GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9363 Location: Northwood, NH USA
Posted: Fri Dec 30, 2011 9:03 pm Post subject: |
I heard that they were offered into the early 60s, but don't know that for certain. _________________ John Henry
'57 Deluxe
'56 Single Cab |
volksartist Samba Member
Posted: Thu Feb 03, 2011 11:02 am Post subject: |
Does anyone know when the crank start option was offered until.
A local guy has a 54 oval with a crank start set-up and his father
was the original owner. I did not ask him if it came from the factory
that way? |
Posted: Thu Jan 21, 2010 1:14 pm Post subject: |
The industrial and bus cranks (far more common) are too short for the Beetles. I do know of someone who will be reproducing the Beetle cranks hopefully in the next month or two. _________________ John Henry
'57 Deluxe
'56 Single Cab |
johan_l Samba Member
Posted: Thu Jan 21, 2010 12:50 pm Post subject: |
My early 51 (deluxe that lacks the ichias-vents and has a antenna bump and lever dampers) had a hole in the H-valance that looked factory and holes in bumper indicating a riveted crank bracket... Though the car was in very bad condition... will bring parts of it back to life... Will a industrial engine crank handle fit? The engine will also be a industrial 30 hp one... _________________ Johan, Sweden
1960 Karmann-Ghia coupé
1957 Oval window
Bastard Split window <-- Translate |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Thu Jan 21, 2010 7:29 am Post subject: |
If I understand your language correct, yes. A pic would help. |
Posted: Thu Jan 21, 2010 7:24 am Post subject: |
Bengt H wrote: |
I friend of mine has an late -48 with the same hand crank so I think its from that era. If it is for sale I am interested to buy it, I also has a -48 . My june -49 has the normal style of crank. |
By "normal" style Bengt, you mean the kind with the bead rolled in the end of the sleeve/handle?? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Jan 21, 2010 7:22 am Post subject: |
Posted: Wed Jan 20, 2010 1:22 pm Post subject: |
johnshenry wrote: |
Cranks were dropped as standard equipment after '49, but offered as an option well after that. My '50 came from Sweden, and I was told that a lot of N European splits were ordered with the hand crank option. |
Thats correct, many Swedish -50 has the crankhandle but I have not seen many later splits with that. |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Wed Jan 20, 2010 10:59 am Post subject: |
Thanks! _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Posted: Wed Jan 20, 2010 10:29 am Post subject: |
Cranks were dropped as standard equipment after '49, but offered as an option well after that. My '50 came from Sweden, and I was told that a lot of N European splits were ordered with the hand crank option. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Wed Jan 20, 2010 10:19 am Post subject: |
I thought I read somewhere that the crank was dropped before 1950. _________________ Central Jersey VW Society
ChrisRheinschild Samba Member
Joined: September 24, 2007 Posts: 81 Location: Clemmons, NC
Posted: Wed Jan 20, 2010 10:13 am Post subject: |
The crank handle that came with my 25hp has the rolled bead. On the pulley end it has a guide pin that fits into the nut. This helps to place the crank to the engine. The engine is November 1952. I don't know if the crank is original to the engine. |
Posted: Tue Jan 19, 2010 7:03 pm Post subject: Beetle hand start cranks |
I have 3, and 2 have a handle end that has a bead rolled in the end, as does the rod under it to keep it captive, this is the more common style that I seen. But this one has a simpler design, with just a sleeve and small steel rings welded on either side of it to keep it captive.
Wondering if anyone has seen this style before, has one, or maybe has documentation showing it. It could be a homemade job, but the rod bends look very nice.
Any info would be great...
'57 Deluxe
'56 Single Cab |
