SG profile ignition switch lock cylinder.
3foldfolly
3foldfolly is offline
PostPosted: Sun Jan 10, 2010 6:34 pm    Post subject: SG profile ignition switch lock cylinder. Reply with quote
I want to re-key the lock tumblers in my ignition lock cylinder to match my NOS outer door handle Huf key. Is this possible or would it be easier to re-key the door lock cylinder?
Bruce
Bruce is offline
PostPosted: Sun Jan 10, 2010 7:07 pm    Post subject: Reply with quote
It is most likely easier to rekey the ignition switch. If you have a relatively rare Bosch switch, you can't take it apart. Another reason to do the switch is to clean out the last 50 years of gunk so it works smoothly.
Post a pic of your ignition switch.
Glenn wrote:
..... and like them better than Bosch.
3foldfolly
PostPosted: Sun Jan 10, 2010 7:17 pm    Post subject: Reply with quote
Thanks Bruce, I'll try and get out there tomorrow night or Tuesday and take it out to get a pic.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jan 10, 2010 10:10 pm    Post subject: Reply with quote
it is wayy easier to rekey a door vs ignition
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1958 deluxe Parts needed
1 rear hatch
2 rear pressed bumper trim
3 locking t handle
4 safaris
5 front hurst
Bruce
Bruce is offline
PostPosted: Sun Jan 10, 2010 10:22 pm    Post subject: Reply with quote
Not when the tiny grub screw is peened over.
There's nothing difficult about rekeying an ignition switch.
GLHTurbo
GLHTurbo is offline
PostPosted: Sun Jan 10, 2010 10:26 pm    Post subject: Reply with quote
I'm very interested about rekeying both the handles and ignition...some detailed pics and instructions would be much appreciated!
I bring nothing to the table.
1956 Beetle
1967 T2 Panel/Homebrew Camper
Bruce
Bruce is offline
PostPosted: Mon Jan 11, 2010 12:00 am    Post subject: Reply with quote
Here's an oval's ignition switch:
The lock cylinder of an oval window's ignition switch is held in place with the small wire clip. Groove for clip is indicated.
Although this is a 56-59 handle, the earlier handle comes apart the same. You have to remove the tiny grub screw in this hole. On most handles, there's a centerpunch mark just beside the top of the hole to lock the set screw in place. Sometimes it is impossible to get the screw out without destroying it's slot.
Once you get them apart, wash the gunk off with solvent or brake-clean. Mix the wafers around until they are flush with the OD of the lock cylinder when the key is in the cylinder. If you think you can just mix them around and be done, it's not that simple. You will be left with some wafers that are the wrong size, and in need of others you don't have. That is why it's a good idea to collect broken handles to get parts from.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Mon Jan 11, 2010 10:21 am    Post subject: Reply with quote
personally have never had real issues with the grub screw i always heat the handle after apply oil. i have had a bugger of a time however removing the clip from the ingition and reusing it afterwards. quess it is all luck of the draw.
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
Bruce
Bruce is offline
PostPosted: Mon Jan 11, 2010 10:40 pm    Post subject: Reply with quote
Sounds like you're not using the right tools. Really pointy dental pics do the job every time. After you get it out, you could file a small slot perpendicular to the groove to help get under the clip.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Jan 12, 2010 9:16 am    Post subject: Reply with quote
i normally use a dental pick with sucess however just two nights ago i had one that just wouldnt come off. admittedly someone had forced the cylinder with a screwdiver (instead of using a key). all said either way is not very hard i just seem to find it easier to go after door handles.
in a pinch with limited tumbler selection you can always tune them with a file to work
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
GLHTurbo
GLHTurbo is offline
PostPosted: Tue Jan 12, 2010 5:26 pm    Post subject: Reply with quote
great info guys, thanks. Any pics of the actual key matching process?
Will the guts of a 64ish door handle set work for spare parts?
Also, can you do this to a T-handle as well?
1956 Beetle
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Jan 12, 2010 5:56 pm    Post subject: Reply with quote
yes on parts and t handle no on fitting pictures
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
Bruce
Bruce is offline
PostPosted: Wed Jan 13, 2010 12:17 am    Post subject: Reply with quote
The wafers might work. There are two different diameters, and two thicknesses. Lock cylinders don't interchange.
bloogy
bloogy is offline
PostPosted: Fri Feb 17, 2012 1:08 pm    Post subject: Reply with quote
Here is the riveted style dis assembly. More work, you have to gently separate the rear as a whole assembly prying up on the crimps. then you can remove the assembly which easily separates into two pieces. Remove the pin and wedge and the lock cylinder comes out. Make sure to have the key in place to prevent the tumblers and springs from flying.
