Rear torsion bar adjustment help
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
56 manx
56 manx is offline
PostPosted: Mon Feb 01, 2010 7:41 pm    Post subject: Rear torsion bar adjustment help Reply with quote
Last year a friend and I tried adjusting them on my swing shaft but we couldn't get the insides to come loose. We ended up moving the outer a few notches but the camber isn't right yet so we're going to try it again soon. Does anybody know the best way to get the insides loose without a major production? And is it even necessary to adjust the insides in order to get the desired camber? I'm hoping I can get the camber correct by adjusting the outsides only in case I can't get them loose without major deal. All help is appreciated.
Richard
BL3Manx
BL3Manx is offline
PostPosted: Tue Feb 02, 2010 9:53 am    Post subject: Reply with quote
If you only move the outer splines, you can only make adjustments in 8.1 degree increments. It will probably be too much or too little. To make finer adjustments you have to move the inner forward a notch and the outer back( or vice versa) until you get it right.
Usually the bars come loose from the center by just wobbling them around and pulling by hand. If yours are really stuck you could either pound on the end of one with a sledge hammer until it pushes out the opposite one. Then get a steel rod with a just smaller diameter than the splines and hammer the remaining bar back out.
An easier solution is to buy a pair of adjustable spring plates and install them on the stuck bars as close to correct as possble, then use the threaded adjusters to get it right.
http://www.thesamba.com/vw/classifieds/detail.php?id=575512
Dale M.
Dale M. is offline
PostPosted: Tue Feb 02, 2010 12:51 pm    Post subject: Reply with quote
Pretty extensive discussion with lots of charts and calculations and input here:
http://www.mydune-buggy.com/forum/viewtopic.php?f=10&t=47
Also pretty good article by a well know name on these boards...
http://www.mydune-buggy.com/home/dl_files/reartorsionsetup.pdf
IF you get the bars out, be sure to grease them (splines) before putting them back in!
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
mcmscott wrote:
...... and not keyboard jockeys that just have high post counts
10ovr
10ovr is offline
PostPosted: Tue Feb 02, 2010 6:49 pm    Post subject: Reply with quote
+1 on adjustable spring plates,Takes about 2/3 of the bad words out of the job,,,,
Russ Wolfe
Russ Wolfe is offline
PostPosted: Tue Feb 02, 2010 7:02 pm    Post subject: Reply with quote
And can I also mention, that there is a left and right to the bars.
They should be marked on the ends.
Gary: OK. Ima poop.
56 manx
56 manx is offline
PostPosted: Sun Feb 07, 2010 9:01 am    Post subject: Reply with quote
Sorry it took so long for a response, I've been in the hospital for maintenance. Thanks to everybody for the help.
I've never heard of the adjustable spring plates before, and they're definitely a possibility. I imagine these will need to be welded to the stock plates or is there another way? Also are these something lot of people on here use?
Thanks, Richard
BL3Manx
BL3Manx is offline
PostPosted: Sun Feb 07, 2010 9:43 am    Post subject: Reply with quote
There is no welding. You take the old spring plates off and replace then with the two piece adjustable spring plates. Since the adjustable plates are two piece(like a pair of scissors) they're thicker and you'll have to shim out the end cap. The inner section also has a larger diameter because one part fits over the other, so you'll need a larger diameter inner bushing.
There are also swingaxle and IRS styles and also different sizes for the three different torsion bar lengths.
No clue how many people who read/post on the samba use adjustable spring plates. Have you done an archives search on "adjustable spring plates"? I'd start there.
Dale M.
Dale M. is offline
PostPosted: Sun Feb 07, 2010 10:30 am    Post subject: Reply with quote
The flip side of adjustable spring plates at anywhere from $100 a set (Chinese) to $350 as for (Sway-A-Way) is about 1.5 hours of work on each side... Once you have chassis "set" where you want it, your investment just sits there.....(either method)...
Dale
GreaterMook
GreaterMook is offline
PostPosted: Sun Feb 07, 2010 10:41 am    Post subject: Reply with quote
Does anyone have a picture of these installed???
56 manx
56 manx is offline
PostPosted: Sun Feb 07, 2010 12:06 pm    Post subject: Reply with quote
Thanks again for the replies I always appreciate the help I get on here.
I'm still going to consider using the adjustable plates but it might just be as faster to adjust the stock ones thus saving myself some money. Once I get them where I want em there will probably be no need to adjust them again, therefor no need for adjustable plates necessarily.
But if I do go with the adjustable ones, are the different bushings going to be hard to find?
Richard
Dale M.
Dale M. is offline
PostPosted: Sun Feb 07, 2010 12:48 pm    Post subject: Reply with quote
Should take stock bushings....
Dale
66 Shorty
66 Shorty is offline
PostPosted: Sun Feb 07, 2010 1:41 pm    Post subject: Reply with quote
Speaking of Bushings, I noticed my IRS spring plates have a larger diameter where the bushing rides than the Swing plates do. Is that normal? If someone were to,... say switch the spring plates to run a swing in an IRS car & remove the arms, they would just need stock Swing bushings for the plates, right? Are the T/H ends on both the same?
~X-Man~
'60's Spatz Buggy body on '74 Chassis (Budget Build)
Sand Rail (Budget build to play around)
'69 Bug (Baja-to-be partial daily)
'10 Silverado (My daily)
10ovr
10ovr is offline
PostPosted: Sun Feb 07, 2010 1:43 pm    Post subject: Reply with quote
CB has the Sway A Way adjustable plates for under $300..They come with bushings,,
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
