pdub Samba Member
Posted: Mon Feb 08, 2010 2:55 pm Post subject: DPR or DMS (Demellow Crank?) |
Which is better DPR or DMS, or are they both about the same? I'm starting to plan my 1915 to 2275 upgrade for my baja bug (75% street driven) and was thinking (I like torque):
DPR 82 mm crank
DPR stroker rods (stock rods) http://www.dprmachine.com/Html%20Files/con_rods_1.htm
DPR reground lifters
DPR reground "120" camshaft (regrinds ok or just go new?) will 120 work with 1.25 rockers? (already have them). http://www.dprmachine.com/Html%20Files/cams_1.htm
Mahle 94 mm type B stoker pistons
Steve Timms stage 1 heads
Exisitng 40 IDF webers (upsize vents & jets)
Exsiitng Trimil exhaust with muffler
009 disitirbutor or CB's Magnaspark
Does this seem like a good combo? |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Feb 08, 2010 3:17 pm Post subject: |
There is no difference in quality. They are both superior crankshaft shops. This one you will have to go with a gut feeling when you call them up to check out customer service level. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Turbo_Manx_Maniac Samba Member
Posted: Mon Feb 08, 2010 3:26 pm Post subject: |
120 cam with 1.25 rockers is a great combo and will work great with your combo and heads. On lifters, I really like the CB lightweight ones vs reground, they are alot lighter and any weight you can take out of the valve train pays off in spades.
Flip a coin on the crank vendors, DMS and DPR are both the best. |
spyvsspy Samba Member
Joined: August 22, 2006 Posts: 1022 Location: inside the barrel...
Posted: Mon Feb 08, 2010 4:51 pm Post subject: |
I own a DPR crank and flywheel. If measuring precision is a pastime of yours, you'll get gratification from verifying DPR components. _________________ It is what it is. |
craigman Samba Member
Posted: Mon Feb 08, 2010 6:44 pm Post subject: |
The one and only Demello crank i've seen was bent. It was .015" out. Right out of the box. Found it during mock up. |
RGR Samba Member
Joined: October 15, 2009 Posts: 126 Location: SAN DIEGO
Posted: Mon Feb 08, 2010 7:23 pm Post subject: |
if your from san diego call pauter machine in chula vista , i dont know if there still making there welded cranks but if they are there alot better than two you listed. |
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 210 Location: NE Indiana
Posted: Mon Feb 08, 2010 7:29 pm Post subject: |
Bob Demello (DMS) builds a great crank, just don't be in a hurry to get it, I have been waiting several months on my parts. I would give DPR a try.
Good Luck
Kenric _________________ The empty can rattles the most! |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon Feb 08, 2010 7:38 pm Post subject: |
DPR.. I have over a thousand engines on the road using their cranks.. NEVER have I had one fail!
No exaggeration. Jose knows his stuff better than anyone I have experienced. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
gt1953 Samba Member
Posted: Mon Feb 08, 2010 7:45 pm Post subject: |
My 76mm crank in my 1745cc Hot VW mileage motor is DPR product. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Mon Feb 08, 2010 8:07 pm Post subject: |
I ordered a stock VW crank to replace my 69mm 4340 that was 0.007" out on two journals. I called him back 10 minutes later to ask what his tolerance was. (This is for the stock stroke. I think the welded ones are closer. Anyone know for sure?)
"Like, 0.003" man."
"Do you think my 0.007" is a problem?"
"You don't need my crank, man. You trying to kill mosquitos with a cannon!"
"Are you sure?"
"Run it. Go and run it."
"Thanks Jose. Can I cancel this? I'm sorry. I hope I didn't waste your time."
"Yeah man, no problem, you can cancel. You don't need any of this stuff!"
Just like that. I have not met another vendor that revokes my order when he decides that his stuff won't fix my problem. Guess who my future 82mm is coming from?...
No experience with DMS. |
77charger Samba Member
Posted: Mon Feb 08, 2010 8:30 pm Post subject: |
I have used 3 diiferent dpr cranks and have been happy with all of them would nt use anything else.
1 motor was a 69mm c/w -1914
78x90 motor i built for my uncle
And my current 82x94 i am using in my buggy.
I am spinning my 2275 to 7k.You will notice a nice improvement in low end torque with the jump from 1914 to 2275.
I like mine makes driving the dunes alot easier and dont have to keep motor revved up as much and shift less _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
pdub Samba Member
Posted: Mon Feb 08, 2010 10:23 pm Post subject: |
Great information! Thanks for the feedback. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Mon Feb 08, 2010 10:53 pm Post subject: |
I ordered a DPR crank a few months back, called Jose just today and told him I needed another for a customer. He actually remembered who I was, was polite and told me the parts were on the shelf and ready to ship. Top notch service.
Quote: |
spyvsspy: I own a DPR crank and flywheel. If measuring precision is a pastime of yours, you'll get gratification from verifying DPR components. |
I checked a set of DPR 311B stroker rods I got a while back, I've never seen a rod balanced so closely right out of the box. Impressive. _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
nsracing Samba Member
Posted: Tue Feb 09, 2010 3:28 am Post subject: |
They are both good. I just have more dealings w/ Demello in the past. (Chris) and dad I have dealt w/.
I have also installed DPR cranks. Also very good.
The nitriding if so ordered I like getting them done from Demello. |
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Tue Feb 09, 2010 6:42 pm Post subject: |
I had Jose at DPR build a crank for my 36 Hp project, I am no engine builder, he asked what I wanted to use it for and suggested a great crank at a very fair price. I was under a time constraint and he really worked with me. Great customer service from DPR. _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4025 Location: Redwood City, California
Posted: Wed Feb 10, 2010 9:37 pm Post subject: Cranks |
I had Demello build me a crank for my 1.9 WBX and do a complete balance . I used their services during the Christmas special they have.
It was like 15% off if you had three or more services done by them .Parts were delivered on time and packed well and that thing was smooth as hell for the 3 hrs I had it running before I sold it.
I would not hesitate to use Demello again.
Stacy |
