junichi Samba Member
Joined: September 12, 2005 Posts: 749 Location: brentwood bay, bc
Posted: Tue Nov 24, 2015 9:15 pm Post subject: Small o-ring? |
I am following along at home and went to put in the small o-ring but it seems very small.
In my limited experience, o rings are usually a friction fit, not a stretch fit.
It will stretch and fit on, but then when I try to slide it in it rolls and twists itself inside out.
I assume this is not good... Have I got the wrong o ring? I got a generic kit from cip1 that has about a 24mm I.d. o-ring but the splined shaft is about 35mm. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Tue Nov 24, 2015 9:45 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Got to stretch it.
Take off the bearing cover.
Carefully by hand install the O-ring all the way inward on the axle.
Slide the outer spacer into the bearing cover and make sure the axle seal inner lip does not get bent out of shape doping that.
Slide in place the bearing cover and outer spacer together onto the stub axle.
Etc... _________________ In Stereo, Where Available! |
Posted: Tue Nov 24, 2015 10:00 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Hmm..I was hoping to follow the previous tutorial where the o-ring is slid in by pushing the spacer in. There is fresh rtv on the bearing cover!
Comments from Bruce that posted this tutorial?
Edit: more oil on the o-ring allowed it to slide in nicely. Is this method going to create a proper seal?
How does the spacer sit in relation to the bearing cover? Flush with it or sticking out a bit? If so by how much? How much force is required to push it home? _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Tue Nov 24, 2015 11:22 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Just slide the spacer inward. When you snug down the axle nut the drum will press it the rest of the way. _________________ In Stereo, Where Available! |
Posted: Tue Nov 24, 2015 11:59 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Of course! Thanks. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Wed Nov 25, 2015 7:41 am Post subject: Re: HOW TO: Install rear axle seal kit |
Ditto on responses, the o-ring has to be lubed well and stretched over the axle splines, it states that clearly in my description. You can't tell it well from the first two pics but the spacer does protrude outboard of the housing a bit (IIRC, 1/8"?) so the drum won't rub on it.
The biggest mistake guys make here is damaging the seal when pressing it into the housing. I owned a truck repair shop for decades and have installed thousands of seals, so I saw my guys make every mistake possible when installing a seal. If you use a socket to push the seal in it commonly distorts the seal or pops the garter spring out causing a leak. Buy a set of HF seal drivers.
Most of all, good luck! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Stocknazi Samba Member
Posted: Wed Nov 25, 2015 4:55 pm Post subject: Re: Small o-ring? |
junichi wrote: |
I assume this is not good... Have I got the wrong o ring? I got a generic kit from cip1 that has about a 24mm I.d. o-ring but the splined shaft is about 35mm. |
I usually put a round of tape on the end of the stub axle before pushing that o-ring on. Eliminates the possibility of damaging the seal on the splines. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Tue Dec 01, 2015 12:55 am Post subject: Re: HOW TO: Install rear axle seal kit |
On the other side I found this....note severely flattened large o-ring, and sealing washer is mangled. Mine were done differently on each side, and according to previous input the large o ring and washer should not have been in here!
Posted: Wed Dec 09, 2015 1:41 pm Post subject: Re: HOW TO: Install rear axle seal kit |
I will add as well that I have followed this great tutorial with a largely successful end product.
On the left side, I am fighting a slow leak at the axle, which I can only assume is caused by a less than perfect o ring seal. While it could be user error or a faulty spacer or o- ring, on the other side I decided to slide the o ring in place before mounting the backing plate and bearing cover. In this way I was able to visually confirm the o-ring placement and feel more confident with it. No leaks on the side done in this manner. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
joetrike13 Samba Member
Joined: April 09, 2014 Posts: 20 Location: Wichita, KS
Posted: Thu Feb 25, 2016 10:53 am Post subject: Re: HOW TO: Install rear axle seal kit |
can someone that has the pictures for these axle seal kits please repost them as the ones on the post are gone. i currently am trying to fix my 61 single cab small nut and it leaks out the vent hole. thanks for any assistance |
Posted: Thu Feb 25, 2016 11:45 am Post subject: Re: HOW TO: Install rear axle seal kit |
thanks |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu Feb 25, 2016 12:26 pm Post subject: Re: HOW TO: Install rear axle seal kit |
joetrike13 wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=615740 |
Posted: Wed Mar 02, 2016 1:07 pm Post subject: Re: HOW TO: Install rear axle seal kit |
I have a couple questions about the small o-ring found in the rear wheel seal kits. It does not look like a normal round o-ring; would a round o-ring work in this application, or is this a different type of o-ring?
I looked in the parts list and the part number is:111 501 296, but no mention of the size.
I would like to source some of these o-rings, instead of buying the complete wheel seal kits. _________________ WANTED:
Thomas Jefferson |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Scorcho Samba Member
Joined: May 04, 2012 Posts: 386 Location: Chicago, IL
Posted: Thu Oct 13, 2016 2:21 pm Post subject: Re: HOW TO: Install rear axle seal kit |
I just replaced my seal and as I was putting everything back in realized it was leaking even more fluid than before! I did everything right as I've checked twice already.
It appears to leak even more when I add fluid to the reduction gears. Anyone have any guesses as to why? |
Posted: Thu Oct 13, 2016 2:24 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Scorcho wrote: |
Until you fully torque the axle nut it will leak. |
Posted: Thu Oct 13, 2016 2:41 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Yikes forget what I just said about doing it right haha. I somehow broke the new seal. I may have put everything in the wrong order? The last picture shows the order in which I put everything should I have put the spacer BEFORE the round metal thing? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Thu Oct 13, 2016 6:57 pm Post subject: Re: HOW TO: Install rear axle seal kit |
Correct order but the seal is in backward. |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Fri Oct 14, 2016 6:15 am Post subject: Re: HOW TO: Install rear axle seal kit |
Also, put the spacer into the seal first while everything is in your hand, then slide the whole cover assembly on. _________________ 1957 Beetle
1966 Bus |
