ts39136 Samba Member
Joined: January 30, 2010 Posts: 735 Location: Pocatello, Idaho
Posted: Sun Feb 13, 2011 12:49 am Post subject: |
thesatelliteguy wrote: |
I like the blue trim color. Are you going to paint the trailing arms that color? |
Yes. Eventually. Also fenders, trans mounts I figure I'm going to have to readjust my ride height soon, so I plan on removing the arms again before spring, redoing the ride height and painting at the time. They are primer white right now.
I'm on a rigid schedule this week. 48 hours of work to go and here is my schedule. I'm trying to make a local VW meet on Friday. It's still up in the air if I'll make it.
Saturday
wheel bearings/spacers/stubs
brakes/brake lines
finish welding frame horns
frame horn support left
Sunday
frame horn support right
rear cage bottom mount
rear cage top mount / rollbar modification
engine mounts tack
Monday
remove engine
remove transmission
engine mount finish weld
sand/clean frame horn / trans mounts.
primer frame horn x 1
primer frame horn x 2
Tuesday
paint frame horns x 1
paint frame horns x 2
install flywheel/clutch/pressure plate
lube pilot bearing and throw out bearing
install transmission
install engine
radiator mount construct/weld
squeezed in sometime
rear cage sand prep
primer rear cage x 1
primer rear cage x 2
paint rear cage x 1
paint rear cage x 2
Wednesday
control arm install (test)- tire install - fender install - trim fenders for clearance
control arm remove
torsion bar install
control arms install
rear end alignment
CV/axle install
brake line install
shocks
Thursday
starter install / wireing upgrade?
air cleaner
radiator install
antifreeze
bleed brakes
throttle cable
gas lines
exhaust realign / reweld
bowden/clutch
shifter attatch/adjust
brake light wiring solder
tires
fender install
Friday whatever I forgot
Whew... tired already. I got a bunch done today (Saturday) and am looking forward to another good work day tomorrow. I work much better under pressure, so I placed this deadline upon myself.
Then I can work on the day projects to get it prettied up. Pictures will be slim until I get done, no time for documentation. _________________ My Build Page |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Sun Feb 20, 2011 8:27 am Post subject: |
Well... I got quite a bit accomplished. The deadline worked to get my butt in gear. Lots of paint, motor ready to go in.
I'll try to get some pictures on here later. I'm on the iPod right now.
Got stumped by the trailing arm again. Maybe I was too tired when I measured it up last time, or maybe I just didn't realize how close I'd be cutting my CV angles. I'll need to go to a slight positive camber like the other arm.
So... as soon as I found that out I left the garage and haven't returned yet. Taking a few days off.
Still plan on running again in two weeks.
Pics. tonight if I don't get called in to work again. _________________ My Build Page |
Posted: Mon Feb 21, 2011 2:26 am Post subject: |
Posted: Tue Feb 22, 2011 9:05 am Post subject: |
Well... got the trailing arm fixed up and mostly welded. I'm going ot do some more reinforcing. Very excited to get that out of the way. Need some more welding wire, but now I'm off to put some trans fluid in.
Also ordered a new clutch disc. That six puck kennedy disk, I'm thinking, is why I've been having chattering issues. _________________ My Build Page |
Posted: Mon Mar 07, 2011 1:40 pm Post subject: |
Well... I'm getting close to buttoning up the rear end. I still need to find or build some high fenders. This is 13" under the rear skid plate, plenty of droop left.
It should sit perfect front to back once I get the bigger tires on there.
Still need to bleed the brakes, install the starter, and hook up the shifter.
I will need to readjust the torsions at some point, but thought I'd give them a beating first.
The spring rate seems just perfect where it was way too stiff before, but I'll have to do some testing to make sure. The ride will definitely be less harsh, anyway.
Posted: Tue Mar 08, 2011 1:52 pm Post subject: |
Took it for a drive today! Very happy to be back in the saddle, for now.
I need to figure out the alignment, it's still way toe-ed in. I'm debating on redoing the other trailing arm, but we'll see how close I can get.
But the really good news. That transmission is as tight as a $#%5 $% $%#$ #$%#$%. Much better than my sloppy second hand trans I had.
And I now have a forth gear!! Once I get the 32" tires mounted and figure out my alignment, it should cruise very nicely at 55.
quadrazer Samba Member
Joined: April 11, 2010 Posts: 295 Location: Castalia, Ohio
Posted: Tue Mar 08, 2011 2:54 pm Post subject: |
Nice to see you driving it again Tim! I really like the blue colors you used during the build. What type of wheels are those? Those are sharp! _________________ I DID wash my hands....the rest is 'built-in' dirt!
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=409845 |
Posted: Tue Mar 08, 2011 7:36 pm Post subject: |
quadrazer wrote: |
Nice to see you driving it again Tim! I really like the blue colors you used during the build. What type of wheels are those? Those are sharp! |
They are "Jackman's" from what I'm told. Wait till you see what color I'm going to paint them _________________ My Build Page |
Posted: Wed Apr 06, 2011 6:35 am Post subject: |
Well, I've been neglecting my Samba friends. Here is an update on the craziness.
I'm mostly back together and running. Still need to figure out some high mounted fenders in the rear, but am happy to be driving it again. Heat and windshield wipers are the main projects now.
edit--> I also put the 32" tires on there. It cruises really nice at 55mph @ 2600rpm. 65mph is a little loud (3100rpm). But there is still plenty of low end torque to handle the 32's at slow speeds.
The new clutch disc has made a world of difference in drivability. Very user friendly now.
I like the whole roadster look. Low, long, wide, fast. Exhaust is still unruley, but with careful driving I can keep from echoing through town. I'll work on painting the wheels, fenders, and little trim pieces as energy allows.
I hope to park my 12.5mpg truck and drive this through the summer, and if all goes well, have the ammenities ready for winter driving. I filled it up the other day after about 100 miles... $10.?? (still need to fix the speedo/odo cable and fuel guage)
Here are some pictures of how it stands now. It has about 13" under the rear skid plate and about 14.5" under the pan. There is still room to go up on both the front adjusters and the rear torsions. 16" will be about my goal.
Also did a weight check at the local certified scales...
750lb. (37%) front
1260lb. (63%) rear
______
2010lb. gross
I still have some cage work that should be done, plus add in tools, spare tire, etc. And front bumper... almost forgot about that.
That's all for now. _________________ My Build Page |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Wed Apr 06, 2011 6:53 am Post subject: |
I might have missed it...but where is you fuel tank??front or rear? _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Posted: Wed Apr 06, 2011 7:02 am Post subject: |
Stock fuel tank, stock location. _________________ My Build Page |
Posted: Wed Apr 06, 2011 3:43 pm Post subject: |
She looks great, Tim! The longer rear arms really did wonders for the stance. And I hear ya on parking the truck for the summer...my rail will see a ton of street use this year for the same reason! _________________ I DID wash my hands....the rest is 'built-in' dirt!
yellowsnow Samba Member
Posted: Thu Apr 07, 2011 9:51 am Post subject: |
Haha, I just read the entire 23 page build and must say this has been an excellent read. I am very impressed with your ability to adapt to time/budget constraints and still get that rig done. Great job buddy! Oh, and need more youtube videos! |
tanner_122 Samba Member
Posted: Thu Apr 07, 2011 11:44 am Post subject: |
quadrazer wrote: |
She looks great, Tim! The longer rear arms really did wonders for the stance. And I hear ya on parking the truck for the summer...my rail will see a ton of street use this year for the same reason! |
x2 the stance is perfect now
and brian lucky u have full AC in ur rail haha _________________ 91 jeep Cherokee "TANK" |
Posted: Thu Apr 07, 2011 2:10 pm Post subject: |
tanner_122 wrote: |
and brian lucky u have full AC in ur rail haha |
True...but it seems to blow a bit colder in the winter. _________________ I DID wash my hands....the rest is 'built-in' dirt!
Posted: Fri Apr 08, 2011 12:31 am Post subject: |
yellowsnow wrote: |
Thanks. I keep thinking I should have spent the time to get another degree and then just buy a better bug, but my daughter's first ride in it was worth all the time we spent together. She's very proud of "her" work. _________________ My Build Page |
Posted: Mon Apr 25, 2011 11:29 am Post subject: |
Your provoking me again. Come the time my 1600 blows all over the road, im going for a water pumper. Screw this air cooled shananagins. _________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
Posted: Mon Apr 25, 2011 6:53 pm Post subject: |
Your provoking me again. Come the time my 1600 blows all over the road, im going for a water pumper. Screw this air cooled shananagins. |
Maybe my silence is speaking to you?
I've been driving. Yes, believe it or not. I've been driving to work, taking my kids to school, running errands, and even joyriding. It handles great for the street. Haven't managed to get off road yet, the local trails are closed until May 15th. I still have work to do on the fenders and tree bars and exhaust, but it's the kind of work I can finish and be back to driving in a day or two.
I even found out that the earth is round , go figure. I went on a short interstate trip (50 miles). Averaged 30mpg at 75mph. I laugh every time I go to the gas station. Quite litterally, I sit there with a shit eatin grin on my face . With windshield wipers and heat, it is much more enjoyable.
My truck is on empty, I don't think I'd even make it to the gas station without running out of gas, and I don't plan on filling it up anytime soon. No more (!) baby steps.... 25 cent to the stop sign, 50 cents, then turn right, $1.75 then put it in neutral to try to gain 0.3mpg. No more.
I even had to scrape frost off my window for the first time. I'm happy it's a small window.
Still got work to do, but all in due time.
Thanks for the comment. _________________ My Build Page |
Posted: Tue Apr 26, 2011 6:11 am Post subject: |
I'm just getting off work. It's snowing!!
My first trip in the snow _________________ My Build Page |
