pull your RGB drain plugs if your have oil in them, and let drain until they're really empty and dry.
Put a thin film of FIPG or your favorite RTV on all of the flanges.
I keep studs around for lining shit up, it makes things easy, these are just bolts with the heads cut off. Put a couple of alignment studs in, set the backing plate over the studs and put the seal housing in place using two bolts. The drain hole in the seal housing goes down to line up with the drain hole in the backing plate.
Remove the studs, torque to 43.
Make sure the spacer is perfect- no rot, rust, or pitting, otherwise it will eat the seal.
You have to lube the seal and where the o-ring goes.
You can't tell, but it's wet with lube and there's chassis grease on the surface of the spacer. There's a chamfer on the back of the spacer where the o-ring sits to prevent gear oil from leaking along the axle shaft.
Push it home and reinstall the park cable.
Make sure the drain hole is clear.
Put the brake line, clip and bolt back in.
Don't forget to fill the RGB's!
Notes- the outer bearing outer race is slip fit in the RGB, not press fit. The inner race is an interference fit on the axle stub. The spacer (what the seal rides on) is slip fit. If it's stuck remove the backing plate so you have better access and get a bearing race remover (split style with 2 long bolts) with some adapters/puller/ingenuity to remove it. I wouldn't use much heat.
I also rebuilt my RGBs and put in a Rancho trans after doing a full restoration on this bus. The tranny stuff is page 34-35 in the link below. _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Lost in Space Samba Member
Joined: June 09, 2012 Posts: 133 Location: Bug Infested Forest, next to the REZ
Posted: Mon Jun 08, 2015 4:04 pm Post subject: |
Awesome pictorial, Bruce !
I too am doing a big nut on my '66 bus.
My question is, no washer between the small Oring and the inner race of the bearing ?
Basically I see no washers at all in this type assembly, correct ? |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Tue Jun 09, 2015 12:24 am Post subject: |
yes nice tutorial ^^^^ _________________ 1967 Split SO-42 Dormobile |
BarryL Samba Member
Posted: Tue Jun 09, 2015 11:02 am Post subject: |
Lost in Space wrote: |
My question is, no washer between the small Oring and the inner race of the bearing ? |
On Big Nut it's the chamfer end of the seal surface/spacer that butts against the inner race/o-ring: no washer. |
Posted: Tue Jun 09, 2015 11:07 am Post subject: |
Thanks much for the confirmation ! |
