nasty grey goo in the air cleaner
cschuck14
cschuck14 is offline
PostPosted: Wed Feb 10, 2010 2:39 pm    Post subject: nasty grey goo in the air cleaner Reply with quote
i took off my air cleaner today, and after breaking the lightly burned rubber, i proceeded to take it out of the car and tilted it when thick oily nasty smelling grey goop spilled over the ground. thank god i was outside it is nasty. what the hell is it? why was it in the cleaner? i have a fi 72 that had a small engine fire
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Feb 10, 2010 3:13 pm    Post subject: Reply with quote
It is an oil bath air cleaner.
There is supposed to be oil in it up to a certain line.
It is supposed to be cleaned each time you change oil.
Sounds like yours has not been cleaned in a long time.
Gary: OK. Ima poop.
KTPhil
KTPhil is offline
PostPosted: Wed Feb 10, 2010 4:59 pm    Post subject: Reply with quote
Might also get grey goo (or whitish creamy goo) from a poorly ventilated crankcase breather.
cschuck14
PostPosted: Thu Feb 11, 2010 1:48 pm    Post subject: Reply with quote
ya has not been changed. so do i need to change the air filter or does the oil keep it from needing to be changed
and how much oil do you put in it?
KTPhil
KTPhil is offline
PostPosted: Thu Feb 11, 2010 1:59 pm    Post subject: Reply with quote
terrieann
terrieann is offline
PostPosted: Thu Apr 26, 2012 4:49 am    Post subject: Reply with quote
KTPhil wrote:
Just what I was looking for. Thank you! Not being familiar with oil bath air filters I wasn't sure if it had to be changed when the oil and oil filter was changed. I love where it says to clean it with a wood chip. Wink
