73 sedan project begins...
Goto page 1, 2, 3 ... 9, 10, 11  Next
millerje78
Samba Amishman
millerje78 is offline
PostPosted: Tue Jan 05, 2010 3:50 pm    Post subject: 73 sedan project begins... Reply with quote
Hey guys, just thought I'd share a few photos here of my 73. I picked it up about a month ago and finally got started on it. here she is
already removed the fenders, decklid and hood. they are in pretty good shape, but the fenders on from a 72.
another view
cleaning up the engine bay
pans and channels not bad. somebody replaced them already but never treated the pans. Confused why would you not treat them?
this is a mess, but its all there.
im thinking the brake fluid reservoir lines need to be replaced. this gas system is ridiculous. I'm deleting everything but the filler neck.
mismatched door...trim line doesn't line up.
what is that black box?
should these rivets be there? probably not.
this area obviously needs attention. I have the replacement panel for it. can I do this without removing the body from the pan?
next issue...this bolt is stuck and I mean it. the 17mm no longer fits its so deteriorated. any suggestions?
sorry guys, lots of stuff to look at here. just wanted to share and get advice!
[/img]
always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry
miller0358
miller0358 is offline
PostPosted: Tue Jan 05, 2010 4:13 pm    Post subject: 73 sedan Reply with quote
I'm getting ready to install my body back on the chassis in about 2 weeks. Good luck, Jeff
DrDarby
DrDarby is offline
PostPosted: Tue Jan 05, 2010 4:14 pm    Post subject: Reply with quote
Glad to see another one saved. The black box is the voltage regulator for an alternator (alternator arrived middle of the 1973 model year). You'll most likely have to cut that bolt off and drill it out. You can soak and soak and soak in Kroil or BP Blaster then rattle it good with an impact hammer (then repeat) and after about a week try it. If you can heat it red hot that might do it too........just be ready to drill it out.
Midwest Autosavers, Cary, IL
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 4:48 pm    Post subject: Reply with quote
okay, voltage regulator, thanks!
the suspention bolt...hmm...gonna be fun cutting that one out. why do I have this feeling that I can't replace that panel without taking the body off the pan?
Rome
Rome is offline
PostPosted: Tue Jan 05, 2010 5:23 pm    Post subject: Reply with quote
This car certainly is saveable. Stay with it; complete one task before going to another. Rivets at glovebox should be there; they hold the dash surround panel to the metal dash. Glovebox should also have a black plastic liner over it.
Rear body bolt- heating it until bolt head is red/orange is good idea, since the expansion can break the rust bond to the chassis. Then, use a medium chisel straight-on to mark a flat on a side of the bolt head, preferably on the right side. Then place the chisel tip in that mark, hold the chisel "tangentially" to the head, and hit it with hammer (wear glove!). You are trying to break the bolt and turn it CCW ("lefty loosey"). Repeat this as the bolt starts to turn and loosen. This technique is in the back of the "Idiot" VW manual.
Although I've never replaced that rear mounting panel section, it appears that you can do the repair with body on pan. Just make sure that you cut the body metal slightly SMALLER than the patch panel initially, then trip to fit based on the type of repair (welding, riveting) you are planning.
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 5:41 pm    Post subject: Reply with quote
thank you for the info, Rome. I will give it a shot, and post the results. I assume I can't get the bolt hot enough with a propane torch? I don't have access to an oxy/acetylene torch. Sad
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Tue Jan 05, 2010 5:53 pm    Post subject: Reply with quote
If that doesn't work I'd slowly cut away everything around it, knock the head off and work the stud out once the head is out of the way.
I had the same bolt on the other side break (socket actually fit well). The stud came out easily.
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
*SBS 75*, LVVWC, SV2
www.my65bug.com
www.her65vert.my65bug.com
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 5:59 pm    Post subject: Reply with quote
how did you get at the stud? was the body off?
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Tue Jan 05, 2010 6:09 pm    Post subject: Reply with quote
Yes, and it has been several years but it you can get it center punched correctly and good EZout will back it out with heat applied.
Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
www.my65bug.com
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 7:00 pm    Post subject: Reply with quote
ill try it and post back some results, hopefully with some skin left on my knuckles.
gt1953
gt1953 is offline
PostPosted: Tue Jan 05, 2010 7:31 pm    Post subject: Reply with quote
Nice garage. Lotta work but U will getter done. My 73 has 72 trim along the running boards. How did you decide that it had 72 fenders? Not surprising, I think if it was in the parts bin they used it. Ditch the voltage regulator and go with an internal regulator altenator.
on your brake fluid reservoir line I strongly suggest you use fuel injector line as it has a plastic lining to hold up to the brake fluid.
Numbers Matching VW's are getting harder to find. Find one keep it Stock. You will be glad you did.
PS Wife wants a Type 3 Fastback
vwbud1973
vwbud1973 is offline
PostPosted: Tue Jan 05, 2010 8:24 pm    Post subject: Reply with quote
Nice! Keep up the good work. I wish mine was that nice when I started! Good luck with it.
I'd give that bolt some Kroil, and later in the day, heat it up and give it a whack with an air chisel or just a hammer and chisel. I had a few stubborn ones like that on mine. Although that particular bolt was laid sideways between the body and the frame and welded in between the two! Shocked
millerje78
Samba Amishman
thanks! I love it, only wish I would have built it bigger! isn't that always the case though. the best thing I did was putting in-floor heat in there. concrete stays nice and warm.
I do have quite a bit of work on my hands, but I enjoy being out there working on it. the fenders, well, I decided they are 72s because they have 71-72 taillights on them instead of elephant feet holes. If I ditch the voltage regulator for an internally regulated unit, which wires can I eliminate. I am an idiot when it comes to electrical stuff. Embarassed
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 8:27 pm    Post subject: Reply with quote
wow, puts things in perspective! I would really like to get it out of there whole, but due to the rust damage to the head, I might being pissing in the wind with that idea. I like the "soak it in PB blaster and beat on it with a chisel" idea. Smile sounds right up my alley.
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 8:29 pm    Post subject: Reply with quote
its here! Very Happy Green Bug
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jan 05, 2010 8:33 pm    Post subject: Re: 73 sedan project begins... Reply with quote
millerje78 wrote:
Same problem on my passenger side. I had my body guy leave it as is since that's how the car came from the factory.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 9:07 pm    Post subject: Reply with quote
Hey Glenn, yeah, I see what you're saying. It looks like yours is ever so slightly off, where mine I think is because this door is a replacement off of donor vehicle. I'm pretty sure mine is more than a minor factory oversight.
nice fricking bug by the way. I'm shooting for something half as cool as your 74.
PatterBon
Samba Engine Connoisseur
PatterBon is offline
PostPosted: Tue Jan 05, 2010 10:10 pm    Post subject: Reply with quote
Very nice project! Glad to see another 73 getting the attention it deserves, good luck with it and I look forward to seeing how it turns out! Very Happy
PNW Dub Folk & Kitsap dub Folk (KdF)
1973 Standard VW Beetle
1969 Cessna 172K Airplane
johnshenry wrote:
"Crusty"??
It would be easier to restore the Titanic.
lupin..the..3rd
lupin..the..3rd is offline
PostPosted: Tue Jan 05, 2010 10:33 pm    Post subject: Reply with quote
Replace your brake master cylinder, that thing looks nasty corroded. Oh and I'm quite jealous of that nice big heated garage!!
millerje78
Samba Amishman
PostPosted: Tue Jan 05, 2010 10:43 pm    Post subject: Reply with quote
I shall indeed replace it. I hope I can find a quality replacement, and I hope I can get the bolts out. Smile I am having a lot of fun getting corroded fasteners off of this thing. Laughing
the garage is a nice upgrade. when I worked on my 66 I was outside under an awning.
Page 1 of 11
