GeoffP Samba Member
Joined: July 14, 2002 Posts: 400 Location: Blaine WA / Vancouver
Posted: Tue Apr 27, 2010 10:08 pm Post subject: Re: Bigger is "sometimes" better.......... |
Mr. Okrasa wrote: |
How about uppin the ante now? Here are several sets of GENUINE 48mm Webers that are "sand cast". Note the little enamel badge that you dont find anymore.
Todays "immitation" die-cast Weber 48's were made from these prototypes. I bought these when they were cheap at $5,000 a pair. Enjoy! Mr. Okrasa
Very nice! Still not as rare as the 46 IDM's I sold a few years ago |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed Apr 28, 2010 7:23 pm Post subject: Re: Weber 40 IDF / SOLEX 40 P-11 Update! |
Mr. Okrasa wrote: |
Look at what I got in the mail today! Im going to be "test fitting" these Okrasa intake manifold prototypes this week. Cheers! Mr. Okrasa
Any updates? _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Tue Oct 11, 2011 10:41 pm Post subject: |
cru62 wrote: |
BUMP
SO? Any news, Joe? |
Speedwell USA has already made these and I believe is on his second run now _________________ Stocking distributor of "The Funky Green Panels"
Posted: Wed Oct 12, 2011 9:00 am Post subject: |
cru62 wrote: |
BUMP
The guy that is/was going to make them has been at it for over 4 years now?? Since I have purchased
some intakes from Ray also, I wont be coming out with a set. This idea took too long and just "fizzled" away....... _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Art Thraen Samba Member
Posted: Fri Oct 14, 2011 6:00 am Post subject: Re: Bigger is "sometimes" better.......... |
Joe, Very cool PIC!
Very cool PIC! |
cru62 Samba Member
Posted: Fri Oct 14, 2011 5:39 pm Post subject: |
Ray doesn't answer emails and his website is "under construction" for ...well, forever. Guess selling his junk is not a priority. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sun Oct 23, 2011 9:51 pm Post subject: |
Hello-
I hate to be a stick in the mud, but I have some practical questions for those of you using Solex P40-11 carbs.
1) I believe the Solex carbs came with 32mm venturis. Are you planning on running your engines in the 5-6K range, or are you going to install some smaller venturis?
2) I've read that the later split shaft Solexs have a much better transition circuit. I've also read that they're a pain in the rear until you convert them over to a solid shaft configuration. A number of carb restorers will do this for a little less than $2K. Are you rebuilding these yourselves, or are you biting the bullet, and shipping them out to be rebuilt.
Smokin' hot carbs, by the way.
Regards,
Paul |
GTV Samba Member
Posted: Mon Oct 24, 2011 2:27 am Post subject: |
I'm running p11's on a 1600 based engine, so I can't really comment on venturi size. I did however have a set of split shaft carbs converted to solid shaft by 356 Carb Rescue. The split shaft carbs have an independent idle circuit, as well as 5 progression holes rather than the 4 found on the earlier solid shaft carbs. Anyway, I had the bodies done on an exchange basis, I tore them down and reassembled the carbs myself. The work done was VERY well done, but it wasn't cheap at $675 for the pair.
I would like to know if they fit in a Beetle engine compartment using those tall manifolds and the early shroud. P11's are HUGE carbs (width wise), mine are atop vintage EMPI globe manifolds and I had to drill 1" holes in each side of the body for the accelerator pump rods to pass through. I was not happy about that. _________________ EMPI Power Rules! |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
