busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
korfmach Samba Member
Joined: February 28, 2014 Posts: 247 Location: Fort Collins, CO
Posted: Sun Jul 12, 2015 8:37 am Post subject: |
Colin, thanks again for publishing this excellent guide. A couple of notes:
Some of the diagrams have vaporized; I managed to get by without them but reposting them would be beneficial, especially for those not yet familiar with the nomenclature.
It might also be useful for the guide to specify that the procedure applies to Buses with an OEM (DVDA) distributor. If your Bus is cursed with a 009, you're kinda on your own.
The intake hose mentioned in Colin's spiel on emissions controls is missing from every '72-'74 Bus I"ve seen. I don't know how critical it really is for the engine, but I've replaced mine. It is a 63mm (2.5 inch ID) hose about 80-90cm long and is secured with a hose clamp at the airbox inlet and two lugs on the engine compartment wall near the right elephant-ear.
A good-quality, two-layer neoprene replacement is available from Pegasus Racing (part # 3630-2.50-3FOOT) for about $20. I haven't been able to find the OEM paper hoses anywhere; they are a different size than the common heater hoses. _________________ 1989 Westy
2016 Golf TSI
Gone, but not forgotten:
1974 Dorper Baywindow, "The Bleeding Trout"
1998 Jetta TDI, "Trixie"
1987 GTI, "Heike"
1974 Thing, "The Luftwaffel"
1974 Ghia
1966 Ghia |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Jul 12, 2015 9:55 am Post subject: |
korfmach wrote: |
A) It might also be useful for the guide to specify that the procedure applies to Buses with an OEM (DVDA) distributor. If your Bus is cursed with a 009, you're kinda on your own.
B) The intake hose mentioned in Colin's spiel on emissions controls is missing from every '72-'74 Bus I've seen. I don't know how critical it really is for the engine |
A) 009 can work, but I am not going to provide the work around solutions for an 009, it would make mincemeat of the already hard-to-discern logic behind these carburetors.
SVDA can work, too. Like the 009, without a retard at idle, you have to choke off the central idling circuit to get a decent idle. Then you have a poor transition to the main carbs off idle, etc.
B) That hose is the cool air supply. It is not emissions related. I do recommend that we pony up for a hose that can reach the right side scoop area.
As parts dry up, we will need to exercise ever-greater creativity to achieve anything like the driveability of the original engineering. It can be done.
Colin _________________ www.itinerant-air-cooled.com |
sparky892 Samba Member
Joined: August 22, 2014 Posts: 97 Location: Ann Arbor, Mi.
Posted: Wed Jul 15, 2015 6:37 pm Post subject: |
Amskeptic wrote: |
Colin |
Colin, would you recommend that I replace the weber's that I have back to the originals?
I have a 72 Westy 1.7 with weber ict and can not get them to co-operate with each other.. _________________ 72 westy 1.7 dual carbs |
bwaz Samba Member
Posted: Mon Dec 14, 2015 11:08 pm Post subject: Re: Final Factory Dual Carb Adjustment Procedure |
Any chance you could repost those missing images from your first post?
Great info, thanks |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Dec 14, 2015 11:21 pm Post subject: Re: Final Factory Dual Carb Adjustment Procedure |
bwaz wrote: |
Check this page:
http://www.itinerant-air-cooled.com/viewtopic.php?t=7767
Perhaps a mod or Colin will edit the first post accordingly, since the picture links seem to be broken. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
bwaz Samba Member
Posted: Tue Dec 15, 2015 1:55 pm Post subject: Re: Final Factory Dual Carb Adjustment Procedure |
asiab3 wrote: |
bwaz wrote: |
Check this page:
Perhaps a mod or Colin will edit the first post accordingly, since the picture links seem to be broken. |
thanks for the link! |
