Angelomater Samba Member
Joined: February 08, 2009 Posts: 5 Location: Victorville, Ca
Posted: Tue Feb 09, 2010 9:52 pm Post subject: Check out my 1776 rebuild parts |
Tell me what you think and if i need to change anything thanks!
78mm Chromoly Stroker Crankshaft -8181-
Chromoly I-Beam Connecting Rods 5.50" Up To 6500RPM
Engle 110 Camshaft 4.30 Lift x 284 Duration-ACC-C10-5266
Mahle Pistons 90.5mm x 69mm-Forged -01-98-1990-B
High Performance Heads 90.5 Bore Road Warrior 5 series-EHD0012
Scat Racing Lifters -ECV0013 |
impala400sb Samba Member
Joined: June 14, 2009 Posts: 6 Location: forreston, il
Posted: Wed Feb 10, 2010 5:40 pm Post subject: |
i'm no expert like some of theres other guys on here (or so they think) but if you use anything other than the 69 mm crank it wouldnt be a 1776 anymore would it? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Feb 10, 2010 5:44 pm Post subject: |
impala400sb wrote: |
You are correct as usual King Friday. _________________ Glenn
Member #1009
#BlueSquare |
AlteWagen Troll
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Feb 10, 2010 7:19 pm Post subject: |
Everything looks good. 5.5 rods? You can get away with running 5.4. What CR are you thinking of running with? What kind of carbs are you going to run? Im not familiar with that type of heads however. I would run 82x90.5 B p/c's. Engle 110 cam is pretty great mild cam, but decent for a nice street motor. -Jon
Oh yea get a decent set of German lifters or refurbed wiesmans. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely!
Posted: Wed Feb 10, 2010 7:21 pm Post subject: |
double post oops. _________________ 2276 IDA's 86C 11-1 DD !
Check your oil levels routinely! |
VolkDubz Samba Member
Posted: Sun Apr 26, 2015 12:27 am Post subject: Re: Check out my 1776 rebuild parts |
Angelomater wrote: |
Sounds like a nice little setup |
