How to remove front seats in 1973 Super beetle
twogunpapa
twogunpapa is offline
PostPosted: Sun Jan 17, 2010 1:53 pm    Post subject: How to remove front seats in 1973 Super beetle Reply with quote
My husband just bought me a 1973 beetle..she needs a little work but will be so worth it. We need to remove the front seats as the bushings are worn how do we remove them? I saw a post but they didn't say if it was for a 1973 or not.
Thanks for your help..and I've already learned alot by browsing through the forums.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jan 17, 2010 1:56 pm    Post subject: Reply with quote
There's a safety clip in front of the center slider. Just pull it down and slide them back. They'll come off the tracks and then take them out.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
ExtraNoise
ExtraNoise is offline
PostPosted: Sun Jan 17, 2010 5:46 pm    Post subject: Reply with quote
Were the 73s just like the 74 and laters? Our 72 had a little pin on the right-hand rack that needed to be pressed down in order to get the seats to slide off. We couldn't find anything about it in any book or on the internet.
Help me save my VW - check out my Kickstarter project
My VW project blog in case you want to follow along
kspageddie
kspageddie is offline
PostPosted: Mon Jan 18, 2010 8:57 am    Post subject: Reply with quote
U could get hit in the rear of the car and have the force eject the front seat loose...thats what happened to me last summer...lol
LeviMan2001
Samba Post Whore
LeviMan2001 is offline
PostPosted: Mon Jan 18, 2010 10:36 am    Post subject: Reply with quote
Look at where the front of the seat attaches. See that little tab? push that down then pull the seat straight back untill it comes off the tracks
http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs
hsosa1
hsosa1 is offline
PostPosted: Mon Jan 20, 2014 4:54 pm    Post subject: Reply with quote
does this apply to a 71 super beatle. ? i pull on the lever the seat slides but doesnt come off the rail . im pushing towards the steering to remove the seat. i dont see a pin? i have the lever turned so it doesnt engage the teeth but doesnt slide out.
62' Type 1 Convertible 1962 KAB
59' type1 og ragtop project
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
binky13
binky13 is offline
PostPosted: Tue Jan 21, 2014 4:18 am    Post subject: Reply with quote
my release pin loves to slide out at inoppurtune times and dump me on the floor. I always have to laugh Razz Razz Razz
68 Volksrod project currently
Joel
Joel is offline
PostPosted: Tue Jan 21, 2014 4:48 am    Post subject: Reply with quote
No,that is only 73 and later with the 3 point runners.
the twin rail you've got have a release tab on the right runner at the front that needs pushing down.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
djkeev
djkeev is offline
PostPosted: Tue Jan 21, 2014 6:07 am    Post subject: Reply with quote
Later models had a bolt in the front hole.
I don't know what year the change was made.
I suspect it was when they went with full foam seats and abandoned springs.
http://www.thesamba.com/vw/forum/viewtopic.php?t=553852&highlight=
Dave
86 Vanagon Westy "Weekender" 2.1 Auto
Karmann Ghia
hsosa1
hsosa1 is offline
PostPosted: Tue Jan 21, 2014 5:18 pm    Post subject: Reply with quote
Ok yeah its not a 74 . just a 71 which has the the lever. it looks like the rail end which kinda looks like an arrow head is getting stuck on the rail. looks like i will need to grind dow that metal end. to get the seat off only thing i can think of. it looks lit the end doesnt pass through the guide and just hits near the spring on the right passender rail. i tried to straigten the end but now im going to just grind it down or maybe use a file so it can pass through the rail .
GARYVONT
GARYVONT is offline
PostPosted: Wed Jan 22, 2014 3:20 pm    Post subject: Reply with quote
I had this identical problem on my '71 Super. Mine has small metal tabs located at the front, right, side, just outside of the tracks. FIRST, remove the coil springs that pull the seat forward. Push the tab down and push the seat forward (both actions at the same time) and off the track. You may need some help pushing it forward. If there is a "sticky" on this, some kind soul sent me some excellent photos when I was inquiring. Good luck!
GARYVONT
GARYVONT is offline
PostPosted: Wed Jan 22, 2014 3:21 pm    Post subject: Reply with quote
hsosa1
hsosa1 is offline
PostPosted: Wed Jan 22, 2014 4:25 pm    Post subject: Reply with quote
do u have any pics of the that tab? its not the actual lever that turns the metal piece to lock into the teeth correct? ill look for the tab. i didnt see the return spring underneath im suspecting it was pulled out. is the tab on the actual seat rail of the seat or is it part of the rail welded to the pan?
GARYVONT
GARYVONT is offline
PostPosted: Thu Jan 23, 2014 9:59 pm    Post subject: Reply with quote
I found the tab difficult to find, but once you do find it, you'll wonder why it was sooo hard. It is NOT the lever that disengages the seat so it will slide. Look at the right front corner of the right hand track, just to it's right corner area. You may have to dig through some carpet to find it.
GARYVONT
GARYVONT is offline
PostPosted: Thu Jan 23, 2014 10:00 pm    Post subject: Reply with quote
hsosa1
hsosa1 is offline
PostPosted: Thu Jan 23, 2014 10:42 pm    Post subject: Reply with quote
Ok ill look tommorrow. i remember on my 1st 71 that i had . i had no problem removing the drivers seat. over 20yrs ago i remember wanting to have lowbacks . also remember swearing i would never buy a fatchick. again lol
djkeev
djkeev is offline
PostPosted: Fri Jan 24, 2014 10:57 am    Post subject: Reply with quote
Did you follow any links previously posted?
There are photos of the tab and also a link within a link with a photo of the tab installed with the seat.
Dave
Karmann Ghia
hsosa1
hsosa1 is offline
PostPosted: Fri Jan 24, 2014 8:44 pm    Post subject: Reply with quote
ok today i found the tab. i took a picture placed a nickel on the tab that you push down on. for future reference. this is for a 71 superbeetle front seat removal. spray wd40 etc. clean around tracks. i used a tall flat file to push down on the tab while i pushed the seat off the track.
GARYVONT
GARYVONT is offline
PostPosted: Sat Jan 25, 2014 11:07 pm    Post subject: Reply with quote
While you have it out, you may want to find out if the '71 Super used plastic/nylon (?) skids on the rails. My seats were real sloppy, and there were no skids on them. If so, I will definitely add some if I end up using the stock seats.
Joe1stBeetle
Joe1stBeetle is offline
PostPosted: Sat Jan 25, 2014 11:22 pm    Post subject: Reply with quote
I have a 73 standard beetle. You remove one little Philips head screw then pop the little clip back and that part is free. You have to pull your forward adjustment lever so the big pin clears the hole and the seat will slide right out the back. Very simple. About 1 minute and you are holding your seat outside the car. Not sure if the super is any different. I wouldn't think so on a 73
