notchedup Samba Member
Joined: September 18, 2009 Posts: 19 Location: La Mirada, CA
Posted: Tue Feb 09, 2010 3:41 pm Post subject: 912 Transmission |
Hey guys, just bought a 67 912 and the trans is bad. Looks like they ran it without oil and when I took it apart there were bearings frozen and some of the gears looked blue from heat. I am not a tranny expert but would like to know what it costs to rebuild, who is recommended by you guys/girls as a good place to work on it, or should I just buy a used one.
It is a 902/0 4 speed box.
Thanks for all the help |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Tue Feb 09, 2010 11:09 pm Post subject: |
Used |
Rescue912 Ferdinand Sanford
Posted: Thu Feb 11, 2010 9:48 am Post subject: |
If you can find a decent used one that would probably be least expensive. Dunno if Vic Skirmants works on anything that late anymore but you can ask - http://www.356enterprises.com
I have a few 5 speeds in the barn but no fours... _________________ Beauty is in the eye of the key holder ... |
Posted: Thu Feb 11, 2010 11:56 pm Post subject: 912 Tranny |
Rescue 912, what would you want for one of the 5 speed tranny core. I found a rebuilder in PA that has a great reputation in the 914 circuit. Can you PM or email me your price? |
Posted: Fri Feb 12, 2010 9:58 am Post subject: |
pm sent _________________ Beauty is in the eye of the key holder ... |
turbobob Samba Member
Posted: Mon Dec 30, 2013 7:56 pm Post subject: |
912Rescue, still got a 5spd 912 tranny core out in the barn? _________________ Robert Young
ForcedPerformance.net |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Tue Jan 14, 2014 4:40 pm Post subject: |
Is it possible swap 914 5 speed gears (901 trans) into the 902 4 speed case or is the case different. Alternatively a 914 trans with nose cone pieces/R&P from the 902? _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
savaden Samba Member
Joined: May 03, 2012 Posts: 83 Location: North Carolina
Posted: Mon Mar 10, 2014 3:41 pm Post subject: |
4sp and 5sp cases are the same and you could swap all the gears and everything into the early 4sp case. The differential carrier and bearings are different, but the ring and pinion are the same.
SV |
whaletailcanada Samba Member
Joined: December 17, 2013 Posts: 4 Location: waterloo,ontario,canada
Posted: Fri Mar 14, 2014 9:42 am Post subject: 912 911 trans |
the expert in NA is gary fairbanks in Connecticut easily found if you google,but you will be much cheaper if the other knowing good one work. |
Tonto2 Samba Member
Joined: March 31, 2014 Posts: 1 Location: Portland Oregon
Posted: Mon Mar 31, 2014 9:24 pm Post subject: |
German Transaxle in Bend Oregon.
They are as good as they come.
I have two cars with there rebuilt trans in them. Work perfectly for years. |
