Matthew Tylka Samba Member
Posted: Sat Dec 12, 2009 8:24 pm Post subject: Baby Dells Jetting |
I have a stock internal 1600cc 1971 Beetle motor with the only non-stock items being an 009 dist. and header. I also just installed some Dellorto FRDs and was wondering what jetting I should go with? Right now the jetting is what the factory installed in the dells. I was reading an old article in Hot VWs where the same carbs were installed on a relativly stock motor and the main jets were swapped out for a set of 130s and the venturies were switched to 26s. Anybody running else running these carbs on a stock motor and if so what jets do you have? Thank you. |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1192 Location: Boca de Ratones FL
Posted: Sat Dec 12, 2009 8:44 pm Post subject: |
are you in Bolivia or Miami jetting subject to altitude. _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Sun Dec 13, 2009 12:22 am Post subject: |
His ads say Sparta, Tenn. |
Posted: Sun Dec 13, 2009 1:24 pm Post subject: Baby Dells |
Yes I live in TN. The car accelerates, but is not very quick to acccelerate like it should and it acts like it tops out quicker than it should. If you try to blip the throttle it bogs itself like it is sufficating itself. Any ideas? |
Posted: Sun Dec 13, 2009 5:48 pm Post subject: |
so did they just started acting up?
sounds like some plugged jets.
this will help figure out what jets may be getting affected http://www.vw-resource.com/jets.html
you use a sync tool on them? _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
Posted: Sun Dec 13, 2009 6:02 pm Post subject: baby dells |
Actually just installed the carbs and they have the factory jets in them. I have the carbs synced by using a sync tool and they have just been cleaned and kits were installed. They are popping through the carbs, which make me think they are running lean. Doesn't seem like there is any vac. leaks and it idles great, just doesn't want to accelerate that great. I thought about upping the main jet as it has a 128 in it now, but the next size larger that CB sells is a 150 I believe...sorta large? |
Posted: Sun Dec 13, 2009 6:47 pm Post subject: |
to adjust for altitude I think you go up on the air.
with 40's and Pict 34 try loosen up the idle jet so it's berly on there.. dont know if it will work on FRD's
also make sure you dint tweak the float hook that had me scratching my head.
my pict bogged when I bunched the gas even after I went SVDA, I found a chunk of hose stuck in the fuel pump dint bog after that.
you fuel bump good? 3 1/2 psi IIRC _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
gator797 Samba Member
Joined: February 02, 2014 Posts: 2 Location: soddy daisy TN.
Posted: Tue Jul 22, 2014 8:34 am Post subject: |
Did you ever figure out the problem im having the same issue |
