Weezyissuperfast Samba Member
Posted: Thu Sep 18, 2014 1:20 pm Post subject: New Vanagon Owner Question |
So, I just got my first Vanagon...a long time dream realized. It is an '87 Wolfsburg. The body and interior are in great shape, but there are some mechanical issues. My major area of concern at the moment is that it blows white smoke out of the exhaust. I'm assuming that this is indicative of a blown head gasket that is allowing coolant to get into the cylinder and burn. Am I correct in this assumption?
I am planning on pulling the engine and replacing the head gaskets. I am hoping to not have to replace the heads themselves at this time. Do I have a prayer of this? I'm trying to get an idea of just what I will be sinking into this repair before I start it.
Thanks!
-Rob |
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Thu Sep 18, 2014 1:39 pm Post subject: |
The usual head gasket failure is the water jacket seal letting go and profuse coolant leaking from there (thick black gasket between water jacket and head). White smoke MAY be a coolant burning situation but is often a very rich-running condition, caused by various things including a crapped out O2 sensor, leaky exhaust, bad grounds, etc, etc. best to figure your ailment before tearing the heads off. If you are convinced of head gaskets then you can have your coolant tested for combustion gasses. Your cooling system should be percolating pretty good if the head seals are gone and allowing combustion gasses in. _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
Syncro Jael Samba Member
Posted: Thu Sep 18, 2014 2:20 pm Post subject: |
Just on a good note. One of my kids took a Westy camping late in the year. They woke up and started the vehicle.
White smoke blew out along with water.
They shut it down and promptly called me on a cell phone stating their dilemma and a blown head gasket.
I told them to start it back up, let it warm up and call me back if it still blew white smoke.
I never got a return call....
Hopefully yours is this easy. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Thu Sep 18, 2014 2:31 pm Post subject: |
Can you smell coolant in the exhaust?
A sweet smell, may make you hungry for pancakes.
I have not done this but I recall threads describing the use of JBWeld to address small pits that are often found on the head surfaces. Sounds like a hack but by all accounts it is a responsible approach in some cases. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Thu Sep 18, 2014 6:51 pm Post subject: |
Are you losing coolant from the reservoir?
Any whiteness on your oil dip stick? |
vela123321 Samba Member
Posted: Thu Sep 18, 2014 8:13 pm Post subject: |
Syncro Jael wrote: |
Hopefully yours is this easy. |
Good kid to have that situational awareness and actually call you! I hope I'm so lucky... _________________ ________________________
1987 Westfalia Vanagon 2.1 automatic
2014 VW TDi Jetta Sportwagen (Dieselgate)
2016 BMW 328i
1967 Bug... given to a friend
others not VW... Toyota, Audi, Volvo, Datsun, International Harvester |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Thu Sep 18, 2014 9:06 pm Post subject: |
A blown water jacket will leak coolant around the seal, the thick black rubber seal around where the head meets the case. A blown head gasket is internal. The head gasket is a metal ring that sits ontop of the cylinder and is crushed (sealed) by a properly torqued head (33ft pounds i believe). When the head gasket goes bad it allows combustion gases into the coolant and if bad enough allows coolant into the combustion chamber, which would give you white smoke for sure and a smell of burning coolant out of exhaust. How bad is the white smoke, just on start up, all time driving or just on decel? All these symptoms could point into different directions. Are you sure the smoke is not slightly bluish? That would indicate possibly bad rings or valve guides.
dig deeper and report back so can help diagnose properly
Welcome to the looney bin |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17109 Location: Retired South Florida
Posted: Fri Sep 19, 2014 10:01 am Post subject: |
A weeping brake master cylinder can fill the booster with brake fluid that will get drawn into the engine an smoke too. Rare, but does happen. _________________ ☮️ |
Posted: Fri Sep 19, 2014 10:10 am Post subject: |
Thanks for the help everyone. I haven't had a chance to drive it yet, as the auto transmission is slipping (that is my first project). From what I can tell just letting it run in the driveway, there is no smoke on startup but within a couple of minutes the smoke starts. It is definitely white, not blue at all. Nothing obvious on the oil dip stick, looks pretty clean, no sign of coolant. I will run it some more this weekend and look for gas in the coolant. Thanks!
-Rob |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
