1967250s Samba Member
Posted: Tue Jun 25, 2013 7:12 pm Post subject: |
An aside, has anyone used urethane bushings? And what size to look for- 1 7/8" or are any made for Bus-'72? And what do you do for rust on the tube/bushing so it does not wear away the bushing prematurely, aside from applying talc? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 25, 2013 7:39 pm Post subject: |
1967250s wrote: |
I can't answer the Urethane question but definitely sand the bearing surfaces on the torsion arm smooth and shiny, rusty lumps will eat away the new bushing in no time. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue Jun 25, 2013 11:01 pm Post subject: |
if your doing the spring plate adjustment, put your jackstands under the torsion tube. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
pintail78 Samba Member
Joined: February 24, 2013 Posts: 97 Location: san diego
Posted: Wed Jun 26, 2013 2:03 pm Post subject: |
Thanks Stuart, I looked today, that looks best nice and beefy looking. John T. _________________ 1968 Transporter Bus |
Posted: Wed Jun 26, 2013 10:12 pm Post subject: |
pintail78 wrote: |
Thanks Stuart, I looked today, that looks best nice and beefy looking. John T. |
it will give you more solid squat with the bus. if you put the stands under the frame rails, when you jack up the spring plates (if you are lifting your bus) then the bus will lift up a LOT easier than you would think. go for those torsion tubes, especially if you are lifting it up. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri Jun 28, 2013 1:37 pm Post subject: |
Anyone had any problems with the bus lifting up when jacking the spring back up to get it over the lip? I was just going to level the bus and use the torsion bar as jack points. Seems kinda scary if the bus started to lift. Any suggestions or experience. _________________ 1968 Transporter Bus |
Posted: Fri Jun 28, 2013 1:40 pm Post subject: |
If the bus is lifting you have the plates set wrong, are you using a protractor or doing it by "eye"?. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 28, 2013 1:53 pm Post subject: |
I havent done it yet, I was going -1 inner and +1 outer to raise it about 1/3 of an inch or 50'. Just a general question, someone had mentioned it and I wondering about other peoples experiences with it lifting off the jack stands. _________________ 1968 Transporter Bus |
Posted: Fri Jun 28, 2013 2:50 pm Post subject: |
When it's set properly you can almost pry it up onto the stop without a jack but one of those little scissor jacks makes it easier, not much load there and it won't lift the bus. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 28, 2013 5:19 pm Post subject: |
cool thanks, I like to know what Im doing before I get into it. I appreciate it. _________________ 1968 Transporter Bus |
Posted: Sun Jul 07, 2013 6:08 pm Post subject: |
Just finished the job, heres my take, I have a 68 bus so its a little different than others.
-I had to loosen my parking brake cable, on mine it s easiest just doing it from the cab.
-I had to pull my brake lines off the nub to get more clearance.
-I used anti-seize instead of talcum powder, a buddy of mine owns a VW repair shop locally (for 30 years) and he said it will last longer and work better.
-I adjusted mine to 24 degrees (bentley says 23 50'), I adjusted the drivers side up 1degree, the passenger side was fine as is.
-the silver sharpie wiped off easily and i lost my marks on the first side, i just adjusted it to gets about 1 more degree from original measurements.
-I used a dremel tool to permanently mark original settings on the second side as the sharpie sucked and wiped off.
-The torsion bushings were wasted, i think they give the bus a lot of freeplay when loading and unloading, probably will effect handling, i'll see in the next few days.
-It took my 7 hours total, mainly because i had to pull all the brake stuff off after I took everything else apart, and my silver sharpie marks were wiped off on my first side. _________________ 1968 Transporter Bus |
dames Samba Member
Posted: Thu Jul 18, 2013 7:49 am Post subject: |
I am a first time mechanic and am attempting to return my bus to stock hight.It has been lowered two splines in the past I have managed to strip the rear and understand how it all goes back but on one side the spring plate looks like it stands proud but its back far enough to sit on the step so now im thinking the spring is a bit shorter is this possible? |
dames Samba Member
Posted: Thu Jul 18, 2013 8:36 am Post subject: |
Thanks Busdaddy I have just had another look and im sure the torsion bar has gone in a bit far and the spring plate is fully back as it will sit on the step fine. |
Posted: Thu Jul 18, 2013 10:09 am Post subject: |
dames wrote: |
It is normal for the spring plate to not fit completely flush with the torsion bar. |
Posted: Thu Jul 18, 2013 10:26 pm Post subject: |
anyone else see the spring plate article in a recent issue of hot VWs? lots of cool stuff to look through _________________ Stuart Zickefoose
206-841-7324
[email protected] |
scirocco_crazy Samba Member
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Thu Sep 19, 2013 6:23 pm Post subject: |
The rear of my bus unloaded is a little low, but when its loaded for camping and the small trailer it can get pretty saggy. I would like to lift it up a bit but don't want to destroy the new CVs and don't want to go to 930s since the current ones are brand new. Currently the axle angles are 9 degrees on flat ground unloaded. Assuming most miles will be driven unloaded what is the upper limit of the axle angle before the CV's lifespan starts to reduced???? _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
vwcanuck Samba Member
Joined: September 27, 2012 Posts: 155 Location: Canada
Posted: Thu Oct 03, 2013 4:53 pm Post subject: |
I know this is an old thread ... but did it ever help me today. Thanks for the great instructions and pics patayres!
One thing to add ... when putting in the bolts to secure the hub back to the end of the spring plate, start with the 2 captive bolts followed by the 2 nut and bolts that go through the spring plate and hub. I spent 30 minutes doing it the other way around. It only took sconds to get them threaded this way. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Mon Oct 21, 2013 4:43 pm Post subject: |
vwcanuck wrote: |
Thanks for that. I don't remember how I did my left side a while ago, but the right side was quick when I did it your way today.
Just a heads up for those who read these threads for fun- It is probably worth replacing your torsion bushings even if you don't plan on resetting the spring plate angle. Here are my used ones, notice the wear on the left bushing. The right bushing looks like that on the back, but ok on the visible side (for comparison.) When I took the plate cover off, rubber shards and powder came pouring out. 98k documented original miles on the chassis. I didn't hear any squeaks or grinds beforehand, but I had the bushings on my shelf and thought it would be fun
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
